Connected to ECU's and Balanced Throttle Bodies!!!!!!!
pbrowne
Re: Connected to ECU's and Balanced Throttle Bodies!!!!!!!
Post by pbrowne » Tue Jun 18, 2019 10:14 am
I flipped right past that page! Duh!
Shepherdstown, WV USA
2018 Ural GearUp "Arwen'
AndyH
Post by AndyH » Sat Jun 22, 2019 6:54 pm
Sun Jun 16, 2019 8:15 am
... but if you look on Page 5 of this thread, you will see the 2014-2016 six-pin MOLEX connector (a diagram of which is on Page 1) AND the 4-pin cannon-plug style connector used on 2017 and newer Urals to obtain OBD-II diagnostic information.
Might be time to sort this thread out into a shorter guide that sets out the steps for OBDWiz, the Connectors and how it works and split questions off to another thread? (and yes I know just how painful that would be as an admin, but I think the topic warrants the attention)
2015 Ural EU Tourist -
Post by Tomcatfixer » Sat Jun 22, 2019 7:43 pm
Not a bad idea. Might have to confer with my associates on how to effectively accomplish this. 🤔
Post by Mr Wazzock » Sun Jun 23, 2019 8:58 am
+1
pbrowne
Post by pbrowne » Mon Jun 24, 2019 10:59 pm
I cannot get my OBDLink SX to work. I'm sure now after several checks that the pins are right. I made up the adapter cable and I have 12.3 v on pin 16 and the grounds show 0 ohms resistance at the female plug before connecting the OBDLink SX cable from my PC. Same values at the bike round OBD plug. The OBDLink SX cable LED stays yellow when connected and the OBSWiz software can't communicate with the bike.
I checked the OBDLink SX cable on my VW Tiguan and OBDWiz connected just fine and the cable's LED was green.
I could make up a new adapter cable, but I'm afraid that the result would be the same.
I'm at a bit of a loss as to what to try next.
pbrowne
Post by pbrowne » Tue Jun 25, 2019 9:39 am
I'm starting over! Ordered new cable & plug parts. I suspect that there's some sort of issue with the original cable.
pbrowne
Post by pbrowne » Tue Jul 02, 2019 7:56 am
I finally got my cable to work.
First, I had been overthinking the problem of making up the adapter cable with the female plug. What is pictured and labelled "chassis plug" in the instructions is actually the female plug (same as OBD2 plug in a car) at the end of the adapter cable that you must make. I had the connections reversed.
Second, I found a broken wire in the adapter cable that I had made. Be sure to check continuity of connections if you encounter a connectivity issue. I had done so, but the wire broke after that, probably when I first plugged in the round plug.
SgtFear85
Post by SgtFear85 » Fri Aug 02, 2019 4:00 pm
Thanks for all the great work! Totally appreciated!
Post by Mr Wazzock » Sat Aug 03, 2019 1:05 pm
Finally tried connecting mine up, and eventually managed to make it work.
I'm using OBD Fusion on iPhone, and this: ("OBD II Wi-Fi Interface")
It's linked to 'phone as Wi-Fi, and for OBD Fusion as "OBDLink MX Wi-Fi"
At first I kept getting "Not Connected". Eventually I realised I had to tap the "Connect" word at bottom of the screen! Image
Then there was the hiatus of finding which "Device" setting works. (OBDLink MX Wi-Fi)
There was a lot of connecting and chundering going on, then it reckoned it was ready, and sure nuff it seemed to have downloaded a page of diagnostics (mostly, no error codes).
The vacuum max. scaling is too low so I found out (eventually) how to change it - touch and hold finger on the dial picture and the properties window appears. So upped it somewhat.
Anyhoo at the moment I've merely established that the idle is 900 rpm and the throttles are equal.
BlueRockCrawler
Post by BlueRockCrawler » Wed Aug 07, 2019 10:57 am
Mr Wazzock, Try the app "Torque"
2015 Ural Patrol
1993 Suzuki DR 650
2018 Suzuki DR 650
previous Honda's were
1996 750 Magna
2002 750 shadow A.C.E.
2004 919
1985 500 Magna
kkarl528
Post by kkarl528 » Thu Sep 12, 2019 8:56 pm
Does anyone know if the OBD2 cable used for the 2018 work on the 2019s?
AndyH
Post by AndyH » Fri Sep 13, 2019 5:38 pm
The OBDII cable is used to balance the throttle bodies and the new Kehin's have vacuum ports so OBDII has become a bit redundant. Fault code finding with OBDII is very hit and miss and only points you in the general direction of the fault area, as the displayed codes do not correspond.
Based on that my guess is no?
Post by Mr Wazzock » Fri Sep 13, 2019 9:41 pm
I might hazard a wild guess that since the Keihin system is completely diifferent then so is the connector and the pinouts. The Electrojet set-up went thru two different OBD port connector configurations.
scottmastrocinque
Post by scottmastrocinque » Sat Nov 09, 2019 10:05 pm
Thanks to this forum and information, I crafted the cable for my 2017 Gear Up today.
Nevermind that I ordered the parts over 1 year ago, and had them sitting in the closet for the longest time. :shock: I figured that I needed it for the next service I intend to do tomorrow.
I took my time, use some old fashioned extrapolation of the technique in the video and made the changes, in my mind, for the 2017 connector differences.
Worked like a charm the first use! I'm thrilled.
I even tried my hand at programming some custom user screens, and I like the program. I bought the TouchScan, + Professional Add-on, from the obdsoftware.net site. I have a Dell touchscreen Windows X laptop specifically for all of my other motorcycle ECU software.
So my heartfelt thanks to the original author of this information! My gratitude for a job well done Sir!
2017 Ural Gear Up Sahara
2012 Moto Guzzi Stelvio NTX
2008 Moto Guzzi 1200 Sport
2008 Piaggio MP3 400ie
1997 Moto Guzzi V10 Centauro
scottmastrocinque
Post by scottmastrocinque » Sat Nov 09, 2019 10:17 pm
I do have one question that I haven't found the answer for yet.
In my PID definitions, there are both Metric and English units. On the layouts I designed, they defaulted to the English units. How do you switch it to the metric display, so for example, you can see pressure in kPa versus psi? Is there a quick toggle or keystroke to do this? I search the help database but found nothing.
Thanks in advance!
UPDATE: Found it. It's under the GENERAL tab in the software. :D
