Back up generators and a GU
Post by chaos2 » Thu Mar 07, 2013 6:28 pm
Just a neat photo. Pass these everyday on my way to work, finally decided to stop and take a pic.
Re: Back up generators and a GU
Post by Albuquralque » Thu Mar 07, 2013 6:54 pm
06motorradman
Post by 06motorradman » Thu Mar 07, 2013 11:52 pm
That's not Chernobyl is it? :-o
My Bikes: 2011 Ural T ( gone on but not forgotten )
2006 BMW R1200RT, 2011 KTM 990 SMR, 2014 Vespa 300 GTS Super, 2016 Honda CRF250L, 2016 Honda CRF110
Post by chaos2 » Fri Mar 08, 2013 12:57 am
Local power company uses them during peak demand in the summer. 7 Jet engines all pointing straight up, they can also run them to correct minor abnormalities with the earth's orbit :shock:
Teuchter
Post by Teuchter » Fri Mar 08, 2013 3:56 pm
Now there is an idea for my Ural conversion. A small gas turbine from a helicopter with a Denso alternator bolted onto the end!
lendrinkard
Post by lendrinkard » Sat Mar 09, 2013 1:47 am
I use to work on T58 turbo shaft engines. Mario Andretti ...all most won the Indianapolis 500 with one of those engines. A wheel bearing fail just short of the finish line. At the time they put out over 1200 HP and weighed less than 300 lbs.
