2014 Ural Parts List
Post by Albuquralque » Wed Mar 12, 2014 10:34 am
Battery
YTX20L-BS
Brake Pads
Rear - EBC FA473V (Used on 08/09 Spyder Can Am)
Sidecar - EBC FA266V
Front - EBC FA244HH
Light Bulbs:
Plate and car presence light - Osram 5007 - 1156 base.
Car running light - Osram 7506 - 1156 base.
Car brake/turn - Osram 7528 - 1157 base.
Bike brake/run - Osram 7506 - 1156 base.
Bike turns - no maker on bulb 12V/21W. 1156 base.
Dash - 12V/2W 7mm dia base. Ridges instead of pins. BA7S base.
Turn Signal Flasher
Napa EP-36L
CEC Industries EF36L
Air Filters:
K&N 33-2022
Spectre HPR3916
AC Delco A974C
Buick 25095333
Fram CA3916
Motorcraft FA1085
Napa 6139
Purolator A33590
Spectre HPR3916
Ural 104015075
WIX 46139
Oil Filters:
Mann W 75/3
Napa Gold 7207
Fram PH6017A
Fram PH10959
Fleetguard HF7615
Baldwin B307
Carquest 84207
Wix 57207
Bosch 3300
Napa 1358
Napa Gold 1365
Mobil1 M1-108
Wix 51358
STP SA2808
Fuel Filter
Napa Gold 3095
WIX 33001 (Plastic)
WIX 33031 (Metal)
ACDelco GF479
Note: I have not tried any of these fuel filters, but others have. You can also try to cross reference these into another fuel filter to see if it works.
Spark Plugs:
NGK BPR6HS
(Autozone 7022 - If you go to Autozone, they cannot cross reference an NGK BPR6HS. But if you give them the number 7022 - it is an NGK BPR6HS).
Speedbleeders:
Front Caliper - SB8125..........M8 x 1.25mm x 27.99mm long
Rear Caliper - SB8125...........M8 x 1.25mm x 27.99mm long
Sidecar Caliper - SB1010S......M10 x 1.0mm x 31.35mm long
Hose clamps for compliance fitting and both sides of branch tubes: https://www.caphardwaresupply.com/colle ... 4345024259
You will need the 40-60mm sized clamps, 6-each of these. Replaces the one-time use pinch clamps.
Hose clamps for fuel lines and brake hoses: Use 1/2" fuel injection hose clamps found at any autoparts store.
U-Joint - Sidecar Driveshaft
Autozone 1-0300DL
Last edited by Albuquralque on Sat Aug 18, 2018 10:21 am, edited 26 times in total.
Roadblock357
Re: 2014 Ural Parts List
Post by Roadblock357 » Wed Mar 12, 2014 5:33 pm
:cheers:
Jack
2014 Sage Green Gear-Up, Василиса Царевна-лягушка (Vasilisa, the Frog Princess)
2004 BMW R1150RT
redtails
Post by redtails » Sun Mar 23, 2014 9:01 pm
Excellent post! FYI, for those who may not know:
Oil Filters:
Mann W 75/3 = OEM filter, easily available through Amazon.
Napa Gold 7207 = from what I heard, is identical to the Mann
Wix 57207 = this filter also identical in size to stock, but is white (if color matters)
Microgard 51365 = smaller and taller than stock
- Jon
2014 Patrol Red/White "Uranus"
Post by wooden nickel » Mon Mar 24, 2014 8:35 am
Amazon has a Bosch D3300 filter that is supposed to be 99.9% efficient. But I guess I will only order them if Gene runs out of stock filters.
But then I still have several weeks of waiting to get my M70 so it's all academic.
co_g30
Post by co_g30 » Fri Apr 18, 2014 9:10 pm
another website for cross-referencing oil filters for the 2014 rigs:
http://www.findpart.org/part/man-w753
CO_G30
2014 Ural Patrol "Scarlett"
1987 BMW R80 "Brigitta"
2006 Yamaha TW200 "Yagi"
heindlengineeringural
Post by heindlengineeringural » Thu May 01, 2014 9:49 am
To add to your list, the sidecar pad is FA266
Heindl Engineering, LLC
Ural Dealer in Southwest Ohio
(937) 787-3686
www.heindlengineering.com
sales@heindlengineering.com
OldSchool
Post by OldSchool » Sat Aug 02, 2014 4:41 am
Coluralado wrote:Brake Pads
Sidecar - EBC FA266
Front - EBC FA244HH
Light Bulbs:
yada, yada, yada, yada, umpty, ump, yeah, yea,
Thanks! Holy Moly ya even got speed bleaders on thar, yo gotta be related back ter someway
:cheers:
It's the ‘stupid’ things we do that we remember the most. The 'good' decisions we forget. But the stupid ones? Ahh, those are the memory builders and the building blocks for great stories and adventures that make you smile and laugh years later.
Siberian Mule
Post by Siberian Mule » Sat Aug 30, 2014 8:07 am
Also~ Oil Filter K&N KN-204
Post by rivers » Sat Aug 30, 2014 1:54 pm
FWIW regarding oil filters: there seems to be another WIX number besides the one listed. I got a couple spares from the dealer and they sent WIX 51358. Haven't used one yet so can't verify it's correct but it's from a reputable dealer. I'll verify one way or the other when the time comes.
Post by Albuquralque » Sat Aug 30, 2014 1:57 pm
rivers wrote:FWIW regarding oil filters: there seems to be another WIX number besides the one listed. I got a couple spares from the dealer and they sent WIX 51358. Haven't used one yet so can't verify it's correct but it's from a reputable dealer. I'll verify one way or the other when the time comes.
There is another WIX number and I had purchased one at one time. The reason I didn't put it on the list is because it is a lot smaller in diameter than the stock filter. So much so that it leaves quite a bit of the flat machined surface exposed and that surface is prone to getting damaged if left exposed.
Roadking
Post by Roadking » Tue Sep 30, 2014 4:12 pm
I just ordered a couple of filters and received the WIX 51358's. I see Darrells point about the exposed surface.
I was wondering if anyone has used them.
2001 HD Roadking FLHRI
barnone
Post by barnone » Sat Nov 22, 2014 9:09 am
Get a "Whoops, our bad..."
on URL
"Hose clamps for compliance fitting and both sides of branch tubes: http://www.caphardwaresupply.com/hose-c ... thin-clamp"
barnone
Post by barnone » Sat Nov 22, 2014 9:21 am
wooden nickel wrote:Amazon has a Bosch D3300 filter that is supposed to be 99.9% efficient. But I guess I will only order them if Gene runs out of stock filters.
Did you try the Bosch D3300 yet?
Post by Albuquralque » Sat Nov 22, 2014 10:43 am
barnone wrote:Get a "Whoops, our bad..."
on URL
I fixed the link in the first post: http://www.caphardwaresupply.com/40-60m ... al-ss.html
barnone
Post by barnone » Sat Nov 22, 2014 4:42 pm
on URL
Thanks. Ordered six.
