2014 Ural Parts List
Re: 2014 Ural Parts List
Post by wooden nickel » Sat Nov 22, 2014 5:44 pm
Vince,
Still working on my first 5000 km yet. Gene does the first service for free and Kenny changed the filter at that time. Like I said, I probably won't order as long as Gene has filters in stock. I like to do most of my own work but I'll buy parts from Gene as much as I can. If I end up trying these, I'll let everyone know.
barnone
Post by barnone » Sat Nov 22, 2014 7:08 pm
wooden nickel wrote:Vince,
Thanks for the info.
I got two of the Bosch D3300 filters from Amazon. They seem to be quite a bit longer than the Mann W 75/3.
tonered
Post by tonered » Mon Apr 13, 2015 3:11 pm
Sorry, but I didn't see this in the posts above or in a search.
A friend is bringing her 2015 beast to my place for service on Thursday and needs to get a fuel filter, or at least have one on hand. Can someone post the part number or an equivalent? I didn't see anything in the 2015 OM either.
Thanks!
Have a good one.
tony b
Lynnwood, WA
2013 GearUp (Taildragger)
2001 Duc ST4 (Thumper)
Post by Albuquralque » Mon Apr 13, 2015 5:25 pm
tonered wrote:Sorry, but I didn't see this in the posts above or in a search.
Thanks!
Have a good one.
Haven't found an equivalent yet. The Ural one is only available through a dealer. The stock ones have no part number markings on them.
tonered
Post by tonered » Mon Apr 13, 2015 5:59 pm
Thanks, Darrell.
I appreciate the help.
We might just forego the filter and simply check the flow and the tank filters. After finding my carbie tank filter almost clogged with paint and bug guts and still nothing on the in-line filter after 20,000km, I think she will be okay for another interval.
It looks similar to a NAPA 3032 filter that is used on my Duc, but possibly longer? I'll see if I can get some measurements. I don't have one on the shelf.
Have a good one.
tony b
Lynnwood, WA
Post by Albuquralque » Mon Apr 13, 2015 6:21 pm
The filter canister part is 2" long. Over all length is 3-3/4".
tonered
Post by tonered » Mon Apr 13, 2015 7:00 pm
About 2in O.D.? This could be a good match:
http://www.napaonline.com/Catalog/Catal ... 0297051903
Works great in our Ducs as a non-OE part with 3bar pumps and 10,000mi maintenance intervals for the filter. Our pumps do have a prefilter also.
Have a good one.
tony b
Lynnwood, WA
Post by Albuquralque » Mon Apr 13, 2015 7:47 pm
That's about 1/3 the cost of one from a dealer. Will definitely use it on my next filter change out.
Post by Albuquralque » Mon Apr 13, 2015 7:51 pm
tonered wrote:About 2in O.D.? This could be a good match:
Have a good one.
The stock Ural one is 1-1/2" OD at the rib in the middle. 1-3/8" OD for the rest of the filter housing part.
2" might be a little big.
tonered
Post by tonered » Mon Apr 13, 2015 8:22 pm
Sorry, but I don't have a EFI bike to look at. But, looking at the pics in the 2015 OM, it does appear that there is enough room for a slightly larger O.D. filter. Or, am I not seeing something there? :cheers:
BTW, if you happen to go this route, the filter does not come with Oetiker clamps. You'll need to buy a couple of the appropriate size. The reusable screw-type, fuel-injection clamps work just fine.
Have a good one.
tony b
Lynnwood, WA
tonered
Post by tonered » Wed Apr 15, 2015 8:29 pm
Just had a look at my friend's 2015. The NAPA filter will work with no problem. We're doing the service tomorrow. The original filter is crazy small, esp for the price, but it would be fine for many KMS.
Have a good one.
tony b
Lynnwood, WA
Re: 2014 Ural Parts List - Air Filter
Post by siberman1 » Tue May 19, 2015 7:57 pm
Here is another Air Filter for 2014:
Microguard 46503 $6.39 (no metal grate on top, is that just "fluff"?)
Trevorski
Location:Adamant, Vermont, USA (yes, it's really a place name)
Post by Trevorski » Tue May 26, 2015 12:00 am
Another fuel filter option, that I've picked up and will be trying on my '14 G.U.- the Golan Super Mini cleanable filter with 10 micron stainless screen. Not cheap but I like the option to be able to clean it and be back in service right away; I picked up an extra screen to be able to change screens and have a clean screen ready to go. Be advised if you buy one to look inside the filter body before you install; I had some problems with ones where someone in the distribution chain of the online vendors I'd bought it through had filched the filter element from the inside (this happened 2x with two separate online vendors) .... it would not have been good if I had installed it with the assumption that it had the filter element in it, and had unfiltered fuel headed through my fuel injectors....
http://www.golanproducts.com/filters.html
1976 Kawasaki KE125
BeemerlessBob
Post by BeemerlessBob » Thu May 28, 2015 7:58 am
Clutch cable?
Is there any generic clutch cable that will work for a 2014 gear up or do I need a Ural specific cable?
I'm currency stranded near Asheville, NC. Any suggestions as the the quickest place to get a cable?
Adventures and Misadventures bog: http://www.BeemerBob.com
2014 Gear Up (The Grey Goose)
Modifications:
founding member of the "Let it Be" support group.
tonered
Post by tonered » Thu May 28, 2015 8:34 am
It looks like it has two standard ferrules on the ends, except the clutch arm end is installed lengthwise versus the more common transverse direction. The only thing special would be the length of the sheath. So, measure it and call some of the local shops. I wouldn't go any shorter, but an inch or so longer would be okay.
I also remember back in the day, you could buy replacement cable for bicycles. It came without a ferrule on one end. The ferrule was clamped on with a couple set screws. It would be genius if they made these for motorcycles.
Good luck!
My clutch cable frayed out at the levers at about 10,000km. The replacement has been great.
Have a good one.
tony b
Lynnwood, WA
