New Ural accessories product line! Ural skid plate
HemisphereOffroad
Post by HemisphereOffroad » Mon Sep 10, 2018 10:51 pm
Hi all,
Hemisphere Offroad is launching a brand-new product line designed from the ground up.
Highlighted in this post is our Ural skid plate.
Protect your engine, transmission and exhaust from damage when on the trail! Our skid palte is made from 1/8” thick aluminum, for a lifetime of service. Includes hangers for mounting to the frame tubes.
Removable drain plate allows easy oil draining without removing the skid plate, or making a mess.
Aluminum with durable powdercoat finish.
Includes all hardware needed.
No drilling required.
Installation time: approximately one hour.
Soviet Steeds members and friends special discount: use code "SOVIETSTEEDS" on checkout to get free shipping on your entire order!
$124 + shipping
https://www.hemisphereoffroad.com/produ ... -plate-kit
dogboy443
Re: New Ural accessories product line! Ural skid plate
Post by dogboy443 » Wed Sep 12, 2018 1:38 pm
How is the removable oil change plate attached? is it pre-threaded holes that simply screw in with no locking bolt on the upside?
Mark Masztal
Post by stagewex » Wed Sep 12, 2018 2:50 pm
Skid Plates are like oil threads here. Some work, some crumble (or crumple).
HemisphereOffroad
Post by HemisphereOffroad » Wed Sep 12, 2018 4:51 pm
There are threaded clinch nuts on the topside of the skid plate.
If we were to just thread the skid plate, the threads would fail after a couple oil changes, so we are using steel clinch nuts that are permanently pressed into the skid plate on top, to allow many cycles of screw removal/installation.
Post by BinDerSmokDat » Fri Jan 04, 2019 5:42 pm
Are the brackets aluminum or steel?
HemisphereOffroad
Post by HemisphereOffroad » Sat Jan 05, 2019 1:48 am
Hi, the brackets are steel.
mtrdrms
Post by mtrdrms » Wed Feb 20, 2019 8:20 pm
Hello Emily,
Does the skid plate allow for removal and installation of the old style element oil filter? I know mine is a tight fit past the front exhaust pipe and I see the skid plate had the front pipe guard. Just curious if I would have to drop the plate to change the filter.
Thanks!
- Andy
Everyday. No excuses.
2013 Patrol
HemisphereOffroad
Post by HemisphereOffroad » Thu Feb 21, 2019 1:31 am
Hi, here is a side view showing how far up the skid plate extends. It is supposed to be enough to keep rocks from dinging the most vulnerable area, the lower front corner of the pan and block, without blocking filter access.
That said, if you can measure from the bottom of your filter to the bottom of the side frame tubes, and maybe send me a pic, we can check.
Emily
IndyChizzle
Post by IndyChizzle » Thu Apr 25, 2019 7:38 pm
It's cool to see folks making aftermarket products for Ural! Do you have any videos of the skid plate mounted on a bike? Any resonance issues (humming) when revving the engine?
HemisphereOffroad
Post by HemisphereOffroad » Fri Apr 26, 2019 8:43 pm
Hi! No videos, sorry, but we will try to get one soon.
No harmonics or resonance issues, it fits pretty tightly and does not flex / vibrate under throttle, no.
mattzahr
Post by mattzahr » Thu May 09, 2019 10:42 am
I have one on my '16 cT - no issues regarding removing bottom plate for changing engine oil.
My only (if you want to call it) issue is the need to use a funnel to drain the transmission oil - the upside is that the transmission is protected from an inadvertent piece of debris.
For the record, I am not an off roader - but where I do travel, there are pieces of the occasional hardware or rocks from a nearby quarry that litter the roads.
Fit and finish are OUTSTANDING!!!!
'16 cT - Terracotta 20k and climbing
Former bikes
2005 HD Springer Classic
1983 R80RT
