Lost Power
Basset1
Lost Power
Post by Basset1 » Fri Dec 22, 2017 9:28 am
Just got my new to me, used 2015 ct, road it to the Harley shop to show off reverse to my old riding buds. On the way home it started to lose power, could hardly make it up small hills, in 3rd and 4th the mil light would come on. After I got home I let it sit for few hours, rode it for 15 min and it was fine, any thoughts what might be going on.
Re: Lost power
Post by Albuquralque » Fri Dec 22, 2017 10:10 am
Was it running on only one cylinder? Any more info you can share on what was happening?
Basset1
Re: Lost power
Post by Basset1 » Fri Dec 22, 2017 11:15 am
No, both cylinders seemed fine, was if something was dragging it down, like driving with the parking brake on, it wasn’t
Re: Lost power
Post by Albuquralque » Fri Dec 22, 2017 11:56 am
A couple of things. You could look into your rear brake for two things.
1. Make sure the rear brake parking brake cam is adjusted correctly. If it isn't, then it could cause the rear brake to drag a little. The more you ride the pads will heat up and expand (happened to me once when I first bought mine)
2. Make sure of the position of your right foot when riding. It is very easy for your right foot to rest on the clevis for the sidecar brake linkage. Doing this will also engage the rear brake and possibly cause the same as above.
However, if your MIL light was coming on then it does seem like it wouldn't be a brake problem. You can go through the manual and get the blink codes to tell you why the MIL light was coming on.
Re: Lost power
Post by rivers » Fri Dec 22, 2017 12:23 pm
Albuquralque wrote: if your MIL light was coming on then it does seem like it wouldn't be a brake problem. You can go through the manual and get the blink codes to tell you why the MIL light was coming on.
That's where I would start. Blink test described in your owners manual. Might be and ign/computer component heating up and misbehaving.
PS: this "forums tech support" subforum is for forum glitches. Try posting in the "order of the greasy wrench"/2014 and later section. You'll likely get more response.
Re: Lost power
Post by Mr Wazzock » Fri Dec 22, 2017 12:39 pm
Yes get any error codes; with the ignition on, engine not running, toggle the kill switch off & on 6 times. (off/on/off/on/off/on.) Altho might only work if the MIL is lit up. But codes should be stored and can be read via a OBD cable.
Re: Lost Power
Post by hotflash44 » Fri Dec 22, 2017 3:45 pm
Basset1,at least you made it out of your Harley buddies sight, before it took a sh#$. that would be embarrassing for sure! :boogie: :boogie:
Burt1713
Re: Lost Power
Post by Burt1713 » Sat Dec 23, 2017 12:27 pm
Have you checked the vent line on the gas tank? Also checking the fuel filter and strainer might by a good idea.
2017 cT "Woody Moose"
BlueRockCrawler
Re: Lost Power
Post by BlueRockCrawler » Wed Dec 27, 2017 9:46 am
Check the spark plug wires, the coil end is suspect.
2015 Ural Patrol
1993 Suzuki DR 650
2018 Suzuki DR 650
previous Honda's were
1996 750 Magna
2002 750 shadow A.C.E.
2004 919
1985 500 Magna
Subsnowden
Re: Lost Power
Post by Subsnowden » Fri Jan 19, 2018 12:13 pm
Any updates?
Jon
Nomad
2015 Ural Gear Up
Re: Lost Power
Post by hotflash44 » Fri Jan 19, 2018 12:46 pm
Subsnowden +1 :puzzled: :thumbsup: :thumbsup:
Re: Lost Power
Post by Mr Wazzock » Fri Jan 19, 2018 6:36 pm
+2! :o
