what kind of problems would I have if I bought a 2002 Ural??
isldtime
Post by isldtime » Thu Oct 29, 2009 1:25 am
First post but a long time lurker.
I already know what I'm looking at but what can I expect.
This would be my first hack .
Lots of feedback would be good!
Oldtimer
Post by Oldtimer » Thu Oct 29, 2009 6:02 am
I would say, plan to add at least 30 minutes to each trip to compensate for all the attention you get and questions asked. :lol:
2003 BMW GS 650
2013 Honda CRF 250 dual srport
2012 Vespa 150LX
2008 Yamaha XT 225
2015 Ural CT
1966 Triumph Bonneville
2014 Suzuki DR 650
Longview, TX
Rib Eye Steak Ride
http://sovietsteeds.com/forums/viewtopi ... steak+ride
chicagorandy
Post by chicagorandy » Thu Oct 29, 2009 7:48 am
There are so many variables, mostly having to do with 'dumb luck' or mechanical misfortune that it is hard to say. Mileage and how the previous owner treated the beast has a great deal of impact too.
Unless it has already been changed out, I'd suggest changing out the battery for a new one.
Then take off the 35amp RPOC grenade alternator and replace it with a new -yes it's pricey - Denso system. Yours might be fine, but CMSI bikes have had their fair share of alternator-induced mechanical disasters that will cost you way more than the entry fee for the Denso. And even it will be well served by Krytoxing new bearings in the adapter (search this site for info on this)
Changing out all the fluids and oil filter right away gives you a nice baseline for future maintenance. Add some Sea-Foam or the like to the first few tanks of fuel.
Happy Shopping
ChicagoRandy
Former Ural driver of Tovarishch - 82,825 since new - sold 08/14/11
1986 Kawasaki Voyager XII - 1200cc's of two wheel bliss
"Down the highway of life at smiles per hour, with special attention to ignorant and blind cagers"
Mud Pie
Post by Mud Pie » Thu Oct 29, 2009 8:31 am
Like Randy said, maintenance from the previous owner is key, as is mileage.
Is the mileage low because the owner didn't ride much or because it was "down" more than "up" ?
ANY vehicle that lays dormant for an extended period will have problems if certian precautions were not taken. Has the rig been stored inside since 2002 in a warm, comfy garage or left outside to the elements ?
High mileage on a Ural is actually a good thing. It means the odds of the owner finding/eliminating all the gremlins are higher.
Anything made of rubber should have been replaced at this point. Tires, fuel lines, etc. should be free of cracks/splits.
Pull the plugs on the tranny, FD and engine, look at the oil. If it's milky, be suspect. If it looks brand new, be even MORE suspect. If it's slightly dirty, that means the bike has been ridden and chances are the gaskets are keeping out water.
Like Randy said, a new alternator will give you piece of mind. Randy knows of what he speaks about the RPOC alternators munching on his engine(s) !!
If you can, find out the owners name, chances are one of us here will know him ! :)
2005 Ural Gear Up with DP-28 replica
Patriot Guard Rider
"I don't drive a Ural to make great time, I drive a Ural to have a great time."
"There is no way to rule innocent men. The only power any government has is the power to crack down on criminals. Well, when there aren't enough criminals, one makes them. One declares so many things to be a crime that it becomes impossible for men to live without breaking laws." - Ayn Rand "Atlas Shrugged"
JohnBG
General Secretary
General Secretary
Post by JohnBG » Thu Oct 29, 2009 8:43 pm
What kind of problems?
You would have to keep a yardstick handy to beat off all the chicks... :lol:
John Grocke aka "JohnBG"
Site Administrator - sovietsteeds.com
'06 Ural Raven - "Vorona"
'09 Kawasaki KLR650 - "Madea"
History:
'98.5 Ural Tourist - "Valentina" - Gone but not forgotten.
