Steel Rims
Steel Rims
Post by Lmo » Thu Nov 07, 2019 4:19 pm
I searched back through the site for aluminum rim alternatives, not much there.
I spoke with Chris at Woody's Wheel Works (pleasant, helpful, familiar with Ural wheels (and has done several)); in 'general terms' * a new, 40 spoke steel rim, new spokes, laced and trued is roughly $450. $50 more gets you an aluminum wheel.
Disintegrating aluminum rims aren't a problem on my old Dnepr, but I'm considering new rims because my old steel rims are a) not round, and b) starting to get pretty raggedy (pitted, rusted, etc.).
* if the old spokes are still reusable, then price would be somewhat less.
bratmanxj
Re: Steel Rims
Post by bratmanxj » Fri Nov 08, 2019 2:15 pm
I've got a local "old school" Harley guy I grew up by who just trued up a rather nasty front wheel for me. I've done some research on this forum but haven't found any clear answers. Is there any aftermarket rims (19" hoop) to be found that fit our bikes? I've seen some mention that fatter HD wheels can be fitted, is there any benefit in tire choices with different sizes?
Who's Ur Grandaddy ?
Re: Steel Rims
Post by Who's Ur Grandaddy ? » Fri Nov 08, 2019 2:28 pm
Have you tried Buchanan's ? I used to use them back in my /2 days. I think that they are in El Monte Ca.
john
2013 FF gear-up
Mr Cob bulletproof skid plate
Powerarc ignition
7/64 drilled slides
Leftka III type airbox
Modtop mufflers
Re: Steel Rims
Post by Snakeoil » Fri Nov 08, 2019 8:11 pm
Lew, don't give up on your old rims yet. Take them apart and have the rims powder coated with a color you like. I had a set of steel shouldered rims from a 305 Scrambler powder coated silver because they were too pitted to rechrome. They look great and many think that they are aluminum. I bead blasted the spokes and zinc plated them in my basement.
I'm amazed at the price of a laced wheel these days. I suspect that cast wheels have put a major dent in the volume equation.
If your spokes will unscrew, I'd suggest that you bead blast them and zinc plate them yourself. I can give you the procedure to do it in your house. Very safe, cheap and holds up well. The other choice is to blast and paint them with a good rattle can paint. I did the spokes on an S90 that way before I started zinc plating. They still look like new and that was at least 10 years ago. And the bike gets ridden. Bake the paint in your oven if you take that path.
Re: Steel Rims
Post by jeffsaline » Fri Nov 08, 2019 10:56 pm
If you are going to try to remove the spokes and nipples intact instead of cutting them with a bolt cutter... maybe give each spoke/nipple a dose of Kroil Penetrating fluid. You can get Kroil from Kano Labs if it is not available locally. I find it is easy to apply using a small syringe and 18ga needle with the tip dulled on a belt sander or grinding wheel. Kroil works well and if you give it a chance to work and maybe a couple of applications over a few days it works even better.
Re: Steel Rims
Post by Lmo » Sat Nov 09, 2019 12:16 pm
I'm done with these rims Rob, they're WAY out of round (heart shaped, almost). A friend of mine operates a metal polishing business and has de-chromed and polished out parts for me in the past, but these rims are trash; if I'm going to spend the money I'd just as soon replace the rims. But given the HUGE spokes used by Dnepr/Ural finding rims might be an issue. I have time now, so re-lacing them myself is what I'm thinking.
I had Buchanan's rebuild the wheel on my /5 about fifteen years ago; stainless spoke & nipples. At the time I think I paid around $300 each; they turned out great. Didn't think to ask Chris, at Woody's, about the large(r) spoke size.
Kroil is best purchased by the case.
Re: Steel Rims
Post by INSUBORDINATOR » Sat Nov 09, 2019 1:09 pm
DNEPRS imported by NEVAL in the 1980's had CAST ALUMINUM 5 spoke (Russian Star) wheels. I had a set on my NEVAL DNEPR, & painted the star RED.
