Keeping your bike clean
Zuurg
Post by Zuurg » Wed May 09, 2018 11:01 pm
Hello! Any tips on keeping your bike clean?
Thanks,
Anthony
Re: Keeping your bike clean
Post by windmill » Thu May 10, 2018 12:52 am
Zuurg wrote:Hello! Any tips on keeping your bike clean?
Thanks,
Anthony
S100 cycle cleaner, powerful cleaner that won't discolor paint or aluminum.
S100 corrosion protection, excellent corrosion protection that's virtually invisible for visible areas.
S100 engine brightener, makes faded or discolored painted high temperature, anodized, plastic, and rubber items look like new. also protects from corrosion, and makes subsequent cleaning easier.
Boeshield, excellent, durable corrosion protection for problem areas such as seams, weldments, frame gussets, undersides of fenders, and electrical connectors.
On the other end of the spectrum, if significant exposure to salt or mud for an extended period is expected, WD-40 sprayed on and allowed to dry, and repeated as needed can be helpful. It will soon look horrible, but will clean off, and it protects everything.
Lee Pape
Post by Lee Pape » Thu May 10, 2018 9:36 am
When you seem to spend most of your riding time on roads like this, cleaning is a waste of time.
Post by Mr Wazzock » Thu May 10, 2018 10:45 am
I have found no substitute for bucket of warm water car shampoo or equiv (hair shampoo is good) and a w@$# mitt and sponge, have now added a wheel cleaning brush, last year bought a pressure washer, supposed to be a good make, wouldn’t look at the dirt never mind shift it, even with the plug-in car w@$# bottle of soapy stuff, conclusion, no substitute for physical contact wiping/ sponging.
Post by hotflash44 » Thu May 10, 2018 11:20 am
Lee Pape wrote:When you seem to spend most of your riding time on roads like this, cleaning is a waste of time.
the second picture reminds me of the country directions of go down the road a spell until you see the old oak tree then turn right, seems everyone has made right turns around that tree! :boogie: :boogie:
Post by hotflash44 » Thu May 10, 2018 11:22 am
Thanks,
Anthony
do like i do only ride in good weather stay off all dirty roads and keep it in the garage, only down side is no fun! :boogie: :(
Ironhand
Post by Ironhand » Thu May 10, 2018 3:48 pm
[/quote]
do like i do only ride in good weather stay off all dirty roads and keep it in the garage, only down side is no fun! :boogie: :([/quote]
There's one in every crowd :lol: . I am a big fan of simple green and blasting on the car w@$# suds with one of these https://www.chemicalguys.com/Torq_Foam_ ... gJayfD_BwE
2015 Ural Gear Up
2012 Yamaha Super Tenere
2008 Honda XR650L
2003 Yamaha FZ1
Post by RC20 » Thu May 10, 2018 7:16 pm
I agree with the S100. It works good. Good soap and brush needed at times and get the worst off as well.
Anyone have a view on the all black power train vs the "natural" one for being easier to keep clean?
100k estimated cycle driving:
Mechanic/Technician/Engineer: Switchgear/ Generators/Fire Pumps/Computer Controlled Building Systems
Post by windmill » Thu May 10, 2018 8:19 pm
RC20 wrote:I agree with the S100. It works good. Good soap and brush needed at times and get the worst off as well.
It's-a-w@$#......
Having both, My experience is there isn't any real difference. Both will take some effort to keep looking fresh, neither will stay perfect. The one advantage the black has is there's spray on products that will make it look virtually new, where as it takes "elbow grease" to get the same results on an unpainted engine. Elbow grease can be applied at ones pleasure. Spray on products require first w@$#ing and letting it dry thoroughly, then spray on and let it dry thoroughly.
I'd say get what you prefer.
Post by windmill » Thu May 10, 2018 8:27 pm
Ironhand wrote: I am a big fan of simple green
Simple green did a number on the gloss black bits on my Patrol, the frame is dull and hazy. It also stripped the w@* off everything else.
It may be ok for flat and satin finishes, but it doesn't seem to be a good match for gloss finishes.
YMMV as Ural has used different paints over the years.
Ironhand
Post by Ironhand » Fri May 11, 2018 8:52 am
Hmm. I've been using it for years with no damage to paint. It will strip w@*, though as you'd expect being a powerful degreaser.
2015 Ural Gear Up
2008 Honda XR650L
2003 Yamaha FZ1
Post by hotflash44 » Fri May 11, 2018 9:39 am
Mr Wazzock wrote:I have found no substitute for bucket of warm water car shampoo or equiv (hair shampoo is good) and a w@$# mitt and sponge, have now added a wheel cleaning brush, last year bought a pressure washer, supposed to be a good make, wouldn’t look at the dirt never mind shift it, even with the plug-in car w@$# bottle of soapy stuff, conclusion, no substitute for physical contact wiping/ sponging.
Hi Mr Waz, my biggest cleaning area is always the spokes and rims,never found a good easy way to clean them other than pulling up a stool and do one at a time with that little wipe needed around the rim where the spoke goes in. if you have any method to make this job easier please let me know. :cheers:
Post by RC20 » Fri May 11, 2018 6:32 pm
Thank you. If I am tracking right is listed as $1000 so not worth it. I have to manage the purchase for he best price vs need.
SidecarDan
Post by SidecarDan » Fri May 11, 2018 9:59 pm
We're supposed to clean them? :boogie: :lol:
Dan
2012 Forest Fog Gear-Up
128/42 jets
7/64ths drilled slides
2013 branch pipes
Yamaha petcock
Post by windmill » Fri May 11, 2018 10:00 pm
I would say its "worth" is defined by the desire to have it, so if cost is a consideration, and you're indifferent, you should feel free to pass on it based on practical reasons.
I really like the look with OD green, it was in my budget, and its my primary transportation in place of a car, so it was worth it to me.
