Ural: understand & servicing electric starter
youtube]http://www.youtube.com/watch?v=kpSNNeteaow[/youtube]
- co_g30
- Order of Lenin
- Contact:
Re: Ural: understand & servicing electric starter
great video tutorial on disassembling and servicing a URAL's starter! thanks for doing this, I see this in my near future.
CO_G30
2014 Ural Patrol "Scarlett"
1987 BMW R80 "Brigitta"
2006 Yamaha TW200 "Yagi"
- cdscoot
- Order of Victory
- Location: The lower southern tier of central upstate NY ,Binghamton,NY
How often should cleaning be done? Do you wait for a problem to develop?
Craig
2010 Patrol T
2016 BMW R1200GS
2010 Patrol T
2016 BMW R1200GS
Really, really helpful. You and others are opening my eyes to the fact that the fear (maybe more of a concern of making what was a little problem into an overhaul) of doing something is far greater than actually doing it. It's not rocket science and knowing what to expect takes the mystery and guess work out of the equation.
Thanks
Thanks
110,000 km and counting
- cdscoot
- Order of Victory
I wholeheartedly agree ! You are making us self sufficient one video at a time !!Lokiboy wrote:Really, really helpful. You and others are opening my eyes to the fact that the fear (maybe more of a concern of making what was a little problem into an overhaul) of doing something is far greater than actually doing it. It's not rocket science and knowing what to expect takes the mystery and guess work out of the equation.
Thanks
Craig
2010 Patrol T
2016 BMW R1200GS
2010 Patrol T
2016 BMW R1200GS
Great video Van!!
Always better to see it done before you try it.
Thanks!!
Thanks!!
2002 Tourist
2013 Husky TR650 Strada
Thank you.
Might might be due for a cleaning soon.
-T
-T
Yogi Berra
2011 Orange/Silver Patrol
2017 CRF1000 Africa Twin
1977 R100S
former bikes-
2001 HD Sportster
1981 Honda CX500 Custom
Yogi Berra
1977 R100S
former bikes-
2001 HD Sportster
Great video. Thanks Van. Now I need to take those broken and apart starters I have to see if I can get them to work
I do have one that is rusted together, meaning the outside case with windings and the rotating shaft (armature?). Any suggestions in how and what to use to try and free them up without ruining the windings
motoleo
?? Dnepr MT-11 project
07 Patrol-never quite done
Impact out the four nuts that hold the magnetic fields and blast holes with pb plaster. See if that would help.motoleo wrote:Great video. Thanks Van. Now I need to take those broken and apart starters I have to see if I can get them to work
Thanks, that is what I was thinking but I wasn't sure if the pb blaster (or Kroil) would effect the varnish/coating around the wires.gobium wrote:Impact out the four nuts that hold the magnetic fields and blast holes with pb plaster. See if that would help.motoleo wrote:Great video. Thanks Van. Now I need to take those broken and apart starters I have to see if I can get them to work
motoleo
- Albuquralque
- Order of Victory
Nicely done!
(save)
2015 softail deluxe w/motorvation spyder “fattie”
2010 gear-up nato camo "Pasha" (gone but not forgotten)
2007 sportster 883 "blue beast"
- Albuquralque
- Order of Victory
Gobium,
One other check you can do with the solenoid. It actually serves two purposes.
1. It pushes the starter gear into position on the flywheel.
2. There is a relay inside there that when power is applied to the small blade connector, a relay also connects the battery power lug to the lug with the large white wire on it. This provides +12VDC to the starter motor to turn.
. Removing frozen bolts I've never had damage issues using Kroil or PBlaster (my favorites). For cleaning start/gen internal parts I've used Naptha with no harm to the windings. Not sure but I think(?) the windings are clear coated with lacquer so don't use a lacquer paint thinner as a solvent. If it's a shellac coating don't use alcohol. A quick call to your local auto elec shop will set you straight on solvents.motoleo wrote: Thanks, that is what I was thinking but I wasn't sure if the pb blaster (or Kroil) would effect the varnish/coating around the wires.
Great video!
I have problems with starter on my Ural Patrol 2009. After I have removed back plate of starter I saw that 4 springs that press the brushes are burned out, and that insulator tape on back of the starter cover is missing. Does anyone know original dimensions for starter springs, so I can buy new one.
Thanks
Thanks