They were surprisingly handsome (in a Vintage LOCOMOTIVE way) I loved them, They stayed true. I should have hung onto that bike.
I've seen URAL photos from Russia with what appear to be riveted flat steel painted spoke wheels. I'd trade all 4 of my pretty spoke wheels for a set - in a heartbeat.
Re: Steel Rims
Post by Lmo » Sat Nov 09, 2019 5:23 pm
I love locomotives, and DO find these attractive ...
edit - I also can't find squat about these wheels.
Re: Steel Rims
Post by Snakeoil » Sat Nov 09, 2019 5:28 pm
Yikes!!! Those wheels look like they came off a vintage traction motor.
The large spokes should not be an issue if you reuse them with new rims. Assuming the dimple in the wheel will accept the bigger head of the nipple, you should be able to simply drill them to fit.
Harley's ran sidecars for years and used standard HD spokes, same as used on all the solo bikes. I would think if you laced up a new rim using spokes of the same gauge HD used back then, you'd be fine.
Do the new Ural wheels with aluminum rims use the same sausage sized spokes that older steel rimmed models used? I've never bothered to look.
Re: Steel Rims
Post by jaybird » Sat Nov 09, 2019 8:07 pm
I’m pretty sure the wheels on that red motorcycle are home built.
IIRC, either the RAMCO Dneprs or the NEVALS came with Acront aluminum rims, you might try looking for some of those. I have one I bought on eBay many years ago, nice wheel, I’ve been saving it for the front of a solo I’m planning to put together.
Re: Steel Rims
Post by Snakeoil » Sat Nov 09, 2019 8:29 pm
Buchanans has un drilled, un dimpled, Akronts. Assume they are made by Morad. But might be NOS. $207 each.
Re: Steel Rims
Post by stagewex » Sat Nov 09, 2019 9:03 pm
+++1 on Buchanon whether you leave the rims as-is, have them powedercoated like I did or simply paint them. A no-brainer:
These are Polished Stainless-Steel, not Chrome. But they do have Chrome too if that's your thing. After 10 years the powdercoat gets a bit duller but I assure you the spokes look exactly the way they did as in this 1st day picture.
Tough as nails strength for sidecar duty compared to the factory spokes. At least the ones from 2007. Are the newer ones better?
Bilgekeeldave
Re: Steel Rims
Post by Bilgekeeldave » Sun Nov 10, 2019 2:14 pm
RAMCo wheels were chrome plated steel Dnepr export wheels. RAMCo got them from the Dnepr factory. They were made by a Russian aerospace company. RAMCo looked into having more made but the manufacturer wanted a very large order to set up production again and RAMCo didn't need that many.
Dave
RAMCO-Dnepr MT-16
Re: Steel Rims
Post by Who's Ur Grandaddy ? » Mon Nov 11, 2019 2:33 pm
On /2 BMWs , a purposely built for a sidecar bike ( complete with welded on sidecar mounts.) .. The factory recommended that the aluminum wheels were to be swapped out for factory STEEL wheels for the stress that a sidecar rig produced. The Buchanan cost in 1987 for lacing 4 steel BMW rims with heavy-duty stainless spokes was $250 each.The factory steel wheels were , I believe , a taste wider also.
Perhaps the reason for most cracked and split Ural aluminum wheels is that Ural strayed from their BMW roots and went with aluminum wheels over steel wheels for sidecar use.
Lou , I would recommend that you re-lace some round steel wheels , if you can find them. I would be a shame to invest all the money on aluminum wheels , only to have them fail.
Maybe you can find some old stock BMW steel .They would be 18" though. Not a bad thing off the line , but will shave a tad off top speed. Hills will be easier. NOS /2 stuff can be spendy though.
john
2013 FF gear-up
Powerarc ignition
7/64 drilled slides
Modtop mufflers
Re: Steel Rims
Post by stagewex » Mon Nov 11, 2019 2:43 pm
I can't remember the name/brand of this particular rig that I saw a few years ago at the Motorcyclepedia upstate NY.
Pretty sure it's German. It's steel-wheels remind me of the ones that were pictured earlier:
