Carry a spare fuel injector?
Camel Jockey
Post by Camel Jockey » Thu Feb 08, 2018 6:41 pm
I am preparing for a year long trip through Central and Soith America. While I know that decent fuel is generally available, it’s certainly possible that we'll pick up some contaminated stuff. In addition to a pre-filter on the gas tank inlet, and spare fuel filters, I’m wondering if it makes sense to carry a spare injector (or two.)
What is the wisdom of the forum?
Mike S.
Stamford, CT
2018 GU; 2017 350 EXC-F; 2014 F800GS
Re: Carry a spare fuel injector?
Post by wooden nickel » Thu Feb 08, 2018 8:14 pm
I think they are side specific. Kinda pricey for two. On a long trip, I would worry more about kicking and breaking the fuel inlet. I don't know if it is available separately or not. Definitely carry extra filters.
Post by Albuquralque » Thu Feb 08, 2018 8:59 pm
Fuel injectors are not side specific. I carry a spare.
Here is something else you want to carry, you will need one for the right side and one for the left side:
Item 26 & 27. They are the little plastic fuel inlet elbows that transition the fuel line to the injector. I've seen people break these off either while riding or getting on/off their bike. If one breaks you are stuck until you have a replacement.
Left Side - IMZ-8.1040-15331
Right Side - IMZ-8.1040-15332
Post by Albuquralque » Thu Feb 08, 2018 9:01 pm
Also, before you start your trip, you will want to go through the air filter system and the fuel system and replace all the one-time-use clamps with hose clamps (but don't use just regular hose clamps.)
For the fuel system, on the pressurized side, you need to use 1/2" fuel injector clamps (found at your local auto parts store).
For the large hose clamps on the airbox hoses and on the compliance fitting, get these:
https://www.caphardwaresupply.com/colle ... 4345024259
You will need the 40-60mm sized clamps, 6-each of these.
Camel Jockey
Post by Camel Jockey » Thu Feb 08, 2018 9:28 pm
Albuquralque wrote:Fuel injectors are not side specific. I carry a spare.
Thanks!
Mike S.
Stamford, CT
Post by wooden nickel » Thu Feb 08, 2018 9:41 pm
It is clear that I can't remember what I have heard. I need to keep my yap shut until I am sure or at least surer. With my memory getting worse each year I may be mute by next week.
Post by Mr Wazzock » Fri Feb 09, 2018 9:14 am
Another one is the cyl. head temp sensor connector, found myself kicking that a few times.
Post by gobium » Fri Feb 09, 2018 9:36 am
L or R ural injector
Post by hotflash44 » Fri Feb 09, 2018 10:02 am
Camel Jockey,while your per-pairing for your trip check out our member Fran, and his wife they are already doing what you want to do . they are currently in Mexico heading south.Frans wife also has a blog of their trip with lots of commentary/pictures. :cheers:
Post by gobium » Fri Feb 09, 2018 10:14 am
BTW.
You dont need to carry two plastic elbows (26&27)
What you need is gobium universal elbow adapter!
Post by gobium » Fri Feb 09, 2018 10:16 am
Howdy CJ
When you are down in S. America tell Ural Guy we said hello.
Subsnowden
Post by Subsnowden » Fri Feb 09, 2018 3:53 pm
Camel Jockey wrote:I am preparing for a year long trip through Central and Soith America. While I know that decent fuel is generally available, it’s certainly possible that we'll pick up some contaminated stuff. In addition to a pre-filter on the gas tank inlet, and spare fuel filters, I’m wondering if it makes sense to carry a spare injector (or two.)
I want to do the same thing too!! You can pick up the fuel hats from uralne.com. I just picked up a couple myself. I have been thinking about the spare injector as well but those things have a pretty low failure rate in general so as long as you carry plenty of filters then the injector should stay fine..should...
When are you thinking of starting your journey?
Jon
Nomad
2015 Ural Gear Up
Camel Jockey
Post by Camel Jockey » Fri Feb 09, 2018 10:33 pm
Planning to leave spring of 2019. Just bought the 2028 GU today.
Mike S.
Stamford, CT
Post by chaos2 » Fri Feb 09, 2018 11:02 pm
hmmm, Delorean might work better than a gu
Post by eastbloc » Fri Feb 09, 2018 11:33 pm
For the record, I successfully JB Welded a broken injector elbow and rode that way for a few hundred miles.
I didn't need to -- I bought a spare -- but I wanted to see if it was possible, and it is.
'02 Patrol
'09 BMW F800GS
