Does anyone run wtih stock jets?
dbigkahunna
Location: West Side & Dead Center of the Giant Side of Texas - Gaines County
Re: Does anyone run wtih stock jets?
Post by dbigkahunna » Tue Mar 19, 2013 8:23 pm
Running stock. No too so bad warming up. Two farts, one pop. Then varoom varoom.
"I don't tell my men what to do. Just do the needful." Capt. Jim Riddles, Company E, Texas Rangers
2012 Forest Fog Gear Up
2001 KLR 650
1982 HD Electra Glide
commiezilla
Post by commiezilla » Tue Mar 19, 2013 9:49 pm
Yes, until its time to get'em changed.
2011 Ural Gear Up :: Gobi Desert
"All 2WD is good for is getting you stuck further away from help!!!"--Scott
Tractor Supply: "The Ural Speed Shop"
"OPEC's bike of the year"
"Ural is BMW's Bastard Brother"
Ural-When I go on rides out past where Jesus lost his sandals....
threewheeler
Post by threewheeler » Thu Mar 21, 2013 4:53 pm
I guess some people just like to experiment. I had to re-jet because when I got my Ural the previous owner had fitted a straight through exhaust but I was not convinced the jetting was right. In the end I got it smack on. :D
UK Based
2006 Ural Dalesman
2003 Kawasaki er500
1984 MZ TS 125
1989 MZ ETZ125
planzman
Post by planzman » Fri Mar 22, 2013 7:04 am
See my sig below
Commie Bike Rider USAF Ret
2012 Solo sT "Raven"
If Heaven ain't a lot like Dixie....I don't want to go....Just send me to Hell or New York City....it's all the same to me.
Former owner of 2010 Gear Up
Crawford Sales Co.
Post by Crawford Sales Co. » Fri Mar 22, 2013 8:16 am
In the number of people that have posted here on this topic so far, the bikes they own has covered 3 variations on the electronic ignition and 5 variations on how the carbs were set up from the factory. The bikes change from year to year.
Terry Crawford
Crawford Sales
248-437-8107
No personnel messages.Thank you
http://www.crawfordsales.info - Web Site
crawfordsales@sbcglobal.net - Email
torque
Post by torque » Fri Mar 22, 2013 8:44 am
Thanks, Terry. Sounds like the best track would be to just "wait and see" if we like how it runs?
2017 Triumph T100 w Velorex 563 hack
2013 Ural "T" (custom) (sold)
08 Linhai Aeolus 300 (sold)
09 Yamaha Majesty (traded)
in the mountains of southern West Virginia
"There are many paths from birth to the grave. They all work."
templar1164
Post by templar1164 » Fri Mar 22, 2013 8:50 am
I picked my bike up and other than the heat blocks, I haven't done a thing to the carbs. Its been running without any problems at all. So I figure I'll wait till something happens before I start screwing around. If it aint broke, don't fix it!
Templar1164
2012 FF Gear Up
Post by VWK75S » Fri Mar 22, 2013 9:54 am
MartyL wrote:The only issue with stock jets is when the engine is cold the rigs tend to sputter and fart until warmed up.
That never happens when it's 15F out. Even after a one hour commute to work.
For me the stock jets were awful.
2009 GearUp 140,000kms
2007 Retro 20,000kms
vetsurginc
Post by vetsurginc » Fri Mar 22, 2013 3:56 pm
Bike delivered with 130/40 main and idle, a standard upgrade by Gene. Bike ran fine, dark plugs started first crank.
In an effort to improve mileage I went back to the factory (for a 2011 GU) 122 main and used a Gossie needle, air screw out 1.5 turns. Runs great. Minimal cold start noise, burble in the pipes on deceleration, plugs nice and clean, very slight base color. Now I use the enricheners on startup when temps are in the 40's for the initial start and then close them. Mileage change is more related to break in (i'm at 11,000+ km now) and my throttle hand. Running 58-63 on the the highway I get 26-27 mpg (corrected for odometer error). At 50-55 I get 31.7 pretty regular (both with winds below 10mph). :foilhead:
I put the 130 mains back in with the Gossies and found my mpg at fast speeds dropped to 24mpg, so I'm sticking with the 122's. No changes to air cleaner or filter (the 2011's have the Russian K&N type oiled filters).
