iridium Spark Plugs
Ghengiz
iridium Spark Plugs
Post by Ghengiz » Thu Nov 28, 2019 7:33 am
Just wondering if anyone is using the NGK (4085) BPR6HIX Iridium IX Spark Plug? Advantage/disadvantage?
2019 Gear Up
2012 Kawasaki Concours C14 (still own)
1995 Honda ST1100A
1979 Honda CB750K
Re: iridium Spark Plugs
Post by GHGoodwin » Thu Nov 28, 2019 8:26 am
Search in "Hammerin". I believe this has been discussed.
lendrinkard
Post by lendrinkard » Thu Nov 28, 2019 8:41 am
I have been running those for 7 years. They last forever. I have a set for spares but have not needed them.
Ghengiz
Post by Ghengiz » Thu Nov 28, 2019 6:01 pm
What gap do you use, stock out of the box or Ural spec?
2019 Gear Up
1995 Honda ST1100A
1979 Honda CB750K
Post by RC20 » Thu Nov 28, 2019 6:19 pm
Always use the mfg spec. Plugs fit a variety of engines - rarely is it right for yours.
Post by Mr Wazzock » Thu Nov 28, 2019 7:53 pm
Image Fancy tipped plugs are only for cars so they can have 10,000 mile service intervals. 'Normal' plugs are fine.
:D
Post by sKiZo » Thu Nov 28, 2019 10:16 pm
Love iridium ... better spread for improved fuel scavenging and less detonation due to unburned fuel in the pipes. Used to be a big problem on a couple of my bikes, especially on hard decel like coming off a short ramp. 100k expected service life is a major plus too.
Word of caution if you intend to go with other than the factory gap ... the iridium tip is extremely fragile. The plugs will last forever in normal use, but even the slightest knock on the tip can f'up the plug big time. Best to use a tool that avoids any contact with the electrode.
Post by RC20 » Fri Nov 29, 2019 3:41 pm
Good to know, never had them. Thanks
Post by GHGoodwin » Fri Nov 29, 2019 8:41 pm
NGR BPR7HIX. I've run them for years. Gap .8mm.
scottmastrocinque
Post by scottmastrocinque » Fri Nov 29, 2019 9:38 pm
Whatever floats your boat I guess. I say good for you if it makes you happy.
For myself, I have worked on and restored from the block up, so many VW flat 4 air cooled engines, I couldn’t even begin to count.
Not once did I ever use a fancy super race synthetic oil like Mobil 1 or an iridium spark plug, or special ignition wires or gold plated electric contacts or any such stuff. Just your Plain Jane - run of the mill - general purpose supplies. Like what it came with from the factory.
Luckily for me, I never gave it a second thought and I never got stranded by the side of the road because of not using them.
Of course, it’s your money and YMMV!
I cannot help but wonder though if that stuff is really the Bees Knees, why the manufacturers don’t use it from the get go to really make their equipment shine.
Oh well... Different strokes for different folks, right?
Good luck and happy motoring!
2017 Ural Gear Up Sahara
2012 Moto Guzzi Stelvio NTX
2008 Moto Guzzi 1200 Sport
2008 Piaggio MP3 400ie
1997 Moto Guzzi V10 Centauro
Michal
Post by Michal » Sat Nov 30, 2019 9:43 am
Iridium plugs are for cars where manufacturer specifies spark plug replacement interval 100,000 miles.
I use regular plugs for around 20,000km in my Ural, never had a problem with plug. Surprisingly, road salt seems to kill plug caps sooner than plugs.
Михаил
2005 Урал 750 Спортсман (2WD)
Post by windmill » Sat Nov 30, 2019 12:43 pm
Some do, not unusual at all. They cost 4X more than a standard plugs which can certainly cause a manufacturer pause, but they have some advantages in low performance, high stress applications.
It is rather amusing the puppies and rainbow claims some make, but there is also some hard science and empirical proof to that they do offer some advantages in low maintenance, high fuel economy applications. Its interesting that they're NOT recommended for high performance, and racing applications.
Primarily its their durability as they will last significantly longer. They also run a little hotter for a given heat range so they're less prone to deposits, and the shape of the electrodes have some advantages in less than ideal conditions where the fuel/air mix is compromised, such as when starting or short trips in the cold, certain throttle positions, and high altitudes. Being more conductive they produce a stronger spark for weaker ignition systems.
kc0yef
Post by kc0yef » Sat Nov 30, 2019 12:45 pm
I just switched
2005 УРАЛ ТУРИСТ
scottmastrocinque
Post by scottmastrocinque » Sat Nov 30, 2019 12:50 pm
Good information to know. Thank you!
Post by chaos2 » Sat Nov 30, 2019 2:57 pm
Ditto. Don't remember my other bikes or cars having rusty plugs like the Ural. But then I always put away my other bikes before the salt flew.
