2013 Gear Up... all lights working EXCEPT the headlight and "presence" light
Posted: Sat Aug 25, 2018 2:34 pm
by MajorFaversham
Okay, I know this should be a relatively quick fix, BUT... I checked all fuses in the left fork fuse box (all 15 Amp blade type) and they appear to be just fine. I tested the LED headlight itself after removing it and both the high and low beams work. I see a mysterious in line fuse on the wiring diagram but according to the diagram it goes directly from the battery to the tub fuse box. Someone suggested that despite the wiring diagram, if it was blown that would be the problem. I took the housing off of the left handlebar switch and all connections are clean and securely soldered.
What is the easiest way to access this mysterious inline fuse with the least amount of disassembly? Is it hiding under the seat bracket or do I have to remove the gas tank?
Any and all advice is appreciated. Thanks in advance.
Re: 2013 Gear Up... all lights working EXCEPT the headlight and "presence" light
Posted: Sat Aug 25, 2018 4:16 pm
by wooden nickel
Did you check the headlight relay?
Posted: Sat Aug 25, 2018 8:25 pm
by MajorFaversham
Yes the problem seems to be in the light switch itself. If the wires are twisted 'just the right way" the switch works as designed. Headlight on when key is turned, high beam works, passing button works (I think. The passing button just seems to be a "push to hold and the high beam comes on... release it and the high beam turns off" ).
I swapped out the presence light bulb on the sidecar fender and it stays on when the key is turned as it should whether or not the headlight low beam/running light is on.
All other lights and switches work just fine. The headlight switch seems to be the issue which is strange as all wires have solid solder connections on the switch. With key turned off, I spritzed contact cleaner into the switch itself and clicked it numerous times through all positions and some dirt and crud did drip out.
Posted: Sun Aug 26, 2018 6:47 am
by wooden nickel
Your passing position is working properly. The most likely problem is a bad solder joint on the switch but it could be a broken wire. Kinda depends on where you were twisting the wires when it worked properly. The switch itself doesn't usually respond to wire twisting. According to the wiring diagram, it is the red wire. Just follow it to the solder joint on the switch, Unless the wiring is pulled over a sharp corner, the most likely problem areas are the solder joint and where the wire enters the switch.
Edit: It is early morning, brain not awake. Since your passing position is working, it almost has to be the switch itself. Both positions use the same wire.
Take it apart and clean the contacts. I usually use a pencil eraser unless they are really burned and then I use a fine file or sandpaper.
Posted: Sun Aug 26, 2018 3:09 pm
by Mr Wazzock
Also check all multi-way plugs and sockets. All connectors that go to the headlight. I did once have a R80 switch cluster completely to pieces, no simple job, but nothing wrong with it*. It was bad connectors in the headlight bucket.
(* Until I took it apart, losing a tiny ball bearing in the process, did manage to find a replacement but those switches were never the same since.)
Posted: Tue Sep 11, 2018 1:15 pm
by Ironhand
Definitely check the large (blue on my 2015) connectors between the handlebar switchgear and the main harness. Several of us have experienced similar symptoms due to an improperly inserted pin within the right side connector.
