Hayes Brake Service Kit Now Available
Post by Tomcatfixer » Wed Feb 28, 2018 3:39 pm
After multiple calls to Hayes Brake to inquire about purchasing replacement caliper slides...
...I received a 'phone call from R&D guy Nik Hays at IMWA.
Nik was pleased to inform me that IMWA and Hayes have put together a new service kit for the Hayes caliper that includes new stainless steel slides, slide seals, mounting bolts with pre-applied threadlocker, circlips, and lube.
The part number and nomenclature are IMZ-8.1040-27032 - Service Kit for Rear Brake Caliper
This kit is already available in Redmond and can be ordered via your favorite dealer. He obviously couldn't quote a firm price because each dealer will have their own markup, but said that the kit should cost around $60.
Virginia Beach, Virginia, USA
Re: Hayes Brake Service Kit Now Available
Post by wooden nickel » Wed Feb 28, 2018 4:24 pm
Great to know. Thanks for the research Chad. I've been in some salt and will probably need to upgrade to stainless steel.
Post by GHGoodwin » Wed Feb 28, 2018 4:57 pm
It's the o-ring seals that cause the problem. The caliper rotates a bit against/on the sliders every time you brake and the o-rings take the beating. Eventually they flatten out and start to leak. I replace mine every spring.
The size is 2.7 x 16.9. Material should be Buna-n rubber with 70A duro hardness.
Post by Speedbump » Wed Feb 28, 2018 6:00 pm
Thanks for the enlightenment Chad. I will add this to my list of stuff to ask for when I am in Redmond next week.
Glen³
Yeah, I got something on the side.
1977 GS550
1979 XS750
Post by Tomcatfixer » Wed Feb 28, 2018 6:07 pm
Nik said that they had 50 kits built-up. My dealer ordered two (one for me and one for the shelf), looks like Nick's gonna order one. If you nab one, there'll be "only" 46 left. :wink:
Trevorski
Post by Trevorski » Fri Mar 02, 2018 10:46 pm
Nice! I wonder if Viton o-rings might hold up longer than regular buna o-rings?
1976 Kawasaki KE125
Trevorski
Post by Trevorski » Fri Mar 02, 2018 10:47 pm
Have they addressed the issue that some have noted about the relative length of the sleeves vs threaded portion of the bolt that left too little engaged thread?
1976 Kawasaki KE125
Post by Tomcatfixer » Sat Mar 03, 2018 6:18 am
I asked Nik about this, since it was such an issue for me (http://www.sovietsteeds.com/forums/view ... it=Threads), and he said that he wasn't aware of the issue. The nee stainless steel sleeves are the same length as their predecessors. I'll have to show him the forum thread above and see if he'll take a look at how much 'bite' he's actually getting on his slide pin threads.
Post by Albuquralque » Sat Mar 03, 2018 9:30 am
I've solved all those issues............. :D
Post by Tomcatfixer » Sat Mar 03, 2018 9:41 am
Albuquralque logic...
Post by Albuquralque » Sat Mar 03, 2018 1:25 pm
That philosophy works in so many other areas of life as well!!!!!!..................... :D
Post by gobium » Sat Mar 03, 2018 1:39 pm
Dont park on hill side if you got no P brake
Post by Albuquralque » Sat Mar 03, 2018 1:44 pm
gobium wrote:Dont park on hill side if you got no P brake
You can always park sideways on a hill side!....... :D
Post by windmill » Sat Mar 03, 2018 11:45 pm
I find I'm having to adjust the parking brake every 8 to 10 riding days. While not ideal I don't see why one would be frustrated to the point of not using or removing it.
Perhaps having the P brake lever immediately at hand on the bar is the difference? I find its simplicity of use and convenience still far outweighs the task of keeping it adjusted or the alternatives.
IMO,
The only 2 viable choices are a simple self adjusting system, or using it as is.
Post by Tomcatfixer » Sun Mar 04, 2018 6:27 am
It just got to the point that every time I NEEDED to use the parking brake, it was out of adjustment. It was frustrating. I got tired of the additional time and effort required. Please keep in mind, I ride the Mobile Chernobyl EVERY day. It's a lot of pad wear and a lot of parking brake adjusting. After a while, I just stopped adjusting it, then stopped using it entirely (I mean, Virginia Beach IS at sea level and quite flat). I intend to move to a more mountainous area in a few years, and I can see how helpful having a functional parking brake would be more of a benefit there.
