Dead 2018 GU
Re: Dead 2018 GU
Post by Mr Wazzock » Sat Apr 06, 2019 1:34 pm
Certainly! Or in other words, give the battery an easier time. I've modified mine by adding an extra switch so I can turn the headlight off for the same reason. I could see this causing possible aggro at winter time.
Re: Dead 2018 GU
Post by Lofty » Sat Apr 06, 2019 1:37 pm
Zuurg wrote:
Sat Apr 06, 2019 1:23 pm
I wonder if that’s to give the starter maximum juice.
Yes.
My Kawasaki Versys had the same feature. Dual incandescent headlights on that one, coupled with a comparatively small[ish] battery. The cut-out function was appreciated.
Like the superlative Mr. Wazz, I too added a low beam cut function (to my carbureted Suzuki). Depending on one's circumstances at the time, it could mean the difference between riding home, or walking.
Re: Dead 2018 GU
Post by Mr Wazzock » Sat Apr 06, 2019 2:12 pm
Zuurg
Re: Dead 2018 GU
Post by Zuurg » Mon Apr 08, 2019 9:47 pm
Dying when I start it again, but not all the time. I used it this morning to get to work, then go to lunch and back, then home after work, then to a store 5 mins away, then home again.
Tried taking it to go get dinner with my wife, same thing as the other day after an afternoon of riding: it would start, hit around 1100 rpm right away, then slowly die. Tried it again, same result. Gave up trying.
Is it possible that it’s only having a hard time staying running when the engine is hot? If so, what would be a likely cause of that? I checked the oil, it’s at the right level and still clear.
Re: Dead 2018 GU
Post by Mr Wazzock » Tue Apr 09, 2019 2:38 pm
Long shot - check sensor connectors - temp sensors, O2 sensors, and particularly the timing sensor connector, it's top right of the bell housing. Pull plugs off, squirt of switch cleaner, and replace. Could be it's getting a bad or intermittent timing signal. Won't run without one. Dodgy temp readngs could mean fuel mixture is all over the shop. ECU's think it's cold while it's actually hot or vice versa. Just guessing tho.
Zuurg
Re: Dead 2018 GU
Post by Zuurg » Tue Apr 09, 2019 2:55 pm
Thanks. Is there a picture or something I can check that has all of those labeled? So far it’s running fine again today.
simmonsk133
Re: Dead 2018 GU
Post by simmonsk133 » Sat Jun 15, 2019 11:25 pm
My 2011 GU did that when hot. It was the ignition coil. Same thing happened to me years ago with a Suzuki.
6 months ago my battery died going down hill into the biggest intersection in town. Cussing and banging on it got me another mile in 3 tries. Both issues can be a real pain. Coils and HES can be temperature related. Good luck....
2011 Ural Gear up.
SgtFear85
Re: Dead 2018 GU
Post by SgtFear85 » Thu Aug 29, 2019 2:10 pm
I saw a post on a recall for the ignition switch on the 2018 GU. Could be the issue???
Re: Dead 2018 GU
Post by windmill » Thu Aug 29, 2019 4:38 pm
Thu Apr 04, 2019 8:16 pm
Perhaps a faulty fuel cap is creating a vacuum.
Are the OEM fuel caps vented? I never checked. I've been using a non-vented aftermarket gas cap for years without issue.
Not sure, but they don't need to be. The over flow in the fill neck is a vent.
Re: Dead 2018 GU
Post by Pterodactyl » Fri Aug 30, 2019 8:11 am
I just started having a problem with my 2018 GU cutting off while riding. My dealer, Raceway, immediately diagnosed it as the ignition and has a switch in the mail to me.
After taking several readings I’m surprised to find my mind is fairly sound..... Willie Nelson, Me and Paul
