New GPR 2-into-1 right exit high mount stainless exhaust
MountainPeakCruiser
Re: New GPR 2-into-1 right exit high mount stainless exhaust
Post by MountainPeakCruiser » Mon Aug 19, 2019 4:33 pm
For those of you following, here’s the video I just punched out:
https://youtu.be/oMQjz0a4gpg
I think the sound quality came out well. It purrs at low speeds and sounds beautiful when you open it up. It has a very charming sound that is very suitable to the personality of the motorcycle.
Colorado Springs :devildog:
2017 Gear Up, Terra-cotta orange
Full LED light conversion w/ Hella headlamp&spotlight.
EJK tuner w/ K&N filter. Full GPR 2-into-1 stainless exhaust. ClearBra to protect cheap but sparkly Russian paint.
MountainPeakCruiser
Post by MountainPeakCruiser » Mon Aug 19, 2019 5:02 pm
Just a couple notes on the install. I recommend putting some hi-temp anti-seize on the exhaust flanges before mounting the pipes to the cylinder head, it eases the seating process as you tighten it down. The torque spec calls for 25nm or 18ftlbs, but I feel that was 20% too much. Also find some more washers (4 worked for me) for the rear passenger pegs. The GPR kit includes ONE washer to allow the left pax peg to fully tighten (after removing the stock exhaust mount which act as a thick spacer), but but one washer is not enough. I added two additional washers between the frame mount and the swing arm rubber bumper for the left peg for a total of 3 washers; this also properly aligned the bumper with the swing arm. On the right side pax peg I added two washers between the frame mount and the exhaust mount; this helped to align the exhaust better through the opening (between the sidecar mount, driveshaft, and 2WD linkage). The washers are slightly larger than 1/2”, a 9/16” by my best estimate. I simply put 1/2” washers in my vise and made them slightly larger with a round metal file.
Yakatak
Post by Yakatak » Sun Aug 25, 2019 3:01 pm
Here's hoping they eventually provide fitment for the '14-'15.
2014 Ural Gear Up - Asphalt
Daisy Cutter
Post by Daisy Cutter » Mon Aug 26, 2019 5:56 am
Lokiboy wrote:
Thu Aug 15, 2019 8:23 am
Daisy Cutter, I like the Raceway. Granted, the muffler tubing is difficult (read as impossible) to keep clean looking, but other then that... I’m glad I bought a used one, however.
I like it too, over the stock pontoons. My issues are with who it came from and the hassle I had dealing with them....and the cheap coating.
North Alabama
2017 Ural Gear Up
Ironhand
Post by Ironhand » Mon Aug 26, 2019 10:11 am
What change between 2015 and 2016 to make this a 2016+ only exhaust?
2015 Ural Gear Up
2012 Yamaha Super Tenere
2003 Yamaha FZ1
MountainPeakCruiser
Post by MountainPeakCruiser » Mon Aug 26, 2019 4:23 pm
I believe someone mentioned someone that is a subtle change in the exhaust flange. So obviously not a major modification to make this available for earlier models.
Aurans
Post by Aurans » Sun Sep 08, 2019 10:28 am
Also curious if anyone can say why the exhaust is labeled off road only.
Post by rivers » Sun Sep 08, 2019 11:01 am
First guess would be it doesn't meet EPA air quality or DOT noise regulations?
Kaliram
Post by Kaliram » Sun Sep 08, 2019 11:32 am
No catalytic converters...
2012 Ural Gear Up ("Tootles")
Aurans
Post by Aurans » Sun Sep 08, 2019 12:18 pm
Thanks!
Post by windmill » Sun Sep 08, 2019 1:39 pm
All of the above plus it's illegal to modify anything emissions related unless it's been certified by the EPA and Dot. The level of enforcement depends on the state. Here in Washington it isn't a problem on public roads, but one better have either the DOT, or spark arrestor markings when riding FS roads.
Post by RC20 » Sun Sep 08, 2019 4:12 pm
While I have a cT, I too have the issue with getting burned (right elbow is still scabbing off and yes I was dumb) and burned my leather on the left side a number of times now.
To me the advantage of going mid height is that it gets the muffler out of the goop and it will stay cleaner.
Left side access as noted by Chad is better.
A bit more noise is not bad and I wear plugs for any longer distance runs.
I will be interested in any power improvement, I don't need it but more power as long as it does not affect the engine life is alwyas a plus.
Now what do I sell to afford this (unlike the government excess purchases need to be offset with cuts or income)
In my case as I quit work (no I did not retire) and no longer work 4 days a week and have 3 days off, I have to generate revenue to pay for my excess.
Post by RC20 » Sun Sep 08, 2019 4:13 pm
Is there an improvement in go pup with out the Cats?
Post by Tomcatfixer » Sun Sep 08, 2019 4:17 pm
Proofread before clicking 'submit'. :D
Post by jaybird » Sun Sep 08, 2019 5:17 pm
What, you never heard of “go pup”? :lol:
I don’t think lack of proof reading is the problem there.
