Fuse Box - Fuse Assignment
Yakatak
Post by Yakatak » Thu Feb 11, 2016 6:10 pm
The main fuse box layout on my 2014 bears no resemblance to the owners manual pics or the wiring diagram. Wondering if anyone else had this condition and if anyone could supply a better guess as to fuse assignments. I REALLY don't want to remove my fairing to get in there. I'm trying to trace a key-off battery drain (11 mA)....and nope...it's not the tach sender.
Jon in SC
2014 Ural Gear Up - Asphalt
Wanderrad
Re: Fuse Box - Fuse Assignment
Post by Wanderrad » Thu Feb 11, 2016 6:32 pm
I thought that the last time I looked at mine it was 180 deg out from the owners manual. I will look when I'm out in the garage tinkering in a bit if someone else doesn't answer first.
Scot
-Scot
Wanderrad
Post by Wanderrad » Thu Feb 11, 2016 9:48 pm
I just verified the fuse assignments on mine. In fuse box #1 (bike) they are inverted compared to the manual (180 deg out). Also, the ones listed in the manual as 20 amp are 15 amp on the bike.
Hope that helps. Scot
-Scot
Yakatak
Post by Yakatak » Thu Feb 11, 2016 10:29 pm
Thanks Scot. That's what I have too. Saved me a lot of time. :cheers:
Wanderrad
Post by Wanderrad » Fri Feb 12, 2016 6:16 am
-Scot
Post by GHGoodwin » Fri Feb 12, 2016 8:35 am
Upside down and wrong fuses were easy. Just wait until you try and follow the wire color codes. GAH!
Marco
Post by Marco » Mon Sep 16, 2019 4:59 pm
I have all 15 amp fuses throughout. Fuses by left fork and fuses for sidecar outlet and light are all 15's. Is that typical? I have the manual but can't seem to match it up.
2012 Gear Up "Rhonda (help me) Anichka"
19,000 Km
"My mother never breast fed me, she told me she only liked me as a friend."
Rodney Dangerfield
AndyH
Post by AndyH » Tue Sep 17, 2019 3:43 pm
And to confuse things further, some earlier 2015's are 180 deg out and the later models are the same as the manual...
2015 Ural EU Tourist -
Post by sKiZo » Tue Sep 17, 2019 5:12 pm
And just to confuse you even more, here's the aux fuse panel on my 2011 ...
(I made it myself so I wouldn't have to dig around under the neck or overload the stock fuses with accessories.
