2014 Ural Parts List
sasha_j
Re: 2014 Ural Parts List
Post by sasha_j » Fri Sep 16, 2016 1:45 am
Thanks.
The nipples are a bit larger with the NAPA filter....I dunked the ends in clean gasoline to help the filter mate to the tubing....takes a little english but it goes on and fits the OEM tubing
Sasha J
http://www.laura-n-sasha.com
2014 Ural Gear Up, Sage Green, expertly dialed in by UNIQUE RIDES in Fort Collins, Colorado
Full Time RV'er with late-model wife
sasha_j
Post by sasha_j » Fri Sep 16, 2016 1:48 am
I also found it easier to drain the tank from the fuel filter tubing, pre-fuel pump. Unlike what the Ural manual recommended.
I thought I would have to re-prime the gas tank after the filter swap, but she started right up!
Sasha J
Post by Albuquralque » Fri Sep 16, 2016 11:01 am
sasha_j wrote:I also found it easier to drain the tank from the fuel filter tubing, pre-fuel pump. Unlike what the Ural manual recommended.
No need to drain the tank. Buy a couple of fuel line pliers and you can clamp off the lines on either side of the filter and then change it out
sasha_j
Post by sasha_j » Fri Sep 16, 2016 6:20 pm
yeah, but I wanted to clean the gas tank interior filter too....otherwise, for sure
Sasha J
Griever
Post by Griever » Sun Oct 23, 2016 7:47 am
Speedbleeders:
Front Caliper - SB8125..........M8 x 1.25mm x 27.99mm long
Rear Caliper - SB8125...........M8 x 1.25mm x 27.99mm long
Sidecar Caliper - SB1010S......M10 x 1.0mm x 31.35mm long
Speed bleeders are new to me. Is it just a case of removing the nipple and screwing the speed bleeder in place?
Do they work as well as they claim on the website?
Is it more fun riding or fixing in the garage?
2016 Ural Sportman UK 1 wheel drive
2010 Yamaha xj6
2016 Sinnis Max II
Post by Albuquralque » Sun Oct 23, 2016 9:40 am
Griever wrote:Speedbleeders:
Technically it is that simple, however, you will have to bleed the brakes afterwards.
Post by Mr Wazzock » Fri Feb 24, 2017 7:00 pm
Thanks very much for these lists
Post by Mr Wazzock » Fri Feb 24, 2017 7:36 pm
'English translation':
Light Bulbs
Front Headlamp 'Sidelight': Osram 5007 - R5W, 12V 5W (BA15S base)*
Rear Bike Tail Lamp: Osram 5007 - R5W, 12V 5W (BA15S base)
Rear Bike Stop Lamp: Osram 7506 - P21W, 12V 21W (BA15S base)
Front Sidecar Sidelight: Osram 5007 - R5W, 12V 5W (BA15S base)
Rear Sidecar Stop / Tail Lamp: Osram 7528 - P21/5W 12V dual filament 21 & 5W (BAY15D base)
Turn Indicators: Osram 7506 - P21W, 12V 21W (BA15S base) - 4 off
Dashboard Light (speedometer): 281 2W BA7S 12V 2W (BA7S base) - 2 off
Headlamp 'upgrade': H4 (427) 60/55, 12V 60 & 55W (?)
* if included in headlamp.
EDIT: My mistake tail lamp is like old BMW, separate tail and brake bulbs.
:D
Post by hotflash44 » Mon Mar 27, 2017 4:57 pm
WOW!, didnt expect such a great response to the oil filter Question,i will never pay the high prices again, thanks Darrell your the man!
Post by hotflash44 » Tue Mar 28, 2017 12:53 pm
Sometimes a post will be extra helpful ,this is one of those, thanks Darrell! ,I bookmarked it for future use.
Razor
Post by Razor » Tue Apr 11, 2017 11:49 pm
:thumbsup: Excellent info! Thank you.
Chris
2015 Gear-Up in Forest Fog, "Betty the Beast"
Several previous Harley's
DeltaGolfFoxtrot
Post by DeltaGolfFoxtrot » Mon Apr 17, 2017 6:28 am
sasha_j wrote:Answering my own question here....just did a fuel filter replacement. Hopes this helps someone.
That Napa Gold filter doesn't look gold to me. Lol
Thia is a great thread. Could the original post be updated with all the extra findings?
Don in Coastal Alabama
You only get to ride this ball of mud once so might as well enjoy it to the max.
Post by Tomcatfixer » Mon Apr 17, 2017 7:45 am
Concur. That's why I spray-painted mine black:
Post by Speedbump » Mon Apr 17, 2017 9:41 am
Found this info for fuel filters:
Filter cross refeance for the Napa 3095;
http://www.fuelfilter-crossreference.co ... /NAPA/3095
The AC Delco one from Amazon;
https://www.amazon.com/gp/product/B000C ... =ATVPDKIKX
Only $3.47 each.
Glenn³
Post by Mr Wazzock » Tue Apr 25, 2017 8:47 am
Had mail ordered two off Mann W 75/3, arrived today.
Boxes identical, but one filter is marked 'W 75/3', the other as 'W 7003'.
So W7003 & W75/3 are the same animal! Not sure if this means 75/3 is changing to 7003, but anyway might help with Internet searches etc.
HTH
PS (edit): think I've seen 7003 coming up several times during previous such searches.
