How to make a 2017 tachometer functional.
Burt1713
Post by Burt1713 » Mon Sep 04, 2017 11:18 am
First of all this is what I did to make my tachometer function, it works on my bike but proceed at your own risk.
The first thing I did was disconnect the tachometer wire from the ECU feed wire.
The tachometer input wire is yellow on the gauge side of the connector.
I then connected the yellow tachometer input wire to the left coil grey with white stripe primary wire.
At this point the tachometer will function, but will read half of the actual RPM. To correct this you will need to turn the key on, but not start the bike. With the key on Press and hold both the mode and reset buttons on the speedometer for 2 seconds. This will bring up the 12/24 hour setting for the clock. Press mode multiple times until the LCD screen reads "RPM SP1r1P" you will need to change this with the reset button to read "RPM SP2r1P' as shown in the picture below.
At this point turn the key off and you are done.
2017 cT "Woody Moose"
2002 Ural solo bobber (work in progress) “Symphony of Destruction”
Re: How to make a 2017 tachometer functional.
Post by Birdy » Mon Sep 04, 2017 12:05 pm
Great, bookmarked! I'll do this next weekend, eating it's a nasty habit because I have to work to support it.
2017 Ural Patrol
shieldsy67
Post by shieldsy67 » Wed Sep 06, 2017 8:04 am
Fantastic ! Thanks Burt [emoji1303]
Sent from my iPhone using Tapatalk
violation
Post by violation » Thu Sep 14, 2017 8:36 pm
will try this soon. thanks so much!
Post by Peter Pan » Thu Sep 14, 2017 9:27 pm
Do I understand you right, that now you have a rev meter on the efi rigs, where the km total used to be on our old Babutschkas?
Sophie Travelair
Patrol 2013 a Jim Petitti special.(RIP)
8 weeks 12.000km Oregon - Alaska - Oregon, now in CR 39.000km and counting.
With a DIY foam air filter the rig runs well even in tropical rain. The air box looks then like an aquarium. :moto:
Final drives: 1. at 5000km, 2. at 34.000km(+friction plates)
Burt1713
Post by Burt1713 » Thu Sep 14, 2017 9:47 pm
Peter Pan wrote:Do I understand you right, that now you have a rev meter on the efi rigs, where the km total used to be on our old Babutschkas?
It has the standard odometer
Two trip odometers
A clock
Voltmeter
And a tachometer among other things
You just have to keep pressing a mode button to cycle through them all
Post by Birdy » Thu Sep 14, 2017 9:50 pm
Yeah, keep pressing the button...about 25 times :D
2017 Ural Patrol
Post by Mr Wazzock » Fri Sep 15, 2017 6:08 pm
Kudos. :bow:
Mikey
Post by Mikey » Thu Oct 19, 2017 10:33 am
How difficult was this for those who did it? Do you need to cycle to get to rpm at each start up?
2017 Gear-up Forest fog
Burt1713
Post by Burt1713 » Thu Oct 19, 2017 9:49 pm
The speedometer stays at the display it was on when the key was turned off.
Mikey
Post by Mikey » Sun Oct 22, 2017 7:17 pm
Burt1713 wrote:The speedometer stays at the display it was on when the key was turned off.
Good to know. Thanks
outrider
Post by outrider » Tue Oct 24, 2017 6:38 pm
Mine worked when I picked up my 2017 without this mod.
2017 Gear Up
Member Mensa
Marital Art Instructor
Burt1713
Post by Burt1713 » Tue Oct 24, 2017 7:28 pm
outrider wrote:My teach worked when I picked up my 2017 without this mod.
Maybe Ural has fixed this issue. When did you get your bike?
outrider
Post by outrider » Tue Oct 24, 2017 8:03 pm
Two weeks ago.
2017 Gear Up
Member Mensa
Burt1713
Post by Burt1713 » Tue Oct 24, 2017 9:54 pm
Two weeks ago.
If you don't mind me asking what dealer did you get your bike from?