2002 Harley Road King FLHPI
1997 Harley Electra Glide FLHTPI
Honda Nighthawk 650 from the mid-80's
1980 Suzuki RM125T
1970 Honda CL100
Love is the feeling you get when you like something as much as your motorcycle.” ― Hunter S. Thompson
Django
2002 Ural
Post by Django » Fri Oct 30, 2009 12:27 am
I bought a 2002 Patrol last year and agree with the above replys. This bike was sitting in a field next to the guys house and was not running. It was dirty and the tires were weather checked, but the speedo showed only 7k km. I bought it and trailered it home. After inspecting the ignition system I discovered the famous 2 piece, pressed together rotor/spark interruptor had spun. However, with a new billit unit in place the motor started right up. I changed all the fluids and oil filter, adjusted the valves removed and cleaned the carb jets and float bowl. I then replaced or (in some instances) had repaired/replaced some components that were questionable or obviously damaged.
The 2002 Urals were the first 750cc production units. Later models had changes to the heads and barrels. Consequently, heads and their related components may be difficult to come by.[/img]
Tooling around doing errands is a hoot. The front drum brake requires you to really pay attention and think ahead as stopping distance may not be as predictable as with newer disc brakes.
In other words, if it looks like a good deal, get it , have fun.
a wink is a good as a nod to a blind horse
2002 Patrol
greenmachine
Post by greenmachine » Fri Oct 30, 2009 11:22 am
There's nuthin crazy different about an '02 model versus another model year...
The '02 was a CMSI era early 750 and NOT an IMWA or current version of the engine. SOME but not all parts in this engine are not interchangeable with current version parts especially in the top end so ya just have to be careful what ya order , etc....
Most of the parts outside the engine are pretty much the same as other model years. NO rig except a new one will have ALL the same parts as a new version unless it has been "upgraded" or modified which MOST rigs get along the way at some point.
kermitski
Russian biker has-been....
Rode around the block a couple times
and got rid of the goofy thing...
isldtime
Post by isldtime » Fri Oct 30, 2009 10:34 pm
Well--I did it. Sitting in my driveway is a prestine black 2002 Ural Tourist.
3800km with everything that came with it from original. The price was very reasonable so the learning fun begins!
45 years of solo.. 0 years of hack!
Here we go...
MartyL
Benevolent Emperor
Benevolent Emperor
Post by MartyL » Fri Oct 30, 2009 10:37 pm
Congratulations!!!! :party: :thumbsup: Welcome!!! Now Practice, Practice, and Practice some more.... Have fun!!!!
1976 Yamaha XS650C
2018 H-D FLHXS
Peace.... God Bless our brave soldiers defending our freedom. God Bless America!
As I get older, I see the wisdom in Hannibal Lecter......
Ladies,Do your part! Prevent MSB often! Save mankind!!!
isldtime
Post by isldtime » Sat Oct 31, 2009 2:34 pm
And There he is!!
RAL
Post by RAL » Sat Oct 31, 2009 3:29 pm
Nice Rig!!
RAL
2005 Gear up
pidgey
Post by pidgey » Sat Oct 31, 2009 3:54 pm
Wow, it's so CLEAN :D
2005 BMW K1200S with Hannigan SuperSport chair
2007 Suzuki Boulevard S83
2010 Patrol (the lemon) SOLD
cpres
Post by cpres » Sun Nov 01, 2009 12:51 am
Welcome and enjoy. I am in So. Ca so maybe I will see you on the road some day.
2007 Ural Retro burning up the road at Ural speed.
Some of my family have asked if Urals come with social lives, I am thinking they do, we have met the nicest people with our Ural.
ugly pumpkin gear up
clean 2002
Post by ugly pumpkin gear up » Sun Nov 01, 2009 2:09 am
clean rig! many miles? how much$? looks like russian rubber. nice find! upgu.
2007 africa gear up / desert camo
2007 dyna street bob
1996 kz 1000 p with bingham sidestrider
1983 yamaha riva 180
Niteblues
Post by Niteblues » Sun Nov 01, 2009 2:23 am
Wow! That is CLEAN! I can't imagine that my engine case and heads will ever look like that again.
Welcome! Ride safe and be happy!
Scott
2004 Ural Patrol
"You can ride farther in one hour than you can walk in a day"
"Media bias contributes to erosion of the perception of truth." Tanya Marcum
