Ran Out of Gas? Video for Bleeding Fuel Pump on EFI bikes
MountainPeakCruiser
Post by MountainPeakCruiser » Fri Sep 13, 2019 3:25 pm
The quick and easy way!
Video link below:
https://youtu.be/nDsDDiZ-UFg
Colorado Springs :devildog:
2017 Gear Up, Terra-cotta orange
Full LED light conversion w/ Hella headlamp&spotlight.
EJK tuner w/ K&N filter. Full GPR 2-into-1 stainless exhaust. ClearBra to protect cheap but sparkly Russian paint.
Wanderrad
Re: Ran Out of Gas? Video for Bleeding Fuel Pump on EFI bikes
Post by Wanderrad » Fri Sep 13, 2019 6:21 pm
I had to learn that the hard way as well. Nice video!
-Scot
Post by Mr Wazzock » Fri Sep 13, 2019 9:34 pm
All well and good but fer chissake don't break off the plastic outlet spout, then you're screwed, someone on this forum has done this.
Knowing my luck I'll struggle to press the tabs down and break something. :(
I've already broken off the clip that secures the cover (actually a plug with no pins in it) onto the OBD port socket. :o
Hasn't fallen off yet tho.
MountainPeakCruiser
Post by MountainPeakCruiser » Fri Sep 13, 2019 10:18 pm
You shouldn’t have to apply that much pressure. Did you watch the video? If you push the connector in with light pressure, squeezing the tabs is very easy; that’s why I mention it in the video. Any part on this motorcycle can be broken if mishandled, so do it properly and you won’t have an issue.
Post by Tomcatfixer » Sat Sep 14, 2019 11:07 am
Thanks for not naming names, Mike. :lol:
