Found yet another dealer mistake, wrong plugs and gap not set
MountainPeakCruiser
Post by MountainPeakCruiser » Tue Sep 24, 2019 6:39 pm
I bought my 2017 GearUp with very low miles (200mi) from from a local dealership. It had been purchased from that dealership and had been traded back to that dealer less than 2 years later; every bit of assembly and maintenance on this bike had been handled by this dealer before I bought it.
So, I keep finding mistakes made on the bike. The latest were the NGK plugs, one step colder (BPR7HS) versus the manufacturer recommended BPR6HS plugs. I had been playing around with the EJK tuner and couldn’t pin down a an intermittent hesitation issue, until I went to check the color of the plugs. That’s when I found the wrong plugs and that they had never been properly gapped, less than .025 versus the recommended .04 gap.
And Tada! That little annoying bit of hesitation I had left after installing an exhaust, K&N filter, and EJK tuner is finally gone!!
Leave it to a sh!t dealership to do some bone-headed maintenance and create unnecessary issues. I hate having to undo other people’s shoddy work.
I’m speaking of Strictly Powersports in Pueblo West, CO.
Colorado Springs :devildog:
2017 Gear Up, Terra-cotta orange
Full LED light conversion w/ Hella headlamp&spotlight.
EJK tuner w/ K&N filter. Full GPR 2-into-1 stainless exhaust. ClearBra to protect cheap but sparkly Russian paint.
Trumpetwasher
Re: Found yet another dealer mistake, wrong plugs and gap not set
Post by Trumpetwasher » Tue Sep 24, 2019 6:47 pm
Two of the reasons I run E3.32 plugs. Factory gapped and covers both heat ranges.
Black Power Train
3.89 Final Drive
Reverse Hand Shift
Sidecar Power Panel
Handlebar Power Outlet
Deluxe Seating
Sidecar Side Panels
Armrests
Double-Spring Saddle
Santamaria Foot Rest
Custom Nose Art
Dnepr Leg Shields
XMT-MOTO Hand Guards
All LED lights.
MountainPeakCruiser
Post by MountainPeakCruiser » Tue Sep 24, 2019 6:52 pm
I’m not familiar with E3 plugs.
Trumpetwasher
Post by Trumpetwasher » Tue Sep 24, 2019 8:53 pm
Black Power Train
3.89 Final Drive
Reverse Hand Shift
Sidecar Power Panel
Deluxe Seating
Sidecar Side Panels
Armrests
Custom Nose Art
Dnepr Leg Shields
All LED lights.
Post by Lofty » Wed Sep 25, 2019 1:45 pm
Your post jogged my memory, so I reviewed my maintenance spreadsheet.
The spark plugs installed on my 2018 Gear Up, presumably at the factory in Russia, were NGK BP7HS. They were replaced at 6,xxx miles with two NGK BPR7HS spark plugs, these being the precise designation illustrated in the Owner's Manual. Resistor versus the non-resistor originals. I noticed no difference in the engine's performance, nor did I expect it.
The spark plug designation for the 2017 Gear Up, as noted on p. 1-4 of the Owner's Manual, is also NGK BPR7HS. Where are you reading that the factory recommendation is for the BPR6HS plug?
It also seems that unless your addition of a freer-breathing intake and exhaust was in perfect sync (tune) with the EJK tuner, that it at least contributed to the imperfect fueling, which usually manifests itself as hesitation. In isolation, that is one of the exact conditions that FI tuners like the EJK fitment are intended to solve.
Certainly, I'd expect the dealer to confirm that both spark plugs were properly gapped, during his pre-sale inspection process. I'm not sure that I'd expect him to examine the model designation of each plug, though. It's reasonable to expect that the factory would at least get that right...and per the 2017 Owner's Manual, it seems that they did so.
Your thoughts?
Post by Tomcatfixer » Wed Sep 25, 2019 2:17 pm
My 2015 manual specifies "sixes", but I believe I'm running "sevens". (Can't remember)
... but we all know how "accurate" Ural owner's manuals are. :roll:
Post by Albuquralque » Wed Sep 25, 2019 2:19 pm
Your thoughts?
Interestingly, 2014 - 2016 manuals spec the NGK BPR6HS plug, but the 2017-2018 manual the NGK BPR7HS.
MountainPeakCruiser
Post by MountainPeakCruiser » Wed Sep 25, 2019 10:28 pm
Your thoughts?
I left out the part where I properly gapped the BPR7HS plugs and that fixed the hesitation, then proceeded to install properly gapped BPR6HS plugs with an identical result. It was the improper gap, and it was an intermittent issue, more prevalent when the bike was cold. If I have a choice between plugs I don’t mind running the hotter of the two (BPR6HS) because it’s a low compression engine and pre-detonation is not a concern. As for where I got BPR6HS as manufacturer recommended, it was actually in my manual and here too on the frame (see pic):
Eric N
Post by Eric N » Wed Sep 25, 2019 11:04 pm
Back in 2016, just before buying my 2001 Patrol, I went down to Hymark (aka Strictly Powersports) to talk to them about Urals. The sales person didn't know much, and their maintenance person told me if it was pre 2007 it would be impossible for them to fix. It really came across as a "we just carry this brand to sell Indians, we don't really know anything about it".
Randy with Unique in Loveland is very good, knows his stuff.
2013 Retro Solo
2001 Patrol - Sold
MountainPeakCruiser
Post by MountainPeakCruiser » Fri Sep 27, 2019 11:44 pm
You’re not the first person that has recommended that shop.
