Off-road Map for ECUs
pbrowne
Post by pbrowne » Sat Sep 14, 2019 5:22 pm
i want to install the off road map on the ECUs. i find that the engines often stumbles between 2,000 and 3,000 rpm.
Is there a way I can do this myself or must I go to a dealer?
Shepherdstown, WV USA
2018 Ural GearUp "Arwen'
Re: Off-road Map for ECUs
Post by rivers » Sat Sep 14, 2019 5:54 pm
Don't know about the 018 Electrojet EFI setup but suspect similar to the earlier EJ EFI years. If so the OR map is a dealer install item. How many miles/kms on the bike? Is your 2000-3000 RPM stumble a new issue or you been dealing w/it since new? May just be time for a tune-up?
Burt1713
Post by Burt1713 » Sat Sep 14, 2019 6:50 pm
The OR map is definitely a dealer installation on 14-18 bikes.
2017 cT "Woody Moose"
pbrowne
Post by pbrowne » Mon Sep 16, 2019 12:24 pm
This has been there since day 1. I've checked the EFI sync via OBD and it's right on. It really seems to overly lean at lower rpm.
Post by Mr Wazzock » Tue Sep 17, 2019 6:27 pm
Mine has the OR, dealer installs it as part of PDI, cos the standard map is so crap. Not only affects Urals, I'm also on Moto Guzzi forums, lots of topics in recent years about new models are plagued with low speed stumbling, snatchy throttle, etc. Same reason too lean.
Yakatak
Post by Yakatak » Thu Oct 31, 2019 1:29 pm
If it was me and I had the non-off-road map, I would install a Dobek tuner instead of the OR map. With the Dobek you can enrichen the FI to your liking. I find the latest OR map too rich across the board. Unfortunately the Dobek can only enrichen the mixture....It can't lean it out.
2014 Ural Gear Up - Asphalt
