Finding neutral and shifting
Post by gobium » Fri Nov 24, 2017 8:57 am
Re: Finding neutral and shifting
Post by hotflash44 » Fri Nov 24, 2017 10:18 am
thanks, Van haven't had a issue on my 2016 GU, but always nice to know whats going on just in case,(no pun intended), for those who have experienced the problem this will certainly help. :cheers:
Post by gobium » Fri Nov 24, 2017 10:22 am
hotflash44 wrote:thanks, Van haven't had a issue on my 2016 GU, but always nice to know whats going on just in case,(no pun intended), for those who have experienced the problem this will certainly help. :cheers:
Vid is more for the new ural owners .
:cheers:
Post by stagewex » Fri Nov 24, 2017 10:26 am
:cheers:
... and also for those of us who are losing their marbles.
Post by hotflash44 » Fri Nov 24, 2017 10:37 am
gobium, your videos are great, and easy to understand your a good teacher. I have personally only used you video on how to adjust the neutral light switch which worked perfect ,(i love my light use all the time). Hope all this admiration and praise doesn't make you toss yesterdays Turkey. :bow: :boogie: :cheers:
Post by Lokiboy » Fri Nov 24, 2017 11:19 am
Video is not just for newbies- I never knew I could go directly from first gear into reverse gear without needing to press on the shift lever (1st-2nd) at the same time.
Thanks. An old dog can learn new tricks
Post by Albuquralque » Fri Nov 24, 2017 11:29 am
Post by gobium » Fri Nov 24, 2017 12:07 pm
Lokiboy wrote:Video is not just for newbies- I never knew I could go directly from first gear into reverse gear without needing to press on the shift lever (1st-2nd) at the same time.
Dave in vid i did not show 2nd gear into nuetral.
Yes can be done just like 1st gear
Post by Lmo » Fri Nov 24, 2017 2:40 pm
Van,
Once spring is back in place, transmission in neutral, adjust neutral switch screw so the light just comes on? No further in?
Screwing switch in too far causes this problem?
Subsnowden
Post by Subsnowden » Sat Jan 27, 2018 8:23 pm
My neutral light is on in 1st, N, and Reverse. I think my little tab is out of place...I’m about to set my Ural ablaze
Jon
Nomad
2015 Ural Gear Up
keetmanaa
Post by keetmanaa » Sun Aug 19, 2018 4:20 pm
Using this method: I'm in first gear, engine running, clutch disengaged...how much pressure has to be applied to the reverse lever to get the gearbox to go into neutral, and then again into reverse l?
Is the repositioning of the reverse lever to 10 o'clock just to allow the foot to be used with greater pressure?
2015 Gear Up
2010 Yamaha WR250R
2004 DL650 V Strom
Post by gobium » Sun Aug 19, 2018 4:42 pm
Howdy.
The Reverse lever position at 10 o'clock is to step on using the right heel.
On pressure, every ural is different.
Newer more pressure. Older less. You have to feel it.
Niteblues
Post by Niteblues » Sun Aug 19, 2018 10:12 pm
Scott
2004 Ural Patrol
keetmanaa
Post by keetmanaa » Tue Aug 21, 2018 8:54 am
Thanks, I've been a little hesitant as it sounds abnormal, but I trust you two and I'll adopt the method.
2015 Gear Up
2010 Yamaha WR250R
2004 DL650 V Strom
Post by gobium » Tue Aug 21, 2018 9:40 am
Your bike is still is new, gear box will loosen up after 30000 km
