VW steering damper question
Bigbikerrick
Post by Bigbikerrick » Mon Sep 20, 2021 1:03 pm
Hello Folks. I plan to add a VW steering damper to my Ural, like I have done to some of my previous sidecar builds. My question is can someone who has one on their rig please tell me the what the diameter of the shaft is at the end that slips into the heim joint? I want to make sure and order the proper sized heim joint. I believe the choices are 3/8", 7/16", and in metric 8mm, 10 mm, etc. I will make the two "L" brackets that hold it in place out of flat steel strap.I know I could buy a fine kit from "sean", but I am retired, and have time on my hands to build stuff. I like to make stuff! :D
thanks alot
Rick.
2012 Ural Gear Up / Forest Frog color. 2008 Goldwing Champion Trike, 73 Guzzi Eldorado, 17 Guzzi Griso
Re: VW steering damper question
Post by chaos2 » Mon Sep 20, 2021 2:49 pm
FWIW, this is the heim joint I used, https://www.ebay.com/itm/271508221403. Dampener was for a 64 bug.
Past afflictions include limey cars and motorbikes, an R60/2, R65ls, & a Citroen.
Now a couple of bicycles, a worn out '87 K75s,
Dual K&N cones on homemade PVC intake, 40/137.5
Raceway needles, Modtop pipes, E starter delete
Post by jeffsaline » Mon Sep 20, 2021 2:57 pm
I don't have the size handy for the one by Sean but... I remember looking at my local ACE Hardware store and they had them in stock in the nuts and bolts area. I think the cost was about $16.
Might be worth getting the shock on hand to see what it requires.
Bigbikerrick
Post by Bigbikerrick » Mon Sep 20, 2021 4:02 pm
Thanks alot, Chaos,and Jeff, thats exactly what info I am looking for. I didnt know ACE carried stuff like that. A Ural ride to the ACE hardware in the eclectic , neighboring town of Bisbee is in order!
Rick.
Post by stagewex » Tue Sep 21, 2021 5:58 am
Was/is it a Gabriel Shock? That comes to mind but it’s been a long time since I installed mine.
Good choice, stupid reliable.
Bigbikerrick
Post by Bigbikerrick » Tue Sep 21, 2021 2:04 pm
I have used different brands of aftermarket VW steering dampers on previous builds.For sure,Gabriel makes decent quality shocks , I think the one I bought is a valtek or something like that. I have used them with great success in a Guzzi 1100/ California sidecars friendship II, and a Guzzi 1000 convert/ Texas Ranger rig.
They work a treat on heavier outfits, and are very easy to rig up. I didnt even need to use a heim joint on my last one.
Rick Duarte
Post by Snakeoil » Tue Sep 21, 2021 8:10 pm
Got my Heim from Summit racing. Gabriel damper off flyaway.
Certified Blatherer
Bigbikerrick
Post by Bigbikerrick » Wed Sep 22, 2021 12:53 pm
Thanks, Rob. :)
Bigbikerrick
Post by Bigbikerrick » Mon Sep 27, 2021 12:45 pm
Hey Guys, I got my VW steering damper in, made the brackets to mount , complete with heim joint, and everything bolted up great, but man, is that sucker stiff! I like to experiment, :wink: so I thought "what the heck", and drlled , and threaded a small hole, in the "fat" end of the damper, and pumped out all the original oil. What came out was very strange... whitish / opaque ,like skimmed milk in color, about 3 oz pumped out. I tapped the hole for a small bolt, and O ring to seal it up. I use a 10 cc medical syringe/ needle to refill with oil.My question, is I want to add the thinnest in viscosity oil I can find to reduce the damping. What is the thinnest oil you folks know of? ATF, Marvel mystery oil, oW-20 motor oil, hydraulic jack oil, aviation hydraulic fluid, extra virgin olive oil, :D ? any other suggestions?
Thanks alot,
Rick Duarte
Post by Tomcatfixer » Mon Sep 27, 2021 1:10 pm
I would find the smallest quantity of 2.5W, 5W, and 7W fork oil to experiment with a viscosity that you find appealing. BelRay and Maxima make fine products, and there are other fork oil manufacturers available.
I know these things are subjective, but I find the Gabriel damper on my cT unobtrusive, despite the fact that I have less leverage than the typical Uralista, because my handlebar is considerably less wide. I would argue that the massive "guns" protruding from my shoulders compensate for the lack of leverage, except for the fact that no sane person would describe my scrawny arms as "massive" or "guns".
I'm interested to learn how your damper project turns out. Post pics!
Bigbikerrick
Post by Bigbikerrick » Mon Sep 27, 2021 2:13 pm
Thanks, Chad, I appreciate the info. I am going to order a quart of the 2.5 bell ray, and in the mean time experiment with oils I have on hand. I will take a few pics today also. I think you got me beat hands down in the "Guns dept!" I really need to hit the dumbells, my arms have skin that flaps like hound dogs ears in the wind, where muscle should be! :D
Rick
Post by chaos2 » Mon Sep 27, 2021 2:13 pm
If you were just turning the handlebars with the rig static, stiffness might not be an issue. Mine is quite stiff sitting in the garage but I really don't notice it on the road.
Post by jeffsaline » Mon Sep 27, 2021 2:40 pm
3 in 1 and sewing machine oil are very close to the same viscosity. WD-40 might be another contender.
Post by Snakeoil » Mon Sep 27, 2021 9:37 pm
Damper performance while standing still is not an indication of how it will perform when the rig is in motion. Some have complained about difficulty with slow speed parking lot type turns. That has not been my experience.
Certified Blatherer
Bigbikerrick
Post by Bigbikerrick » Tue Sep 28, 2021 12:13 am
I tried some bel ray 5 wt fork oil, in the damper today,and it seems to work the best so far. I had filled it with Marvel mystery oil first, since it is supposed to be between 2.5-3.o wt. well, I guess it would foam up with air bubbles when worked hard back and forth, as it would develop "dead spots" in different parts of the stroke , even though I carefully filled the shock,and bled out all the air I could. These VW dampers hold about 100 ml of fluid. I was going to also try some aviation hydraulic fluid I have on hand, but the 5 wt bel ray is working so good, I may just leave well enough alone. I would say the damper is currently 50% as stiff as compared to the way it came. Thanks for the suggestions , Jeff. I am now thinking that in this application, its also,important to have an oil that does not "foam up" easily, and cause dead spots in the damper stroke.
Rick.
