2019 MIL (check engine light) stays on
Re: 2019 MIL (check engine light) stays on
Post by RC20 » Sat Sep 14, 2019 10:57 pm
I had the same issue and it was hard telling what did what.
Initially it looked like a sensor and that got replaced (I was not up on the code readout and it was done during the serice as they did gert a readout ala I was long ways from home and service needed doing anywya)
then it came back and went away only to come back. Cycling the system did nothing for eliciting a blink code.,
It would occur reliable on a fill up (always a longer run) and then go away after running a while.
Then after the last one I tried to duplicate by overfill and it did not come back and has not recurred since.,
Go figure and there may be some oddities to the system.
sbaker
Post by sbaker » Mon Sep 30, 2019 10:39 pm
the Mil light will probably go off in a few days.. I had a big back-fire on my 2019... (too much fuel after trying to kick start) The Mil light came, probably the extra 02 in the system caused the O2 sensor to trip. After about 3 days of riding around it went off. Meanwhile, I re-attaceed the compliance fitting (the rubber tube between the Throttle Body and the Air Feed) It was dislodged during the back fire. Bike runs fine. 3K service coming in a week or so, I'll check the valves and do the other stuff.. These are TOUGH birds...
NOTE: The error code will still be IN memory, but the light will go off on the display....... Ride on!
Post by Lofty » Tue Oct 01, 2019 2:59 pm
I re-attached the compliance fitting (the rubber tube between the Throttle Body and the Air Feed) It was dislodged during the back fire.
Perhaps you meant to refer to the branch tubes? They are the large hoses that provide a physical connection between the air filter housing and the individual throttle bodies.
The compliance fittings are small flanges that are installed between the throttle body and the cylinder head.
https://www.uralne.com/intake-flange-set/
Post by RC20 » Tue Oct 01, 2019 5:11 pm
You need to get more info in your profile! (grin)
Let me know if you need directions, its a bit lost in the setup.
Where you are at (city and state is fine, no phone number or address) and what machine you have.
Post by Mr Wazzock » Tue Oct 01, 2019 5:38 pm
AndyH wrote:
Fri May 03, 2019 4:25 pm
sean0262 wrote:
Thu May 02, 2019 1:58 am
I have disconnected the battery for several hours to reset the ECU. Still the MIL light remains on.
Is this a thing for the 2019 model? All the other EFI models ECU's are disconnected when you switch the ignition off, they are not live and do not require power to maintain memory (a bit like a flash drive).
Only just seen this. Actually they are constantly live via Fuse #1. (Or some part of them is.)
Geno89074
Post by Geno89074 » Mon Oct 07, 2019 1:08 am
can obd wiz pro and the appropriate cable shut off or clear a mil/cel on this model??
2014 Ural Patrol
AndyH
Post by AndyH » Sun Oct 13, 2019 2:21 am
Looks that way doesn't it - if that is the case then there is no need to disconnect the battery - just pull fuse 1 which could be fuse 6 if the box is upside down depending on which one you have.
Be interesting to see if there is 12Vdc at G4 on the ECU connector or if there is a requirement to have generator output live?
2015 Ural EU Tourist -
Post by Mr Wazzock » Mon Oct 14, 2019 4:54 pm
Sorry don't understand the last bit. Generator output is permanently connected to battery so is always live?
Or are you talking about a fuse or link in the battery negative lead? (Which I don't have, and I'm not sure that any EFI bikes do.)
But yes pulling fuse #1 should do it. I disconnected mine once (actually the battery, at the ignition switch plug) but there wasn't anything different afterwards as a result.
Fuse #2 is 10A (blue?) so that's a way of telling which way up the fusebox is. Mine is #1 at the top. (it's beside the steering head.)
Post by GHGoodwin » Thu Oct 17, 2019 7:20 am
Don't trust the wiring diagram. I've seen fuse boxes right side up and mostly upside down in relation to the diagram. Check by wire color only.
FWIW - On my '14 the coils have constant power also.
Post by Mr Wazzock » Thu Oct 17, 2019 1:16 pm
That is not uninteresting! Image
Bigflash1
Post by Bigflash1 » Thu Oct 24, 2019 7:48 pm
Heindle has a good video on utube now explaining exactly how to clear the engine light on a 2019. The reason for the random clearing is probably the three cycles with 10 seconds or more of off time between. Catch the video and get the exact steps.
2018 Gear up
Dallas, GA (Just outside of ATL)
