Rickgren wrote:Thanks for the input. I got home and hopped on war hog and it seemed to loose the sputter. I've yet to take it on the road to see if that fixed itself yet. As for the gas cap from hell, I found a napa part number on this site and got their last one for $6.25. It looked small but it fits great and looks better. Again,thanks for a great form where folks don't call you an idiot because of not knowing about a new russian bike that you've never seen before.
Mud Pie wrote:You're doing the final seating of all parts in that engine (you'll understand when you change your oil). Tight tolerances are words not used when describing these beasts. If I had two Urals, I'd probably name them Slop and Slap, cause there sure is a lot of them in these things.
As the engine breaks in, the parts move more freely, causing the idle to rise. We've all been there. Scared the bejesus outta me until the learned foilheads here quelled my fears. After a couple hundred km's, when the engine is warmed up, simply back off the idle screws equally on both carbs a wee bit. And I mean a wee bit.
p.s. Unlock the gas cap and throw the key in a drawer somewhere. Not worth the hassle. Never even tried mine, it stayed on the spare key ring. I've read too many horror stories about them. Ditto with the fork lock if your rig has one.
