New Ural pulls to right, tried everything, now what?
I'd like to ride the bike back to the dealer, but it's a handful with pulling to the right. I'm out of things to check. Can't find a trailer wide enough and may have to schedule a roll-back if I can't figure out something.
Here's what I've tried:
1. Checked sidecar driveshaft. U-joints were 90 deg. out of phase. Corrected this. Still no mitigation of pulling to right.
2. Tried many alignment changes -- up to 1 1/2" toe-in and 3 deg. lean-out. Settled on 1 deg lean-out and 5/8" toe-in. None of these changes had any effect on the pull to the right.
3. Found a problem with the sidecar brake dragging. Reservoir was overfilled, and I removed some fluid. Master cylinder was not retracting (broken spring?) an bled fluid and pushed pads off the sidecar rotor. Disconnected linkage.
Shepherdstown, WV USA
2018 Ural GearUp "Arwen'
Re: New Ural pulls to right, tried everything, now what?
Low air pressure in sidecar tire???
f-38, r-40, s/c-35
If I had those issues, the last place I'd take is back to the dealer who obviously couldn't set the bike up correctly.
- Kaliram
Brake linkage rod at the master cylinder must have 1mm of free play, or else the brake pressure won’t be relieved when the brakes are released!
2012 Ural Gear Up ("Tootles")
- Mr Wazzock
- Contact:
IMO too high, F-28, R-38 - 40, S/C-28 (I like 26 if no passenger)
- Mr Wazzock
- Contact:
PS: to be sure you could try taking the sidecar caliper completely off to eliminate it entirely.
- Desantnik-VDV
Are your front and rear wheels in straight line alignment?
Is your engine synced?
2007 GearUp NOS
The rest is just a History:
2014 Ural M70
2002 Ural Barberian Classic
2003 Honda Shadow ACE
2007 GearUp NOS
2014 Ural M70
No. The front of the rear wheel points 3/16" to the right measured against a straightedge along the front and rear tires.
There seems to no way to correct the rear wheel misalignment. I think that this misalignment causes the bike to pull to the right.
- Kaliram
No, the pusher wheel slightly out of line doesn’t cause the pull to the right. Many bikes made have this, including my 2016 GU. Many folks adjust the toe-in with the aligning bar snug against just the rear wheel, rather than against both front and rear wheel. And the toe-in that is needed can be a lot more than 1/2”. I’ve seen ones with 1 1/2”! Adjust it to what works.
And make sure that rod that activates the brake master cylinder has 1-2 mm of play in it, or else the brake fluid won’t be released back into the brake reservoir and the brakes will just lock up. (I’ve had it happen!)
- Kaliram
Note: if you set the toe-in at 5/8” measured with the rod against both front and rear wheels, your actual toe-in, measuring with the rod against the Inside of the rear wheel and dangling a good half inch off the front wheel, will be minus 1/8” !!!
My 2019 GU has always pulled slightly to the right. However, yesterday, I raised the sidecar tire pressure from 32 to 36 and it seemed to drive much straighter. Also, I now have 1100 miles on the rig and it drives much straighter and runs smoother than when new.
2019 Ural Gear Up, OD Green
2014 Burgman 400/A
2008 Piaggio MP3250
Whizzer Motorbike
Will Rogers
2014 Burgman 400/A
2008 Piaggio MP3250
Whizzer Motorbike
Will Rogers
From waaaay out in left field: You don’t by any chance have 2WD engaged?
A couple of weeks ago, I moved the 2 WD lever while greasing my GU, then forgot to disengage it. Wow, what a bad ride for about 3 miles before realizing what was wrong!
2014 Burgman 400/A
2008 Piaggio MP3250
Whizzer Motorbike
Will Rogers
2014 Burgman 400/A
2008 Piaggio MP3250
Whizzer Motorbike
Will Rogers
