Breaking in a new transmission
Beastmaster
Post by Beastmaster » Wed Mar 04, 2020 11:16 pm
Hi gang, I've been without my Ural (2018 M70) for right at a month now and just got a phone call that its ready at the shop and I have some questions.
The transmission started acting up early during the holidays last year (it kept popping out of 3rd gear during the upshift) so I took it in to have it looked at. Its all covered under the warranty and they decided to replace the whole transmission rather that work on it.
If you don't mind, I'll talk miles instead of kilometers since my bike is set up that way.
My question is that now that I have a Motorcycle with 12,000 miles on the engine and a transmission with almost none, how should I handle the break-in? My current plan is to follow the normal break-in procedures per the manual for the first 620 miles with an oil change at 310 miles.
The manual reads:
1. Do not overload or “lug” the engine. (I shouldn't think this would matter for the transmission)
2. Do not exceed a top speed beyond 60mph.
3. Do not ride at a constant rpm for long periods of time.
4. Try to vary speed and load when riding.
5. Shift smoothly between gears and do not down shift at high rpm.
6. Always be sure the engine is warmed up before riding.
7. Follow the pre-ride inspection.
Am I over-thinking this?
Donbmw
Re: Breaking in a new transmission
Post by Donbmw » Wed Mar 04, 2020 11:58 pm
I followed the first mileage when I had my transmission replace.
Don
Post by Lokiboy » Wed Mar 04, 2020 11:58 pm
I don’t think the break-in applies to the transmission.
Post by windmill » Thu Mar 05, 2020 12:45 am
Back in 2013 IMWA replaced the transmission main shaft on my Patrol when they installed a prototype clutch, but they didn't mention anything about breaking it in after the rebuild, and they're usually don't overlook such things.
They reminded me several times about following the break in procedure after they installed the Gen II EFI, and 2020 engine upgrades on my M70.
I don't think its a concern with the transmission.
Post by chaos2 » Thu Mar 05, 2020 1:58 am
I had my transmission rebuilt by Heindl a couple years ago, plugged it back in with a new clutch and never gave it a second thought as far as break in.
Beastmaster
Post by Beastmaster » Thu Mar 05, 2020 8:29 am
Very cool, thanks for all the feedback.
I wanted to get some opinions here because the place that has done the work is new to Urals. They specialize in Italian motorcycles and just became authorized to do warranty work and not sure they know all the ins and out of the bikes yet. In fact, that's one of the reasons it took so long, they were waiting on books & equipment to work on another unrelated issue I had.
Post by jeffsaline » Thu Mar 05, 2020 10:06 am
If it was my machine and new transmission I would ride it like normal and change the lube at about 100 miles immediately after finishing a ride while the lube is still hot. I would drain into a clean catch basin and check for magnetic particles/pieces. I would also examine the catch on the magnetic drain plug. If it is toothpaste smooth I would be wipe it clean and move on. If it is gritty like sugar or larger particles I would do another lube change after 100 more miles and check again. I would also use a new crush washer on the drain plug and not over tighten it. Fill with your lube of choice.
Do be aware it might take hundreds of miles to get it shifting smoothly (for a Ural).
Post by windmill » Thu Mar 05, 2020 10:40 am
Ural moved away from crush washers to Dowty washers several years ago, they would be OE on the OPs bike, and what Ural would supply if ordered from them. There's no reason to replace them unless there's visable damage to the seal, and that's unlikely. The ones on my Patrol are at least 10 years old,and still look like new.
They only need to be 2 finger snug.
Beastmaster
Post by Beastmaster » Thu Mar 05, 2020 3:52 pm
So that's what they're called :thumbsup:
I love the forums for the helpful tidbits of info like this, thanks. :bow:
dale914
Post by dale914 » Tue Mar 17, 2020 3:30 pm
I just had my transmission replaced too. Both the dealer (who said the Ural's were carbonated until 2019 and that phasing the drive shafts doesn't matter) and Ural HQ in Redmond said that only the oil change is what needs to be observed. HQ said "take it easy for the first couple miles just to make sure it's all working, but that mostly applies to the engine, you can change the oil, and you'll get some slurry as the gears are breaking in, but it's not as urgent as the engine" so I'll be doing the oil, but otherwise, not too worried. I am sad that my tranny is rough and noisy again, but hopefully it'll smooth out.
05 Triumph Rocket 3
04 Honda CBR F4i
04 Honda Shadow
00 Yamaha VMAX
Beastmaster
Post by Beastmaster » Fri Mar 27, 2020 3:56 pm
I think I will do this as well, better safe than sorry. :cheers:
Hopefully your tranny smooths out soon. :shock:
