Rear brake caliper mounting threads stripped
Gwtg
Post by Gwtg » Fri May 04, 2018 8:01 am
I managed to strip the the threads to the mounting socket on the rear caliper. Is this a replaceable part or can I install an insert? I can’t find the actual model number to find Brembo parts.
Thanks, Greg
2014 Ural Patrol
heindlengineeringural
Re: Rear brake caliper mounting threads stripped
Post by heindlengineeringural » Fri May 04, 2018 8:53 am
The Mounting bracket for the rear caliper is Ural part. We keep them in stock. Cost is around $50.00
Heindl Engineering, LLC
Ural Dealer in Southwest Ohio
(937) 787-3686
www.heindlengineering.com
sales@heindlengineering.com
Gwtg
Post by Gwtg » Fri May 04, 2018 9:01 am
Thanks, after I had some coffee and thought about it I realized the threads were on the mounting bracket and not the caliper. I might just install an insert since I might have it.
Thanks, Greg
2014 Ural Patrol
Post by Mr Wazzock » Fri May 04, 2018 11:52 am
Another victim :( - Tomcatfixer has already been thru all this - the bolts are too short so you only get about 3 turns, and that's it, it's not enough and won't take any too rough tightening up. I do mine up just "that much" with just one hand on the Allen key, and thread lock. No extra leverage!
Post by hotflash44 » Fri May 04, 2018 2:20 pm
Mr Wazzock wrote:Another victim :( - Tomcatfixer has already been thru all this - the bolts are too short so you only get about 3 turns, and that's it, it's not enough and won't take any too rough tightening up. I do mine up just "that much" with just one hand on the Allen key, and thread lock. No extra leverage!
Mr Waz you are great at remembering stuff, i did also ,TCF is a treasure trove of info, he is a been there done that Uralista for sure. seems that IMZWA could use his bike as a east coast test platform, like Windmill does on the left coast. :wink:
Gwtg
Post by Gwtg » Fri May 04, 2018 7:19 pm
The bolts are 11mm right? Because that is the size my kit does not have.
Thanks, Greg
2014 Ural Patrol
Post by windmill » Fri May 04, 2018 9:56 pm
Gwtg wrote:The bolts are 11mm right? Because that is the size my kit does not have.
The Caliper to mount bolts? They are 3/8" SAE, and there should be an allen key that size in your tool kit. The adjuster nut is 5/8".
Post by Tomcatfixer » Fri May 04, 2018 11:16 pm
You can read about my rear brake caliper mounting issues here: http://www.sovietsteeds.com/forums/view ... 23&t=48315
Virginia Beach, Virginia, USA
:FI:Igor
Post by :FI:Igor » Sat May 05, 2018 7:10 am
Striped mine a few months ago. Easy to over torque. Get replacement plate and slide/bolts; they're reasonably priced from Gene or Heindl.
2015 Ural Patrol (Светлана)
2006 HD Low Rider (sold)
Post by Mr Wazzock » Sat May 05, 2018 11:58 am
windmill wrote:The adjuster nut is 5/8".
16mm spanner also fits.
Post by Mr Wazzock » Sat May 05, 2018 12:03 pm
hotflash44 wrote:Mr Waz you are great at remembering stuff,
I can remember things like that but not where I put something down 10 minutes ago or what I ate for lunch yesterday :o
(Ack-shirley it was cucumber sandwiches + fries :D )
Post by hotflash44 » Sat May 05, 2018 4:05 pm
now your talking, :hungry: :thumbsup: cucumber and tomato with mayo and salt and pepper is my favorite sandwich of the garden type.
Post by Mr Wazzock » Sun May 06, 2018 11:58 am
Will have to try that!
Gwtg
Post by Gwtg » Sun May 06, 2018 12:54 pm
5/8 mounting? I don’t think we are talking about the same thing. I’m looking to save $50 if I safely can. If thread inserts are good enough for Chad then they should be safe. He must have put them to the test at the CRAP this weekend.
Thanks, Greg
2014 Ural Patrol
Gwtg
Post by Gwtg » Sun May 06, 2018 2:54 pm
I just read TCF’s thread and it answered all my questions. The engineering solution is above my pay grade (I do my best but try to recognize my limitations) so I am ordering a new plate from Heindl since they were astute enough to answer this thread and take Mr Wazzock’s advice and tighten it with an Allen wrench, Blue loctite and perhaps a little nail polish mark on the bolt/cylinder to keep an eye on it. Thanks everyone who chimes in.
Thanks, Greg
2014 Ural Patrol
