Oil seal dimensions for reverse shifter shaft
Post by Snakeoil » Thu Sep 06, 2018 12:24 pm
I searched here and could not find anything. My aging memory tells me that the reverse shifter shaft seal is an oddball in that either the OD or the ID is a fractional metric size. Example would be 10.5mm instead of 10mm or 11mm. Mine is leaking again. I think I got the last one from Terry. I was considering putting a standard seal in place that is a half mm undersize. The shaft does not spin so no issues with excessive wear and it might just stop the weeping out of that seal.
So, does anyone have the OD, ID and thickness dimensions handy? I realize that the info is printed on the seal. But my small puller is 2 hours away from where the bike and I are and the shifter is in the way of being able to read it. I figure I'll get the seal first so I have it when I pull the lever and replace the seal.
Thanks in advance.
cateyetech
Re: Oil seal dimensions for reverse shifter shaft
Post by cateyetech » Thu Sep 06, 2018 9:27 pm
Hey SO
No expert here :P
The spare seal I have "for our 750" is a
NAK 12-25-7
hope this helps
:foilhead:
Charlie ╭∩╮(-_-)╭∩╮
2003 Gear-Up Ромашка Мзй
2000 Patrol Teh Урал
cateyetech
Post by cateyetech » Thu Sep 06, 2018 9:28 pm
:lol: :lol: :lol: Vans AMAZING vanishing post :lol: :lol: :lol:
:P
Charlie ╭∩╮(-_-)╭∩╮
John B
Post by John B » Thu Sep 06, 2018 9:55 pm
I attached a picture of an old seal that I replaced
The size is on the seal 25.1 X 11.5 X 7
Post by Snakeoil » Fri Sep 07, 2018 9:43 am
Thanks guys. That second one is what I was expecting. It could be they simply moved to the 11mm ID for convenience. I wonder if they changed the shaft size. My guess would be no. If anyone happens to have a 750 tranny with the shifter removed, I'd be curious what the OD of the reverses shifter shaft is. I tried to measure mine, but not quite enough clearance for the caliper with the lever in place.
