Noob Question - Nacelle Wiring Access?
msamsen
Post by msamsen » Sat Apr 14, 2018 7:47 am
What is the easiest way to get to the dash wiring underneath the headlight nacelle?
Thanks!
(Moving things around just a bit. Adding a Fuzeblock for additional electrical accessories.)
Sent from my iPhone using Tapatalk
About to purchase 2018 GU (the Happy Camel) for a year-long Pan American trip with my wife
2017 KTM 350 EXC-F (Cougar)
2014 BMW F800GS (Goat)
Re: Noob Question - Nacelle Wiring Access?
Post by Albuquralque » Sat Apr 14, 2018 8:51 am
The pic is of the sidecar, but you are asking about wiring behind the headlight. If you truly need to get to the wiring behind the headlight, it is held on by two bolts on either side of it. Remove the bolts and pull out the headlight.
Post by Lmo » Sat Apr 14, 2018 10:06 am
... you are asking about wiring behind the headlight.
Or are you asking about the auxiliary "head light" nacelle on the sidecar? Me thinks...
Post by Mr Wazzock » Sat Apr 14, 2018 3:50 pm
He said dash wiring.
For me = take headlight shell off / out.
You have to mark it else lose beam height setting.
Camel Jockey
Post by Camel Jockey » Sat Apr 14, 2018 5:31 pm
Albuquralque wrote:The pic is of the sidecar, but you are asking about wiring behind the headlight. If you truly need to get to the wiring behind the headlight, it is held on by two bolts on either side of it. Remove the bolts and pull out the headlight.
Thanks!
Sorry about the confusing picture...but, I’m running wires from the bike dash into the sidecar. So yes, I did mean the main headlight.
Mike S.
Stamford, CT
Current Rides
- 2018 Gear Up (the Happy Camel)
- 2017 KTM 350 EXC-F (the Cougar)
- 2014 BMW F800GS (the Goat)
Prior Rides
- 2016 DRZ 400S (the Wheeezel)
- 2013 BMW R1200RT (the Mule)
- 2011 HD Road King (Our Hog)
- 2009 HD Sportster (Li’l Hog)
