Low cylinder temp.
Low cylinder temp.
Post by Speedbump » Mon Apr 30, 2018 8:35 am
I have noticed that my RH exhaust had blued more and faster then the LH om my 2015 Retro, now with 15,000km on the odo. I finally installed a CHT gauge and confirmed the LH cylinder takes longer to "warm up" , but will eventually got to the same temp. I started the bike the other day and waited until the RH side got to ~100 deg. then shut her down. While the RH rocker cover was hot to the touch, the LH was not. Drove 3 miles and the CHT said both cylinders were at about the same temp of ~250 deg. No recent loss of power or anything else to indicate a problem. Thoughts?
Glen³
Yeah, I got something on the side.
1977 GS550
1979 XS750
Re: Low cylinder temp.
Post by windmill » Mon Apr 30, 2018 9:33 am
No CHT on my M70, but pipe color and when hooked up to OBD2 tool indicate a similar disparity. On my 07 Patrol an ID thermometer would also show the same.
I could speculate why, but don't really have a irrefutable explanation and never sought one, many others have observed the same. Just seems to be the nature of the beast.
Post by Mr Wazzock » Mon Apr 30, 2018 12:27 pm
Suspect throttles out of balance, best check/sort this out ASAP else real risk of RH side doing most or all of the work and over stressing itself. (As my dealer would put it, the LH side "is just along for the ride" :D )
Post by Speedbump » Mon Apr 30, 2018 5:11 pm
Thanks for the input guys. I just did a 10 mile ride and after she warmed up the temps were the same. Guess I have something to work on at CRAP.
Glen³
1977 GS550
1979 XS750
Post by hotflash44 » Mon Apr 30, 2018 6:19 pm
Speedbump wrote:I have noticed that my RH exhaust had blued more and faster then the LH om my 2015 Retro, now with 15,000km on the odo. I finally installed a CHT gauge and confirmed the LH cylinder takes longer to "warm up" , but will eventually got to the same temp. I started the bike the other day and waited until the RH side got to ~100 deg. then shut her down. While the RH rocker cover was hot to the touch, the LH was not. Drove 3 miles and the CHT said both cylinders were at about the same temp of ~250 deg. No recent loss of power or anything else to indicate a problem. Thoughts?
think the left almost is always slightly cooler than the right, maybe because the side car blocks some of the wind. my CHT almost always shows a 3 to 5 deg hotter right side. as to the blue not sure. driving 3 miles and temp okay, don't think i would worry,IMHO. ps wouldn't hurt to have it looked, at just to make sure. :cheers:
Post by Tomcatfixer » Mon Apr 30, 2018 7:28 pm
Normally, at speed, the right cylinder is the cooler one, due to the hack directing additional cooling air over the jug. At idle, they should have identical temperatures, unless the direction the crank spins throws cooling oil more effectively on one cylinder over the other. It's probably just as Mike suggests: out of balance throttle bodies.
Virginia Beach, Virginia, USA
2015 Ural cT "Mobile Chernobyl", 1999 Ural Tourist "Desert DisGrace: the Iron (Oxide) Curtain", 1994 Honda VFR750F, 1986 Yamaha FZX700S Fazer
Donbmw
Post by Donbmw » Mon Apr 30, 2018 7:31 pm
CHT temps for the most part will not be the same for each cylinder.
Don
Post by hotflash44 » Mon Apr 30, 2018 8:52 pm
Donbmw wrote:CHT temps for the most part will not be the same for each cylinder.
agree my 2016 temps rarely are the same usually 5 to 7 degrees apart and i love the way it runs,great power no hesitation good torque. :cheers:
124c41plus
Post by 124c41plus » Tue May 01, 2018 3:32 pm
Right cylinder always runs warmer.
2016 Ural Ambassador
Orlando, Florida
Post by Tomcatfixer » Tue May 01, 2018 3:36 pm
...maybe on YOUR Ural, but not on ALL Urals.
Eric N
Post by Eric N » Tue May 01, 2018 7:51 pm
When's the last time you checked your valves? Right exhaust tighter than left?
2018 Gear Up
2013 Retro Solo
2001 Patrol - Sold
Post by Speedbump » Wed May 02, 2018 6:57 am
Adjusted valves 4 days ago. Once the bike is warmed up all temps are good. Will try to balance the TB's today.
Glen³
1977 GS550
1979 XS750
