Auxbeam NF-S1 led & Hella E4 lamp beam shots
Post by windmill » Sun Mar 18, 2018 1:58 am
I tried getting some decent beam shots, and of course it started to rain.....
Anyway, a decent representation of how well they work together.
https://www.amazon.com/gp/product/B000V ... UTF8&psc=1
https://www.amazon.com/gp/product/B074G ... UTF8&psc=1
Low beam
High beam
Clean cutoff
Unquestionably an improvement over the stock lamp and halogen bulb, without the additional glare for oncoming traffic like some poorly designed HID, and led bulbs do.
lee 303
Re: Auxbeam NF-S1 led & Hella E4 lamp beam shots
Post by lee 303 » Sun Mar 18, 2018 8:55 am
That is a big improvement! I'm bound for cataract surgery my eye doctor said to wait a few more years before having it done.I don't really venture out that much after dark partly because the oncoming cars headlamps have a blinding halo effect. I met one of my former customers out on the road the other day.He had lens implants done a couple of months ago. At first I struggled to recognize him without his glasses. He said" it was like being reborn". I don't know about you but I don't remember being born the first time.I do remember my first harrowing dismount at speed. It was more like near death than being reborn and very exhilarating. Anyhow better lights equals reduced pucker factor and thanks for taking the time to post the photographs of Bambi down that long dark road.
1996 tourist with mid 70s sidecar
1984 r80rt with sputnik
1967 r60/2 solo
Post by rivers » Sun Mar 18, 2018 11:01 am
Looks good Barry. First LED set up I've seen with that good of results. :thumbsup:
Post by windmill » Sun Mar 18, 2018 7:29 pm
rivers wrote:Looks good Barry. First LED set up I've seen with that good of results. :thumbsup:
I'm really picky about lights, most of what I've seen is dreadful. Glare, hot spots, artifacts, dark or excessively bright near field, short range, some so inconsistent the beam pattern looks like a kaleidoscope, which includes some popular units people rave about.
chopfather
Post by chopfather » Sun Mar 18, 2018 8:59 pm
I think I'm gonna have to do this to my gear up. I had been considering a day maker headlight but this looks like it works great.
Rick Current Bikes- 2018 Ural Gear Up
'91 HD Sportster
'81 Yamaha XS650 - 2 of them, both works in progress
'2015 Coleman CT200U minibike
Post by Tomcatfixer » Sun Mar 18, 2018 9:12 pm
I have the exact same setup now, Barry, since I replaced my Cyron LED bulb with the Auxbeam, and I experienced the exact same results as you. Tomorrow morning's commute to work will be my first ride with the new bulb and I'm quite eager to see the difference on the road, vice the sneak-peek I had in my back yard.
Post by windmill » Sun Mar 18, 2018 9:50 pm
Chad, I also put a 5 3/4 Hella E4 with Auxbeam in my spotlight, and wired it so the low is controlled by the OE spotlight bar switch. The high is wired to the to the main hi/low switch so when I hit the high beam they really light up the road.
Post by Tomcatfixer » Mon Mar 19, 2018 5:04 am
The Mobile Chernobyl doesn't have a spotlight, but I DID install LED strip lighting under the upper ednes of the trunk opening...
...and the footwell, if that counts for additional LED illumination. :D
The '99 project bike DOES (or, should I say, WILL) have a spotlight, but I decided to try out this multi-element all-in one unit:
It might not throw light as far as the Auxbeam, in true SPOTlight fashion, but perhaps it'll give a good, wide, general illumination. It was inexpensive, so we'll see...
I like the idea that your spotlight changes intensity with your headlight beam selection. To control the spotlight on my project bike, I ordered a left switch cluster from China, that has an additional switch molded-in.
Post by windmill » Mon Mar 19, 2018 9:57 am
Chad, that type of light with the led emitters facing outward is a flood light that glares horribly for oncoming traffic. A coworker has a small light bar like that, and quickly gave up using it on the street for that reason, but does like it off road where he doesn't need to see far.
Post by Tomcatfixer » Mon Mar 19, 2018 10:21 am
Exactly my intended purpose. :wink:
Post by windmill » Mon Mar 19, 2018 3:45 pm
Cool, I know a couple of people who were disappointed by them as many sellers misrepresent them as "headlights" when they're not.
bgenest
Post by bgenest » Mon Mar 19, 2018 3:59 pm
lee 303 wrote: thanks for taking the time to post the photographs of Bambi down that long dark road.
That's not Bambi it's a mail box. :D
yb1367
Post by yb1367 » Tue Mar 20, 2018 9:30 am
windmill wrote:I tried getting some decent beam shots, and of course it started to rain.....
Are you using the H4 or 9006/HB4 bulb?
2016 Gear Up
Post by Mr Wazzock » Tue Mar 20, 2018 9:54 am
Tomcatfixer wrote:The Mobile Chernobyl doesn't have a spotlight, but I DID install LED strip lighting under the upper ednes of the trunk opening...
Ooooo..... purty ... Image
It um like a grotto or summink...
Post by windmill » Tue Mar 20, 2018 9:58 am
H4