Most importantly, Having fun all the time :moto:
Doug
2010 R1200RT Gustav
Post by VWK75S » Fri Mar 22, 2013 8:09 pm
vetsurginc wrote: air screw out 1.5 turns.
Some carbs have coarse and some have fine threads.
Post by windmill » Fri Mar 22, 2013 11:15 pm
planzman wrote:See my sig below
Commie Bike Rider
2010 Desert camo G/U "Clay". As in Ga Red Clay
Sequestered 20% pay cut
Carbs still Snake Oil Free!!
No shims
Factory Jets
Undrilled Slides
Let's Race!
I would like to point out that IMZ-Ural updated the OE needles to match the previous needles with 2 shims.
14:1 is science, not snake oil
Post by BigJames » Sat Mar 23, 2013 8:21 am
Coluralado wrote:I run with stock main jets - 125's. To get a better idle and plug color I had to increase my stock (38) idle jets to 42's.
Oddly enough MY stock jets though! :lol: I don't run 'em!
thors_hammer420
Post by thors_hammer420 » Sat Mar 23, 2013 8:30 pm
I have a 2004 Patrol that I have own and rode sine early 2004. I have considered re-jetting, but my performance is such that I couldn't imagine any gain, especially compared to what I read on the boards. I have the stock air cleaner and clean the filter when it needs it, I also pulled both cats before 500k, and the bike hase about 45k on it give or take since I've had the speedo replaced two times and there's mileage in between without the speedo operating.
Former owner of 2004 Patrol
Post by windmill » Mon Mar 25, 2013 11:16 am
thors_hammer420 wrote:I have a 2004 Patrol that I have own and rode sine early 2004. I have considered re-jetting, but my performance is such that I couldn't imagine any gain, especially compared to what I read on the boards. I have the stock air cleaner and clean the filter when it needs it, I also pulled both cats before 500k, and the bike hase about 45k on it give or take since I've had the speedo replaced two times and there's mileage in between without the speedo operating.
Until you ride a rig that is set up well you can't imagine.
I had ridden Mr. Cob's Preaditor a couple of times before I got serious about getting rid of the OE aircleaner. The absolute top end really isn't that much different, but everything between idle and wot is significantly different.
I ran the OE aircleaner for 5 years, it works, but leaves lots of room for improvement.
Z-Man
Post by Z-Man » Mon Mar 25, 2013 1:26 pm
Signature says it all. When I originally got it in January 2010 it would start in 20 degree temps without the enrichers. I was also getting around 18 mpg. Turns out the dealer put in much larger jets, evidently thinking I wouldn't understand how to start it in cold weather otherwise.
For a while I was running 130's and 127.5's but after a visit with Ski at Triquest last year while on a business trip, I went back to the stock jetting. He's done a lot of dyno work and my take away from that was unless you are doing very significant mods to airbox/exhaust, the standard jets work just fine, and that was up to about 5000 ft elevation if I remember correctly.
As stated earlier in this post, properly adjusted valves and balanced carbs go a long way towards a smooth running engine. I also believe that the Gossie needles do help the performance. I've been running mine for almost 12K with no wear issues whatsoever. Never changed the clips from the setting they arrived with and they are very tight on the needles. I was adding Sea Foam before I put them in and continue to add some every couple tankfuls. Using an additive was on of Gossie's recommendations regarding the wear issue but I was doing that anyway.
'10 Ural Gear-Up (другая женщина the "Other Woman")
K&N Air Filter, Gossie Needles, 127.5/42 Jets, past 20K km and running strong. Someone stole my cats.
What broke and needed fixing: speedometer gear, hack stub shaft.
"Ride today, because you don't know what tomorrow brings"
