25mm brake and clutch levers
Redtrev
Post by Redtrev » Thu Nov 14, 2019 4:48 am
Hello there and thanks for letting me on here.
I've just bought a Dnepr K750M and I need new brake and clutch levers. I've been searching and I'm struggling to find alloy lever assemblies that fit 25mm bars. I'm not too keen on getting the cheap Chinese stuff.
Any ideas?
Cheers.
Trevor
Re: 25mm brake and clutch levers
Post by Lmo » Thu Nov 14, 2019 5:05 am
Might try "Russian Garage".
https://russiangarage.com/index.php?cPa ... teiebn1kn4
Oh, and welcome aboard Trevor. Add your location to your 'signature' line, you never know when help is just around the corner.
sallen
Post by sallen » Thu Nov 14, 2019 8:09 pm
Also check out Old Timers Garage
I've got a Dnepr, he has quality parts
19?? Dnepr MT16
2008 Gear Up / Orange camo
130/45 one shim
drilled slides
A statement I live by.
Panic is a luxury you can afford after it is all over.
Post by Snakeoil » Thu Nov 14, 2019 10:01 pm
Buy some 1 inch perches and shim them if all else fails. Less than .020" difference. Beer can shim should do the trick.
Eric N
Post by Eric N » Thu Nov 14, 2019 10:22 pm
https://www.ural-zentrale.de/en/chassis ... er-bracket
https://www.ural-zentrale.de/en/chassis ... steel-pair
2001 and older Urals will also be 25mm. The Russian Garage levers are crap, I tried them when I broke a perch and ended up getting what I needed from Terry Crawford. http://www.crawfordsales.info/
2013 Retro Solo
2001 Patrol - Sold
Redtrev
Post by Redtrev » Sun Nov 17, 2019 6:56 am
Many thanks
Post by Lmo » Sun Nov 17, 2019 1:26 pm
Personally, I don't believe you have a Dnepr K750. You'd have to post photos of it to convince me... :wink: :P
