HELP! Re: EFI - Where should I be looking please?
scottmastrocinque
Post by scottmastrocinque » Mon Apr 09, 2018 11:38 pm
Hi Everybody,
I have my new 2017 Gear Up and I will be doing her first break-in service soon.
Unbelievably, Ural provides NO INFORMATION WHATSOEVER for syncing the EFI. :shock:
I can work with EFI on BMW, Ducati, Piaggio, Vespa, Moto Guzzi, and many others, but this Ural EFI seems to be the worst best kept secret I've ever seen and especially since dealers are few and far between. Really Ural? Really?
I have spent days searching this forum and I cannot find a simple answer to how to balance EFI on my new 2017 Gear Up. I've a garage full of motorcycles with EFI and tools, and I am also a very competent mechanic, but this is insane. I cannot believe how vague everybody is and how much conflicting information there is and how old a great deal of the information is. Do I build a tool, and if so, which way, or do I drill vacuum ports on the EFI bodies and do it the old fashioned way, or do I just shoot myself and get it over with... Arrggg... WWID?!?
Can anyone please clarify this issue and point me to the thread that can help me? I'll take any help at this point as I am so flustered with the 23 pages of conflicting information I've found so far.
I would really appreciate some assistance! Thank you. :bow:
- Scott
- Scott -
2017 Ural Gear Up Sahara - "Ekaterina - a.k.a. Katya - The Farkle Queen"
2012 Moto Guzzi Stelvio NTX - "Stella"
1997 Moto Guzzi V-10 Centauro - "Clelia"
2007 Piaggio X9 500 Evolution - "Chiara"
Noli pati a scelestis opprimi. :cheers:
Re: HELP! Re: EFI - Where should I be looking please?
Post by windmill » Tue Apr 10, 2018 12:14 am
Here's the mother of all EFI service threads. There's quite a bit of chaff, but has everything one needs. Hardest part is making the OBD2 tool adapter cable, and even that is darn easy.
I was a total EFi noob, and figured it out no problem, should be a snap for anybody with experience.
http://www.sovietsteeds.com/forums/view ... hp?t=47343
scottmastrocinque
Post by scottmastrocinque » Tue Apr 10, 2018 12:17 am
Thanks! I thought that was the one but it's a bit of a mess. I guess there is no other way than to wade through it!
Do you know if all EFI's are the same for Ural including the connectors being the same for all years of Ural EFI?
Thank s again!
Scott
- Scott -
Post by windmill » Tue Apr 10, 2018 12:21 am
scottmastrocinque wrote:Thanks! I thought that was the one but it's a bit of a mess. I guess there is no other way than to wade through it!
Thank s again!
Scott
Yes, a lot of chaff but even that was educational for me.
No, the 2017 and later are different,
This is what you need to convert a generic cable to fit your Ural,
http://www.newark.com/te-connectivity-a ... pd-mi-acce
scottmastrocinque
Post by scottmastrocinque » Tue Apr 10, 2018 12:24 am
So this is what I was talking about that's confusing to me. So, I don't need the Molex Connectors, I need these instead?
- Scott -
Post by windmill » Tue Apr 10, 2018 12:31 am
scottmastrocinque wrote:So this is what I was talking about that's confusing to me. So, I don't need the Molex Connectors, I need these instead?
Yes, that's correct, they changed to a waterproof round 4 pin connector.
Newark shows the pins on back order, here's another source,
https://www.onlinecomponents.com/te-con ... E834A7E1cs
or
http://www.te.com/usa-en/product-929974 ... gnId=13262
scottmastrocinque
Post by scottmastrocinque » Tue Apr 10, 2018 12:40 am
Barry I really appreciate this but do you know any other suppliers?
The first place has a 1000 piece minimum order for $223 worth of pins!
And the second place is 50 minimum for $23 !
- Scott -
Post by windmill » Tue Apr 10, 2018 12:53 am
scottmastrocinque wrote:Barry I really appreciate this but do you know any other suppliers?
Oops,, my bad. :(
https://www.digikey.com/product-detail/ ... ND/7320187
https://www.digikey.com/product-detail/ ... ND/2054424
https://www.digikey.com/product-detail/ ... ND/2054567
scottmastrocinque
Post by scottmastrocinque » Tue Apr 10, 2018 12:56 am
Nah, it was my bad. I'm tired and it's late here and I should be asleep. I searched the OEM part numbers and found a supplier with everything (all 3 parts) that sells individual and ships for about 6 bucks. Thanks so much!
- Scott -
scottmastrocinque
Post by scottmastrocinque » Tue Apr 10, 2018 1:21 am
Ok! I've ordered all the parts necessary to craft the cables. I will order the OBD Pro upgrade after I receive the basic cable and software. Hopefully, this will go smooth! Thanks you again Barry! Much appreciated! :bow: :cheers:
- Scott -
Post by windmill » Tue Apr 10, 2018 2:08 am
scottmastrocinque wrote:Ok! I've ordered all the parts necessary to craft the cables. I will order the OBD Pro upgrade after I receive the basic cable and software. Hopefully, this will go smooth! Thanks you again Barry! Much appreciated! :bow: :cheers:
No problem, I'm recouping from hernia surgery, it's a pleasant respite from my inactivity.
If you run into any technical issues with hardware or software, Albuquralque, Tomcatfixer, and Burt1713 should be able to set you straight.
scottmastrocinque
Post by scottmastrocinque » Tue Apr 10, 2018 3:54 am
Ouch! Well, here's to your speedy recovery! :cheers: :beerchug:
- Scott -
Post by Albuquralque » Tue Apr 10, 2018 4:09 am
scottmastrocinque wrote:Hi Everybody,
- Scott
Post by Mr Wazzock » Tue Apr 10, 2018 12:46 pm
Maybe I shouldn't confuse the issue further, but it did occur to me that, providing you know which of the 4 wires do what, there's nothing to stop you wiring up your own preferred style of connector.
124c41plus
Post by 124c41plus » Mon Apr 16, 2018 1:00 pm
I'm seriously considering drilling the vacuum ports in my throttle bodies because all we're doing is adjusting the stops on the butterfly valves to let in the right amount of air on one cylinder vs the other.
2016 Ural Ambassador
Orlando, Florida
