Replacing Head Gasket
atlasheating
Post by atlasheating » Fri Mar 20, 2020 1:30 pm
Looks like it is time to replace the head gasket on the Non Sidecar Side. I have the gaskets and the procedure looks straight forward.
Should I use any Head Gasket sealant???
Re: Replacing Head Gasket
Post by Desantnik-VDV » Fri Mar 20, 2020 3:35 pm
Usually, no sealants are used. Just clean surfaces on both sides.
And, make sure you have the gasket oriented correctly. Oil return hole must be installed correctly to allow oil drain (go back) to sump. :D
The rest is just a History.
Post by Lokiboy » Fri Mar 20, 2020 4:00 pm
Good news... the newer gaskets are universal so orientation is no longer a problem. That said, what VDV stated is something to look for incase you’re sent an older version.
Dr.Tramp
Post by Dr.Tramp » Fri Mar 20, 2020 11:07 pm
As long as you're doing one side you might consider doing the other side too. That way the gaskets on both sides start their life cycle at the same time. Also while you're there check the flatness of the gasket surfaces for any warping.
Ride Safe. Dr.Tramp............
atlasheating
Post by atlasheating » Sat Mar 21, 2020 10:48 am
Thanks, all good information.
Post by RC20 » Sat Mar 21, 2020 1:31 pm
You don't have your Ural year listed so .................
Head gaskets can last forever (often replaced because you need to fix something else) or fail well before they should.
Sans a real old machine and a lot of miles do the one you need to. Check the head bolt torque on the other side but otherwise, no.
atlasheating
Post by atlasheating » Sat Mar 21, 2020 2:58 pm
My Ural is a 2014 Fuel Injection.
The head gaskets were leaking when I bought it. The Non Sidecar side recently got real bad. The other side is holding up pretty good. I really don't want to have to remove the sidecar to work on that side.
It took about one hour fro start to finish. I also have a spare gasket if I need it.
Post by windmill » Sat Mar 21, 2020 3:55 pm
Don't forget to check head nut torque, and valve clearance at 500 km.
Post by RC20 » Sat Mar 21, 2020 8:55 pm
If you are ok with the far side as noted, check the torque and you don't have to do it unless it bothers you or gets bad enough.
I would check your outboard side first for torques as well. Pretty rare for that kind of gasket both side that new to leak.
atlasheating
Post by atlasheating » Sun Apr 05, 2020 7:19 pm
I finally got a chance to take the rig out for a 30 mile ride. No Leaks! Running good.
Post by Tomcatfixer » Sun Apr 05, 2020 8:20 pm
No need for all that bother. Simply remove two of the sidecar support strut bolts and loosen the other two, then you can simply lean the bike away from the hack, which provides enough room to remove the head.
atlasheating
Post by atlasheating » Mon Apr 06, 2020 3:28 pm
That is not too bad.
atlasheating
Post by atlasheating » Sun May 17, 2020 9:52 am
Just an update: after about 200km's
I was getting a small amount of oil leaking out of the valve cover so I opened it up.
Both valves were tight. 2 out of 4 head bolts took a little torquing. All is hapy.
I gooped up the valve cover gasket, hopefully it won't leak now.
