Not yet.biggziff wrote:You doing swaps yet? I was going to do my own, but if you have pre-made levers I'd rather give you the $$$ and save the time!
let you guys know soon.
5 new levers is might spoken for. Sold out?
Ivan is applaudingvetsurginc wrote:Somehow that looks so much better than my cheap (and less effective) attempt
Ready for another order?![]()
I have the Raceway foot box and no problem kick starting the bike.Hansel wrote:any interest in doing a cut and reweld of a kickstarter lever?with my raceway foot boxes it is missing about 1.5" of travel....
I could kickstart it, but it was hard as it wouldn't kick a full stroke. About 2" from the bottom of the stroke it hits the footbox. Van fixed it, essentially moving it 2" higher, documented in another thread.BinDerSmokDat wrote:I have the Raceway foot box and no problem kick starting the bike.Hansel wrote:any interest in doing a cut and reweld of a kickstarter lever?with my raceway foot boxes it is missing about 1.5" of travel....
Didn't need to modify anything. It clears the foot box with a fraction of an inch to spare.
Did you try removing the kick start lever and rotate it on the shaft splines?
Are you sure it is bottoming out on the foot box?
The link is in my sig, under Raceway Engine Guard, but here it is again...Hansel wrote:I could kickstart it, but it was hard as it wouldn't kick a full stroke. About 2" from the bottom of the stroke it hits the footbox. Van fixed it, essentially moving it 2" higher, documented in another thread.BinDerSmokDat wrote:I have the Raceway foot box and no problem kick starting the bike.Hansel wrote:any interest in doing a cut and reweld of a kickstarter lever?with my raceway foot boxes it is missing about 1.5" of travel....
There are no shaft splines on the kickstarter. its fits on one way and there is a wedge pin that holds it on the shaft.
Thats pretty awesome that yours clears... there is another guy on here who has the same issue i do. do you mind sharing a pic of your setup... I'm very curious
