Steel Rims
Who's Ur Grandaddy ?
Re: Steel Rims
Post by Who's Ur Grandaddy ? » Mon Nov 11, 2019 2:52 pm
I did a quick search for 18" BMW steel wheels . around $200 each + shipping on eBay
john
2013 FF gear-up
Mr Cob bulletproof skid plate
Powerarc ignition
7/64 drilled slides
Leftka III type airbox
Modtop mufflers
Re: Steel Rims
Post by Lmo » Wed Nov 13, 2019 5:12 am
Lou , I would recommend that you re-lace some round steel wheels , if you can find them.
That was the idea behind this thread...
wyowillys46
Re: Steel Rims
Post by wyowillys46 » Wed Nov 13, 2019 11:36 am
I recommend Woody's, although shipping will be a bit expensive to Pismo. I've had them rebuild all four rims on my bike (only one with an alloy rim so far), and I've had them build two alloy rims for an M72. Jarod was pretty surprised at how out of round the steel rims were. If you do get them rebuilt, check the drums for out of round after they're laced up and find a machinist who's willing to mount the whole wheel in a mill and touch up the friction surface.
Morgan
'06 Gear-Up
195? M72/K750 hybrid
Re: Steel Rims
Post by Snakeoil » Wed Nov 13, 2019 8:13 pm
You don't have to put the wheel in a mill. There are brake drum lathes that will take our Ural wheels. I know because I had my front drum turned.
The Ural wheels are not the roundest rims I've ever encountered. I suppose if you made some jigs, you could make them better on a press. But it would take some patience and effort. An unlaced rim is not easy to check for roundness. It's doable, just not easy. And you sure are not going to pull them round with the spokes.
A friend of mine has a tool that was probably created sometime before WWII. It uses the hub as a base and presses rims back into shape after having hit a pothole and bent. It is from a time when money was tight and you fixed rather than replaced. Hourly rates were cheap then, too.
Re: Steel Rims
Post by Lmo » Wed Nov 13, 2019 9:32 pm
Vintage Brake is the go-to for drum brake bikes. >> http://www.vintagebrake.com/
But Dave (the owner) once told me that you can pull a brake drum out-of-round simply by over tightening spokes.
Re: Steel Rims
Post by Snakeoil » Thu Nov 14, 2019 12:44 am
Yup. That's why you turn them after they are laced and run in a bit.
wyowillys46
Re: Steel Rims
Post by wyowillys46 » Sat Nov 16, 2019 3:21 pm
Yep. Exactly why the drums are turned or milled after the wheel is built. Just like the proper way to bore and hone a cylinder is with a torque plate installed.
Morgan
'06 Gear-Up
Re: Steel Rims
Post by Snakeoil » Sat Nov 16, 2019 6:47 pm
But Dave (the owner) once told me...
I thought Mike Morris owned Vintage Brake. Is he just the guy that runs the place and Dave is the owner.
Mike knows his stuff and has been helpful with vintage drum info in the past. He's very honest about his shop being backed up and the prices are not cheap. I asked him about turning Ural drums and he dissuaded me from sending them to him. I suspect he did not think they were worth it.
We put my front, which was pulsing badly, on my friend's brake lathe and just took enough off to true it up. What a difference. He died last year and I'm heard they were selling the equipment in his shop. Wish I had room for that brake lathe. Not sure I could justify buying it though. Would be fun to do vintage bike wheels, though.
Re: Steel Rims
Post by jaybird » Sun Nov 17, 2019 5:24 pm
I have a 21” swing Bradford lathe, when I run 3 phase electric into that building, trueing Ural brake drums is going to be one of my first projects. :D
Spat
Re: Steel Rims
Post by Spat » Mon Nov 18, 2019 12:43 am
+ 1 on Woody's, they'll push you towards Excel wheels pricey but they'll put up with the hammering of a Ural (I hope) and what they recommend for the big heavy BMW GS Big Pigs. I was skepitcal but after the later model Ural aluminum wheels failed from my first Woody' rebuild I went for the Excel's. Either wheel I never had a spoke (stainless) problem, Ural wheels failed too many times. Lucky I don't pay shipping, their close.
Hello Wyo
Spat
FLHGSSXDR.Patrol
Proud member of the Patrol Patrol
Fall in love with a person who enjoys your madness
Red Green: If life gives you lemons, throw 'em into a quart of vodka.
Red Green: Duct tape or zip tie,,, fixed is fixed
If we don't change direction soon, we'll end up where we're going.
Irwin Corey
Re: Steel Rims
Post by Snakeoil » Mon Nov 18, 2019 2:26 pm
Yikes! That one mutha of a lathe. Don't 'think I'd want to slide that down the basement stairs. :wink:
Re: Steel Rims
Post by Lmo » Tue Nov 19, 2019 1:28 pm
Does anyone know what the dimensions of a 'stock' steel rim are for a 4.00 x 19" tire?
Aside from the obvious 19" ... what is the 'width' of the rim. I don't have one without a tire on it, and don't really want to break it down to measure it (yeah, I'm lazy, no contest).
Thx.
Re: Steel Rims
Post by Tomcatfixer » Wed Jan 15, 2020 11:49 pm
Thx.
I just so happen to be between tires on this 2001 steel-rimmed Patrol wheel. It measures a consistent 76mm wide all the way around and between 54-55mm inside.
Re: Steel Rims
Post by Lmo » Thu Jan 16, 2020 5:27 am
Thanks Chad, that was exactly what I was looking for. Had a conversation with Richard Winter (Bural) the other day, he's got a line on "Harley" wheels from Drag Specialties. Kinda spendy though, about $180 apiece.
Re: Steel Rims
Post by jeffsaline » Thu Jan 16, 2020 12:37 pm
Jaybird,
If you add a Variable Frequency Drive (VFD) to the lathe you won't need 3 phase and you'll have an electronic speed control on the lathe. Probably less expensive than running 3 phase too.
