Fine tuning alignment question
pbrowne
Post by pbrowne » Thu Sep 05, 2019 5:31 pm
I seem to now have my rig going more or less straight. it had been pulling badly to the right when I first got it. It still pulls to the right a bit more than I think it should.
I've noticed that, at say 40 mph under power, it pulls to the right; but, if I pull in the clutch, it runs perfectly straight. Is this normal? I'm not sure why moderate, throttle just maintaining 40 mph on a flat road, should be causing a pull to the right.
Shepherdstown, WV USA
2018 Ural GearUp "Arwen'
MonkeysUncle
Re: Fine tuning alignment question
Post by MonkeysUncle » Thu Sep 05, 2019 6:17 pm
When you're coasting the bike and sidecar both have the same inertia. When you add enough throttle to maintain speed the car is being dragged forward by the bike. This drag causes the whole thing to want to track to the right a little, that is unless you are Mr Wazzock.
2008 KLR650
2013 GearUp
Post by Snakeoil » Thu Sep 05, 2019 6:25 pm
You are reaching the point where you can tune it further to your liking or leave it be. Mine runs pretty neutral with the hack empty. The throttle up or down is always going to have an effect. The more you ride the rig the less noticeable it will be because you will automatically compensate for it. The brain does some amazing things.
If you have a windshield on the hack, lower it and it may stop pulling. My neutral handling is with my hack windshield down.
Post by windmill » Thu Sep 05, 2019 9:27 pm
A rig will never track straight and neutral under all circumstances, it's subject to constantly changing dynamics. When all is said and done it's a matter of getting used to it.
Eventually one learns to use it to their advantage.
:FI:Igor
Post by :FI:Igor » Fri Sep 06, 2019 6:56 am
I use a four lane road to verify my alignment. Right lane slight drift to the right, left lane, slight drift to the left.
2015 Ural Patrol (Светлана)
2006 HD Low Rider (sold)
pbrowne
Post by pbrowne » Fri Sep 06, 2019 9:22 am
I guess that this is part of learning to live with a Ural! I had a 2011 Suzuki Burgman 650 to which I added a Texas sidecar. After much setup trial and error in my learning about sidecars, it was a beautiful handling rig. Automatic, electronic cruise control etc., etc. Great except that the tranny constantly leaked and I finally sold it in 2016.
Post by Desantnik-VDV » Fri Sep 06, 2019 4:19 pm
It is normal.
If it was a symmetric trike it would've been tracing straight with totally different dynamics. With the current asymmetry and where the sidecar wheel is located (wheel lead), with any different load (Driver, Passenger, etc.), sidecar weight....there will always be major difference in pulling and pushing forces involved. Every given aspect will change the dynamics of the outfit even on flat road with no crown.
The rest is just history.
