Header bolt size
Gwtg
Header bolt size
Post by Gwtg » Mon Apr 03, 2017 2:54 pm
Does anyone have the specs for the exhaust header bolt? One of mine went missing.
Thanks, Greg
2014 Ural Patrol
Re: Header bolt size
Post by Tomcatfixer » Mon Apr 03, 2017 3:04 pm
I've got an uninstalled one at home for my cT. I'll get you a picture, thread pitch, and length tonight.
Or you could just order one from a dealer. They're not overly pricey.
Virginia Beach, Virginia, USA
Post by Tomcatfixer » Mon Apr 03, 2017 4:08 pm
Looks like it's an M8 X 32mm stud with a 1.25 thread pitch.
Hope this helps.
Buckhorn
Post by Buckhorn » Mon Apr 03, 2017 4:13 pm
Holopaw.com has them for $1.99
2013 Ural Gear Up Gobi camo
Dimple drain plugs
Shorty left side directionals
2010 Harley Fat Boy
Gwtg
Post by Gwtg » Tue Apr 04, 2017 1:56 pm
Isn't that 32.76mm to be exact? :) Thank you gentlemen. I have ordered one and a spare.
Thanks, Greg
2014 Ural Patrol
Gwtg
Post by Gwtg » Mon Apr 10, 2017 7:58 pm
Received and installed the header bolt and nut. Decided to torque my other bolts and proceeded to snap my rear pinch bolt. Would you know the size bolt that is? Surprisingly there is no list of load bearing bolts on the forum.
Thanks, Greg
2014 Ural Patrol
Post by Tomcatfixer » Mon Apr 10, 2017 8:06 pm
To be clear, are you referring to the rear axle pinch bolt?
Gwtg
Post by Gwtg » Mon Apr 10, 2017 8:14 pm
Yes.
Thanks, Greg
2014 Ural Patrol
URAL CT
Post by URAL CT » Mon Apr 10, 2017 8:27 pm
You referring to sumptin' like this?
Neat chart but I wouldn't hold my breath tightening Ural fasteners to these specifications. I tried on one of the FD studs, I didn't even get close to the spec & I felt the stud pulling out. I stopped immediately...no harm done. AFAIK! As we say here at SS, "gudentite" is gudnuff. :mrgreen:
CT
2007 Patrol
Plano, TX
Gwtg
Post by Gwtg » Mon Apr 10, 2017 9:53 pm
No there is a list of bolt sizes for non load bering fasteners to replace them w/ SS http://www.sovietsteeds.com/forums/view ... 11&t=31605
No list for all the important bolts.
Thanks, Greg
2014 Ural Patrol
Gwtg
Post by Gwtg » Wed Apr 12, 2017 9:04 pm
First bolt for the Important Bolt List.
M10-1.5 40mm - rear axle pinch bolt
Thanks, Greg
2014 Ural Patrol
Razor
Post by Razor » Thu Apr 13, 2017 12:07 am
Gwtg wrote:First bolt for the Important Bolt List.
M10-1.5 50mm - rear axle pinch bolt
I nominate Gwtg to complete the "Important Bolt List" for the benefit of the SS Collective. thesquarewheelis did a fabulous job putting together a list of non-load bearing fasteners back in 2013 but apparently nobody has taken up the task of the "important bolts" yet. Clearly this is needed and as Gwtg has made a start I think it only fitting that he continue on and reap the just rewards when the task is done. Can I get a second? :D
Chris
2015 Gear-Up in Forest Fog, "Betty the Beast"
Several previous Harley's
Post by Tomcatfixer » Thu Apr 13, 2017 6:04 am
Too late; I've already done it. Well, at least I've measured all of the bolts (except the two that hold the sidecar frame to the bike frame) during my 1999 RPOC disassembly ( viewtopic.php?f=10&t=47611 ). I'm​ in the process of sourcing them online (as was mentioned, some of the Russian diameter/pitch combinations are not readily available) to complete the list, but I suppose I could just publish the measurements.
Razor
Post by Razor » Fri Apr 14, 2017 12:59 pm
:thumbsup: :cheers:
Chris
Gwtg
Post by Gwtg » Mon Apr 17, 2017 4:56 pm
Gimme the measurements and I'll put them in an Excel sheet and source what I can.
Thanks, Greg
2014 Ural Patrol
