Dragging back brake
Mikey
Dragging back brake
Post by Mikey » Mon Apr 30, 2018 8:59 pm
How is it best to lubricate back brake foot lever? Parking brake activates fine. But I have to pull up the foot pedal by hand or it holds the brakes on.
Happened suddenly mid ride.
2017 Gear-up Forest fog
Trumpetwasher
Re: Dragging back brake
Post by Trumpetwasher » Mon Apr 30, 2018 9:21 pm
Broken return spring
Black Power Train
3.89 Final Drive
Reverse Hand Shift
Sidecar Power Panel
Handlebar Power Outlet
Deluxe Seating
Sidecar Side Panels
Armrests
Double-Spring Saddle
Santamaria Foot Rest
Custom Nose Art
Dnepr Leg Shields
XMT-MOTO Hand Guards
All LED lights.
Mikey
Post by Mikey » Mon Apr 30, 2018 9:37 pm
Nope that's attached.
Post by wooden nickel » Mon Apr 30, 2018 9:39 pm
I usually have to disassemble it, clean it up and re-lube the shaft. I think Tomcatfixer put a grease fitting on his.
SidecarDan
Post by SidecarDan » Mon Apr 30, 2018 9:55 pm
Every couple of years I have to remove the brake pedal and lube the shaft it pivots on. This year I'm actually going to install a zirk fitting so I can grease it that way, as it will be much easier to do.
The shaft isn't sealed and gets lots of crud on it which makes the brake pedal bind.
Dan
2012 Forest Fog Gear-Up
128/42 jets
7/64ths drilled slides
2013 branch pipes
Yamaha petcock
Mikey
Post by Mikey » Mon Apr 30, 2018 10:42 pm
Ok, got it off and yah. Just....yah.
So I'm going to sand it and lube. What's best to lube it? And is retrofitting a zerk as easy as drilling and tapping thread? Or so you need channels? Or will the grease just wick it's way around?
Post by windmill » Mon Apr 30, 2018 11:01 pm
Mikey wrote:Ok, got it off and yah. Just....yah.
So I'm going to send it and lube. What's best to lube it?
Grease......whatever ya got will do.
Post by wooden nickel » Tue May 01, 2018 6:48 am
Some have drilled and tapped the shaft. I was thinking of putting a 10-32 zerk in the tube. If I do install a zerk, I will probably grind a shallow spiral channel on the shaft too. Since procrastination is my favorite occupation, I will probably wait until it drags again.
Post by Mr Wazzock » Tue May 01, 2018 9:03 am
As said pivot shaft seizes up. Occasional bit of oil dribbled into each end or I’ve also got an aerosol grease.
Post by Mr Wazzock » Tue May 01, 2018 9:04 am
PS don’t forget also sidecar lever pivot.
Post by Lokiboy » Tue May 01, 2018 11:04 am
Tomcatfixer installed a zerk fitting. Do a search, should be easy to find.
80,000 km and counting
Mikey
Post by Mikey » Tue May 01, 2018 12:29 pm
Mr Wazzock wrote:PS don’t forget also sidecar lever pivot.
Don't forget to grease? Yah, it's on there quite loosely I found. Worth lubricating. I can't believe it started to seize within 2k kms
Post by windmill » Tue May 01, 2018 12:46 pm
Mikey wrote: I can't believe it started to seize within 2k kms
Mr Wazzock wrote: Occasional bit of oil dribbled into each end or I’ve also got an aerosol grease.
The pedal on my 07 patrol started dragging rather early too, but rather than adding a zerk, I just give it a little oil on a fairly regular basis, and it's been fine since. lubing it with oil was on my short list of things to do when I brought home my M70.
A zerk is probably Ideal as it's neater, but it's not a necessity, if one makes it part of their regular maintenence.
Post by Tomcatfixer » Fri May 04, 2018 11:28 pm
The first time I experienced the dragging brake pedal:
http://www.sovietsteeds.com/forums/view ... 23&t=47126
Where I solved the problem:
http://www.sovietsteeds.com/forums/sear ... sf=msgonly
Virginia Beach, Virginia, USA
Post by GHGoodwin » Sat May 05, 2018 6:48 am
I think Van was the originator of the grease fitting adaptation. If I remember correctly his first attempt was to put one on the outer tube and then later he used the shaft itself. I filled mine up marine grease and just apply oil to the exposed ends regularly. I havent had to break the pedal down for a couple of years. That said I admit to being a bit of a "fair weather " rider mostly due to arthritis, artificial joints and a growing case of DAS (discomfort avoidance syndrome).
