2014 Ural Parts List
flcruiser2302
Re: 2014 Ural Parts List
Post by flcruiser2302 » Thu Jul 20, 2017 3:06 pm
Albuquralque wrote:Brake Pads
Rear - EBC FA473V (Used on 08/09 Spyder Can Am)
Sidecar - EBC FA266V
Front - EBC FA244HH
Light Bulbs:
Plate and car presence light - Osram 5007 - 1156 base.
Car running light - Osram 7506 - 1156 base.
Car brake/turn - Osram 7528 - 1157 base.
Bike brake/run - Osram 7506 - 1156 base.
Bike turns - no maker on bulb 12V/21W. 1156 base.
Dash - 12V/2W 7mm dia base. Ridges instead of pins. BA7S base.
Air Filters:
K&N 33-2022
Spectre HPR3916
AC Delco A974C
Buick 25095333
Fram CA3916
Motorcraft FA1085
Napa 6139
Purolator A33590
Spectre HPR3916
Ural 104015075
WIX 46139
Oil Filters:
Mann W 75/3
Napa Gold 7207
Fram PH6017A
Fram PH10959
Fleetguard HF7615
Baldwin B307
Carquest 84207
Wix 57207
Bosch 3300
Napa 1358
Napa Gold 1365
Mobil1 M1-108
Wix 51358
Spark Plugs:
NGK BPR6HS
Speedbleeders:
Front Caliper - SB8125..........M8 x 1.25mm x 27.99mm long
Rear Caliper - SB8125...........M8 x 1.25mm x 27.99mm long
Sidecar Caliper - SB1010S......M10 x 1.0mm x 31.35mm long
Hose clamps for compliance fitting and both sides of branch tubes: https://www.caphardwaresupply.com/colle ... 4345024259
You will need the 40-60mm sized clamps, 6-each of these. Replaces the one-time use pinch clamps.
Hose clamps for fuel lines and brake hoses: Use 1/2" fuel injection hose clamps found at any autoparts store.
Wow, what a ton of work the compilation of this list must have been! I will buy you a beer or 6 if we ever meet. My ridiculous question is this: Does this list serve for 2014 and later, ie as in 2017? Did things sort of stay the same once EFI stage was met or is this list an ever changing thing for each year. Thanks!!
John in Orlando Fl
2017 CT
2-1 exhaust with cats removed, K&N drop in filter installed along with Dobeck EJK set at stock settings.
Post by Albuquralque » Thu Jul 20, 2017 3:12 pm
It should cover 2017 as well.
flcruiser2302
Post by flcruiser2302 » Thu Jul 20, 2017 10:37 pm
Albuquralque wrote:It should cover 2017 as well.
Cheers, that is awesome!
John in Orlando Fl
2017 CT
bikenut
Post by bikenut » Mon Nov 13, 2017 9:53 am
Replacement off the shelf battery?
Fraser
/14 Patrol
/Shovelhead Chopper
Couple of unfinished projects
Post by Albuquralque » Mon Nov 13, 2017 10:14 am
bikenut wrote:Replacement off the shelf battery?
YTX20L-BS
bikenut
Post by bikenut » Mon Nov 13, 2017 10:19 am
YTX20L-BS
Thanks, if I missed it in the thread I appreciate your patience
Fraser
/14 Patrol
/Shovelhead Chopper
Post by hotflash44 » Mon Nov 13, 2017 10:49 am
Albuquralque,Darrell is there a part#/brand of auto store EFI Ural fuel filters? :?: :cheers:
Mikey
Post by Mikey » Mon Nov 13, 2017 11:17 am
Can we make this a sticky and update the first page list with these extras like battery? A one stop list is awesome! I don't mind editing and updating it if Albaquralque doesn't want to or doesn't have time.
2017 Gear-up Forest fog
Post by Albuquralque » Mon Nov 13, 2017 1:12 pm
hotflash44 wrote:Albuquralque,Darrell is there a part#/brand of auto store EFI Ural fuel filters? :?: :cheers:
Updated main list the the Napa Gold 3095. I personally have not tried the Napa fuel filter, but others have. You can also try to cross reference the Napa Gold 3095 to another fuel filter and check them out.
Mikey wrote:Can we make this a sticky and update the first page list with these extras like battery? A one stop list is awesome! I don't mind editing and updating it if Albaquralque doesn't want to or doesn't have time.
I updated the first page with the battery number
Post by hotflash44 » Mon Nov 13, 2017 1:15 pm
thanks Darrell, anyone here tried this EFI fuel filter? :?: :cheers:
Post by Mr Wazzock » Tue Nov 14, 2017 3:20 pm
Just to confuse the issue, mine (2016) has BA9S bulbs in the speedo, 9mm dia. base with pins.
Pretty sure I saw it mentioned elsewhere too. But can't remember where exactly.
Donbmw
Post by Donbmw » Tue Nov 14, 2017 5:45 pm
Add to oil filter a STP SA2808 to the list
Don
Don
Papa mike
Post by Papa mike » Wed Mar 21, 2018 3:02 pm
FYI Bosch 3300 smaller than stock one. Lots of surface exposed. I put it on as it was only one they had. Will change it to correct size asap.
2017 m70, 2002 hd,69 Manx, spec const vw trike. 67, riden sickles since I was 10.
Life is hard, it's harder for those who are on my bad side. :lol:
Post by windmill » Wed Mar 21, 2018 3:07 pm
Papa mike wrote:FYI Bosch 3300 smaller than stock one. Lots of surface exposed. I put it on as it was only one they had. Will change it to correct size asap.
It doesn't matter, it's fine.
