2014 Ural Parts List
barnone
Re: 2014 Ural Parts List
Post by barnone » Thu May 28, 2015 8:52 am
BeemerlessBob wrote:Clutch cable?
Is there any generic clutch cable that will work for a 2014 gear up or do I need a Ural specific cable?
I'm currency stranded near Asheville, NC. Any suggestions as the the quickest place to get a cable?
Where are you stranded?
What is wrong with the cable? Just an end pulled off? An Asheville MC dealer might have these?
Might add one of these to my kit on the Ural.
http://www.amazon.com/gp/product/B008U9 ... UTF8&psc=1
tonered
Post by tonered » Thu May 28, 2015 10:45 am
That's the ticket! Nice.
Have a good one.
tony b
Lynnwood, WA
2013 GearUp (Taildragger)
2001 Duc ST4 (Thumper)
tbump
Post by tbump » Tue Jul 21, 2015 7:54 am
I was just on EBC's web site, they have "no match" for the rear pad # FA473V. any suggestions? Thanks TB
Post by wooden nickel » Tue Jul 21, 2015 9:01 am
That's odd. Amazon says they have 12 sets for $31.30 a set.
keetmanaa
Post by keetmanaa » Mon Sep 28, 2015 9:17 am
Saw this on another site regarding the Napa 1358 and 1365 listed as alternatives for the "stock"oil filter
http://www.triumphrat.net/twins-technic ... ilter.html
Anyone know if our Urals will have the same problem?
2015 Gear Up
2010 Yamaha WR250R
2004 DL650 V Strom
Gwtg
Post by Gwtg » Sat Oct 17, 2015 10:42 pm
I dont know if anyone still cant see the page for the clamps but here it is again. http://www.caphardwaresupply.com/produc ... partial-ss
Thanks, Greg
2014 Ural Patrol
bobblick
Post by bobblick » Tue Mar 08, 2016 7:17 pm
Does this list work with a 2015 Ct ???
Post by Albuquralque » Tue Mar 08, 2016 8:53 pm
bobblick wrote:Does this list work with a 2015 Ct ???
Yes
Big Slim
Post by Big Slim » Wed Mar 16, 2016 8:57 am
Does anyone know of non OEM U-joints for the main drive and the sidecar?
I think they are no different than pre 2014 models but thought it would be good to add to this list.
2014 Gear Up
2016 Indian Scout
"Where The Metal Meets The Meat"
Post by Albuquralque » Wed Mar 16, 2016 10:34 am
Big Slim wrote:Does anyone know of non OEM U-joints for the main drive and the sidecar?
The main driveshaft u-joint is only available through a Ural dealer or from Russia via Ebay.
Sidecar u-joints haven't changed. Here is a link: http://shop.advanceautoparts.com/p/neap ... erm=1-0300
Neapco 1-0300
Big Slim
Post by Big Slim » Wed Mar 16, 2016 2:02 pm
Cool. Thank You.
2014 Gear Up
2016 Indian Scout
Trevorski
2014 ural injector identification numbers
Post by Trevorski » Sat May 07, 2016 2:52 pm
I have the fuel injectors out of my 2014 in connection with drilling the throttle bodies for vac ports for balancing, and installing a Dobeck EJK.
While I have the injectors out, I thought I'd try to take down some of the identifying numbers on them
They have the Bosch 'stylized H inside a circle' symbol, on the main composite body not far from the electrical connection
The main number next to the Bosch symbol is 0280158077 which in some searching I have done on the web is sometimes also shown as 0 280 158 077
There is some information that I am finding on the 'web that preliminarily suggests (though I have not dug around enough to confirm that it's verified/verifiable) that these are used in some GM engines, and, maybe, particularly the relatively recent 5.3L LS4 V8... and that they are within the Bosch EV14 family- apparently 'EV14 Compact' and take an electrical connector called "USCAR" but again, take that with a grain of salt unless and until you can confirm it yourself.
Other numeric details- on the stainless barrel nearer the tip:
80787
13712083032
My bike is a very early 2014 (took delivery beginning of April 2014) so I have no way to know if these same injectors have been used since, although I wouldn't think anything would change radically (although I have read that the '16s have a new throttle body/EFI assembly from ElectroJet, so those might represent a point of change in injector type/size)
Now you can search down uber-high-performance variants of these to squeeze a mighty 0.8 extra horsepower out of your EFI Ural (kidding of course).
Mostly I thought that this might help those who eventually may need new injectors find options at prices less than the north of $100 per injector that I have seen from some sources....
if technology cooperates I am going to attach a couple of excerpted pages from a Bosch document that appears to cover injectors similar to these
Injection Valve EV 14.pdf
1976 Kawasaki KE125
sasha_j
Post by sasha_j » Thu Jun 23, 2016 12:17 pm
tonered wrote:About 2in O.D.? This could be a good match:
http://www.napaonline.com/Catalog/Catal ... 0297051903
Works great in our Ducs as a non-OE part with 3bar pumps and 10,000mi maintenance intervals for the filter. Our pumps do have a prefilter also.
Has anyone tried this fuel filter for hose fit and physical placement fit on the bike? Looks a bit big in the pic...
Anyone have any other suggestions for OEM fuel filter replacement?
Sasha J
http://www.laura-n-sasha.com
2014 Ural Gear Up, Sage Green, expertly dialed in by UNIQUE RIDES in Fort Collins, Colorado
Full Time RV'er with late-model wife
sasha_j
Post by sasha_j » Thu Sep 15, 2016 6:54 pm
Answering my own question here....just did a fuel filter replacement. Hopes this helps someone.
Sasha J
Post by Albuquralque » Thu Sep 15, 2016 7:07 pm
sasha_j wrote:Answering my own question here....just did a fuel filter replacement. Hopes this helps someone.
Half the price of the stock Ural ones! Nice find....:thumbsup:
