Any problems with 2019 Ural's
solo1966
Post by solo1966 » Fri Jul 12, 2019 12:41 pm
Looking at getting a new 2019 Gearup. Have there been any problems with them.
:foilhead: Love my GOD,country,and fear my government,2017 GU , 2019 GU
grayghost
Re: Any problems with 2019 Ural's
Post by grayghost » Fri Jul 12, 2019 2:07 pm
They're too fast
2019 CT
2012 Gear Up Suchka-no longer mine
2002 Indian Scout
Post by gobium » Fri Jul 12, 2019 2:24 pm
Stand by the UralGuy just bought one.
Post by RC20 » Fri Jul 12, 2019 2:51 pm
I have 2000 miles on my cT so far. I had one MIL show up and part was replaced (never could find out what it was (annoying story), suspect O sensor)
As near as I could tell there was no affect on mileage.
Oil use is very low. Fuel Injection is pretty much as promised (I have a burble at idle once in a while for a short time but it clears up fast). Any throttle and zero issues.
MPG has been low of 33 with the cruddy Washington State gas (high octane but has Ethanol) Otherwise its been a solid 36 with decent gas on average and a high of 40 mpg (runs of 36-38 on low octane which is all I will use and sometimes can get in the long open runs of AK)
Low fuel light is reliable.
Gearbox is on par with the R80GS we had. Solid so far.
I have been over the machine on the fasteners, worst was the steering damper had loose bolt on one end and the bracket on the steering head had its two fasteners loose. I ran 800 miles before I found the bracket ones (I did a go over the first day I had it but it was 95 and I didn't have a bucket to sit on)
There were a few that were not as tight as they should have been but not loose, definitely a must to go over anything you can reach.
Post by Albuquralque » Fri Jul 12, 2019 4:11 pm
They're too fast
Blue 2014 still the fastest....... :D
Post by RC20 » Fri Jul 12, 2019 11:04 pm
Ok, we need to get drag track times.
I will see what it cost to run a quarter mile up North.
atlasheating
Post by atlasheating » Sat Jul 13, 2019 10:14 am
I would think the 2019 with about 5 HP increase in power and a CT with 5% lower gearing (due to tire size) would be pretty fast (realitively)
Post by INSUBORDINATOR » Sat Jul 13, 2019 11:48 am
I'd be unhappy without interchangeable drum brake wheels, Needing a dealer for some repairs - but mostly the insurmountable problem of PAYING what they cost. Not only can I not afford - I don't think they are WORTH IT. Buying used is much more cost effective.
Just because it's a 2019 you are NOT escaping OLD technology - just paying more for it - & making harder to repair.
just my $.02
Post by RC20 » Sat Jul 13, 2019 12:59 pm
OP asked if anyone with a 2019 had problems, not your opinion on the machine.
I suggest you just can it.
Post by chaos2 » Sat Jul 13, 2019 1:07 pm
We need a Grumpy Old Man forum :lol: :lol:
treeman1942
Post by treeman1942 » Sat Jul 13, 2019 1:24 pm
I now have almost 1700 miles on my 2019 Gear-Up, zero issues other than my fairing is still on backorder, and has been for almost 3 months. No buyers remorse! In fact, I'm about to head out on an afternoon ride with my favorite companion, Pugsley.
2019 Ural Gear Up, OD Green
2014 Burgman 400/A
2008 Piaggio MP3250
Whizzer Motorbike
Will Rogers
cateyetech
Post by cateyetech » Sat Jul 13, 2019 1:25 pm
X2 :lol:
:foilhead:
Charlie ╭∩╮(-_-)╭∩╮
2003 Gear-Up Ромашка Мзй
2000 Patrol Teh Урал
rehab circus
Post by rehab circus » Sat Jul 13, 2019 1:33 pm
I have 1600 city stop and go miles on my 2019 cT. Trouble free except for a few loose fasteners and a MIL that turned out to be a pair of 02 sensor codes. This tripped after riding about 2 miles after the bike had been thoroughly soaked in a downpour.
It doesn't use oil, pulls up hills like a champ, and overall feels much more solid and peppy than my 11 patrol in every way.
As far as I'm aware there are no surprise issues specific to the 19s.
edit: forgot to mention that the neutral light has been 100% reliable and accurate. I'm not sure if they changed something or I just got lucky.
:cheers:
Eric
2019 OD Green cT.
Burt1713
Post by Burt1713 » Sat Jul 13, 2019 1:54 pm
We did, I believe it was called the “Soap Box” :lol: :twisted: :lol: :twisted:
2017 cT "Woody Moose"
Post by Mr Wazzock » Sat Jul 13, 2019 2:28 pm
Just a note, I pretty much consistently get about 40 mpg (US) this is with the "old" Electrojet system so IMO 36 is "too low" - however they're not broken in properly until a few thousand km. Start to noticeably loosen up at about 2,500 km. And so on ...
