2012 T final drive metal bits....
Emoore
Post by Emoore » Sun Feb 10, 2019 8:24 pm
Changing my fluids today and found this on my magnet in the final drive.....should I be worried??
Ernest
2012 Ural T Olive (Roulette)
2017 Ural CT ( Grey Hex)
Yamaha FZ07 ( My need for speed )
Wake Forest, NC
John Wayne - Life's Hard. It's Even Harder When You're Stupid.
Emoore
Re: 2012 T final drive metal bits....
Post by Emoore » Sun Feb 10, 2019 8:25 pm
Ernest
Wake Forest, NC
Post by windmill » Sun Feb 10, 2019 8:56 pm
Yes, Time to crack it open. Bad bearing, ring gear hardware issue, Both?
Post by Tomcatfixer » Sun Feb 10, 2019 10:34 pm
Was this in the '12 or the '17, Ernie?
Barry's right: y'gotta open it up.
Let me know if I can assist.
Virginia Beach + Gordonsville, Virginia, USA
2015 Ural cT "Mobile Chernobyl", 2001 Ural Patrol "The Patrol", 1999 Ural Tourist "The RPOC", 1994 Honda VFR750F, 1986 Yamaha FZX700S Fazer
Emoore
Post by Emoore » Mon Feb 11, 2019 7:00 am
This is my 2012. Is there a "rebuild" kit for the final drive?
It runs fine, no noise no wobble...that's why I was shocked to find big bits as opposed to furry bits on the magnet.
Ernest
Wake Forest, NC
Post by Tomcatfixer » Mon Feb 11, 2019 7:11 am
No, just order some paper or paronite shim-gaskets for the case (the same number that are already installed), open 'er up, see what's broken, then order that part.
Post by Lokiboy » Mon Feb 11, 2019 8:55 am
Ernie, it’s probably small pieces coming off the pinion gear. I’ve had similar debris in the fluids in the past. I just opened my FD a few days ago and saw where a few of the gears had had smalls pieces break off. I’ve gone a lot of miles with no problems. IMHO, refill, ride a few 100 km then drain again. If you’re not seeing any more chucks then forgetaboutit.
I should note that I opened thenFD to replace my drive hub and reused the pinion gear. Didn’t dawn on me to order a new one. :lol: (faith or ignorance - its a fine line)
Oh, I’ve also had fluids look like yours in the past. But, I tend to wait and see. It should diminish but (at least on mine) never totally go away.
Good luck
90,000 km and counting
WEGUNTER
Post by WEGUNTER » Mon Feb 11, 2019 10:06 am
Hey Ernie, If you need a garage and a warm place to work on that FD, bring it on down my way. I got all the tools and work benches. Have never cracked open a FD before so this would be a learning experience for me.
Post by hotflash44 » Mon Feb 11, 2019 10:44 am
Sounds like something my heart surgeon told me! :boogie:
Post by rougaroo » Mon Feb 11, 2019 11:47 am
The 1WD is a lot simpler than the 2WD, too. If you replace the gears, you should be getting the new Italian ones, but it'll be good to ask specifically for them.
Emoore
Post by Emoore » Mon Feb 11, 2019 2:42 pm
Thanks all. Lokiboy you said the same thing the car mechanic nextdoor said. I'm a bit more paranoid to leave it alone.... You have seen my luck, right?? Lol.
Appreciate the offer Wegunter, I might take you up on it.
Beats laying on a cold wet driveway....
I'll keep this open and post my progress or lack of...
Thanks all
Ernest
Wake Forest, NC
Emoore
Post by Emoore » Mon Feb 11, 2019 2:45 pm
Where does one get these gears from, and how do you know when you get them that are Italian??
Ernest
Wake Forest, NC
WEGUNTER
Post by WEGUNTER » Mon Feb 11, 2019 4:08 pm
Call Holopaw Gene
Michal
Post by Michal » Tue Feb 12, 2019 3:43 pm
This metal debris is way too large. Don't drive it anymore or you can ruin the bevel gear. New Russian made gear set is a bit expensive. New western made gear set is f-ing expensive. If it's just broken tab, loose bolt or ruined bearing, fix is cheap.
By my deeds I honor him, flat twin.
Михаил
2002 Днепр 650 Молодежный Чоппер (КМЗ-8.157.022)
2005 Урал 750 Спортсман (2WD)
Post by rougaroo » Tue Feb 12, 2019 5:15 pm
Shopping list:
ring gear & pinion set - make sure to ask for new ones
paper case gaskets - get three or four, they're cheap
new SKF bearing - if you're gonna keep the bike or just want to do a good job
Putting in a new pinion & ring set you may need shims for both the pinion and the ring gear. Ask Gene or Terry or Heindl. Sometimes you need 'em and sometimes you don't. They aren't expensive, at any rate. I like to have them on hand 'cause if you need them your job just stopped dead until you get them in the mail.
