Ural Relay Issue
cptred
Ural Relay Issue
Post by cptred » Mon Nov 11, 2019 12:09 pm
I have a 2011 GU and I changed the battery and one of the relays under the seat just came apart. I found a possible replacement but I am not sure if it a good match. My knowledge of electrical stuff is zero.
The wiring diagram looks similar but it is not the same.
This is the old one.
This the possible replacement.
The other difference is that the old one says 87a in the center pin but the possible replacement has 87Q.
Can I use the new one or do I need to get a different replacement?
Thanks, for the help.
cptred
Re: Ural Relay Issue
Post by Wildhorse Cafe » Mon Nov 11, 2019 12:49 pm
Winner winner chicken dinner, you're good to go!
Post by Msblu79 » Mon Nov 11, 2019 12:51 pm
I think you are fine and can use the new one. The diagram is the same just done differently but means the same thing. The new one appears to have a device across the contacts to prevent arching most likely. Hopefully some of our more electrically savvy guys will correct me if I'm wrong. :)
2010 Black Patrol 92,000km's
CamaroEric
Post by CamaroEric » Mon Nov 11, 2019 2:08 pm
I agree, you have the correct replacement.
I think your "Q" is just a very large lower case "a" for easy reading and to match the diagram printed on the front.
The 85 to 86 side is the circuit that activates the relay. It has a high load resistor for minimal current draw when the switch is active.
When the switch is active, pin 30 and 87 are connected.
When inactive, 30 and 87a are connected.
Similar relays at many auto parts stores don't have pin 87a and that potential circuit stays open inside the relay. 4-pin vs 5-pin setup, both useful in the correct application. If 87a pin is unused, I prefer to cap it with a bit of heat shrink for safety if pin 30 is 'power in'.
2008 Gear-Up
2012 NC700X
1962 F-100 Flareside 292 4-spd
Post by jeffsaline » Mon Nov 11, 2019 2:12 pm
I agree it looks like a good match. Terminals 85 & 86 are the control circuit terminals. Terminal 30 is power into the relay. Terminal 87 connects with terminal 30 when the control circuit is activated. Terminal 87a connects with terminal 30 when the control circuit is not activated.
Post by Mr Wazzock » Mon Nov 11, 2019 3:03 pm
The shape of it implies it is a resistor.
The other options are: none, or a diode.
Lastly, is the coil the correct Voltage – 'cause it it's 24V it won't work and guess how I know :oops:
cptred
Post by cptred » Mon Nov 11, 2019 3:07 pm
I think it is a 12V. Here is the link to what I bought.
https://www.bwdbrand.com/en/ecatalog?pa ... p&search=s
It is the R3074.
Post by Mr Wazzock » Mon Nov 11, 2019 3:15 pm
Yep you're good to go. :thumbsup:
Post by GHGoodwin » Mon Nov 11, 2019 3:35 pm
Check the others and get some spares.
Post by Desantnik-VDV » Mon Nov 11, 2019 3:50 pm
It has 30Amp rating, you should be good. You can verify it by matching your fuse rating as well.
The rest...contacts are matching.
The rest is just history.
cptred
Post by cptred » Mon Nov 11, 2019 3:55 pm
Awesome. Thanks everyone.
Post by RC20 » Mon Nov 11, 2019 6:16 pm
It looks like the device across the coil is an anti chatter feature.
Not needed in man circuit but highly important in others.
CamaroEric
Post by CamaroEric » Mon Nov 11, 2019 6:22 pm
On a side note, if your circuit does not use pin 87a, I would convert to 4 pin solid state relays whenever you can.
I used Panasonic ACVN51212.
Solid state relays are much smaller than standard mechanical relays (this one is 15x15x22mm) and also have no mechanical parts to wear out.
https://www.arrow.com/en/products/acvn51212/panasonic
2008 Gear-Up
2012 NC700X
propwash
Post by propwash » Mon Nov 11, 2019 6:26 pm
Protection diodes are a good idea if driving with ICs, transistors or micro controllers.
Switches only, not really needed.
Post by Wildhorse Cafe » Mon Nov 11, 2019 6:54 pm
79a is the normally closes contac 79 the normally open. The symbol across the coil is a capacitor to shunt the emf when the relay is de-energize. Like I said he is good to go for a five pin relay.
