Possibly Helpful Stuff
Postby Fat Mack » Sat Jul 21, 2007 11:01 pm
[I originally posted this message on Iron Curtain M/C.; I have re-posted it here so that it might help more people.]
Here is some possibly helpful information I have gathered from various sources.
Because I often have issues with the indices provided by tech manual authors, I have cross-referenced each part in several different ways. Spark plug information, for example, may be had under ELECTRICAL; or IGNITION; or PLUGS, SPARK; or SPARK PLUGS.
I have not had the opportunity to test all of this data. I am putting it here in hopes that (1) someone might find it useful, (2) those who try it will add their comments, and (3) other readers will reply with other useful remarks (as VWNate1 has done -- thanks!)
URAL PARTS, CROSS-REFERENCED
Additive, fuel: Marvel Mystery Oil (one ounce to each gallon of fuel)
Additive, gasoline: Marvel Mystery Oil (one ounce to each gallon of fuel)
Air box hose: 21047 Gates radiator hose
Air filters:
K&N: E-2470 from store.knfilters.com
NAPA: 7-02204, SME 702204, 702204; 7-02228, SME 702228, 702228
Air intake hose:
NAPA 8539; NAPA NBH 8539 (cut in half makes 2); CEET-8 from www.wicksaircraft.com
Alternator gear Woodruff key: 3 mm (same as VW Beetle , ALL , 1938-1979 generator or alternator equipped)
Battery:
Interstate #YTX20L-BS
Wal-Mart #ES20LBS
Odyssey #PC680
Bearings:
Clutch shaft: One 6205 Ball Bearing; one 12204 Roller Bearing
Crank: SKF6207
Main shaft: Two 6304 Ball Bearings
Steering Head: from www.cycleworks.net, or BMW #31412 from Ural or vintage BMW dealers
Wheel (all): Timken 30204, 30204M 9\KM1, (Universal number: 30204)
Woodruff key for alternator gear: 3 mm (same as VW Beetle , ALL , 1938-1979 generator or alternator equipped)
Woodruff Key for 4th Gear: 6mm x 6.5mm
Bike running light: 97 (5w)
Bike turn signal: 1156
Brake lights: 1156
Bulbs:
Headlamp: H6024XV, H6014, H6024; Neolight NL-910H44W
Brake Lights: 1156
Indicator Lights (high beam, alternator, neutral and turn): Sylvania 2721 (1.2W)
Instrument Lights (speedometer face): Sylvania 3893 (4W vs. 3W)
Sidecar rear running/brake light: 1157
Sidecar lights, other: 1156
Clutch shaft bearings: One 6205 Ball Bearing; one 12204 Roller Bearing
Coil, ignition: Accel Power Pulse Coil with Accel 8mm Wires
Cotter pins: 2x20; 3.2x20; 3.2x32; 4x12; 4x36; 5x45; 8x16
Crankcase drain plug: M14 x 1.50
Crank bearings: SKF6207
Crank rear main seal: Butyl Chicago Rawhide #21642 or VITON 21641
Deep Sump:
Kenneth Ulrich; 1486 County Road DB; Mosinee, Wisconsin 54455; (715) 693-6201; Machrat@aol.com
Part 8.101-01131.01 at www.imz-ural.com/accessories
Drain Plugs:
Transmission, crankcase, or final drive: M14 x 1.50
Helicoil: www.autopart.com/TOOLS/TOOLSMAIN/tool/T_37149.htm, Metric M14-1.50
Magnetic Drain Plug: ES#5385 from www.ecstuning.com
Drive Shafts - U-Joint:
U-Joint: CarQuest #111/1-0300 w/grease zerk fitting
Sidecar driveshaft U-Joint (with grease zerk): Precision 341; NEAPCO 1-0300; NAPA 111X; Spicer 5-111X; WESCO 201-581; or AMGAUGE 581
Drive Shaft Seal Collar: (IMZ-8.103-6205334) 33mm x 49.5mm x 8mm
Electrical:
Battery: Interstate #YTX20L-BS; Wal-Mart #ES20LBS; Odyssey #PC680
Bulbs:
Brake Lights: 1156
Relays: Standard Motor Products relay RY-115; Stant EL 13 CarQuest
Ignition Coil: Accel Power Pulse Coil with Accel 8mm Wires
Spark Plugs: NGK - BP7HS, Autolite 273, Bosch WGBC, Champion L82YC, Denso W22FP-U 650
Spark Plug wires: Belden 701002; NGK part number 8048 from www.parts-unlimited.com
Filters, air:
Filters, fuel:
Metal (opaque): NAPA 3027
Plastic (see-thru): SKU 111 209 190 from www.bfyobsoleteparts.com
Others: WIX #33011; NAPA #3011 or 3030?; CarQuest #86011; EFI #GF95; Purolator #F21124; FRAM #G4164; AC Delco #GF461; BOSCH #71936
Final drive drain plug: M14 x 1.50
Fluids:
Fuel: 91-octane unleaded
Engine & Gearbox Oil: Premium grade SAE 20W/50 petroleum based detergent oil designed for air-cooled engines.
Final drive oil: Premium grade automotive 90 EP gear oil
Spindle oil/Industrial spindle oil: ZoomSpout
For non-specific lubrication points: Pusser’s Fix-all (a/k/a WD-40)
Fuel additive: Marvel Mystery Oil (one ounce to each gallon of fuel)
Fuel Filters:
Fuel Line: ¼"
Gas cap key: ILCO X84 HD4
Gasoline: 91-octane unleaded
Gasoline additive: Marvel Mystery Oil (one ounce to each gallon of fuel)
Gear, alternator, Woodruff key: 3 mm (same as VW Beetle , ALL , 1938-1979 generator or alternator equipped)
Grease: Lithium-based automotive chassis grease
Headlamp: H6024XV; H6014; H6024; Neolight NL-910H44W
Hoses:
Air intake Hose: NAPA 8539; NAPA NBH 8539 (cut in half makes 2); CEET-8 from www.wicksaircraft.com
Ignition:
Key: ILCO 1526R; ILCO X258; ILCO 1098 B1
Input Shaft Seal: 32mm x 45mm x 8mm
Joint, U - Drive Shafts:
Keys:
Gas Cap: ILCO X84 HD4
Ignition: ILCO 1526R; ILCO X258; ILCO 1098 B1
Woodruff, for alternator gear: 3 mm (same as VW Beetle , ALL , 1938-1979 generator or alternator equipped)
Woodruff, for 4th Gear: 6mm x 6.5mm
Kick Starter Shaft Collar Seal: 20mm x 40mm x 10mm
Lamps:
Bike running Light: 97 (5w)
Brake Lights: 1156
Lights:
Bike running: 97 (5w)
Brake: 1156
Indicator (high beam, alternator, neutral and turn): Sylvania 2721 (1.2W)
Instrument (speedometer face): Sylvania 3893 (4W vs. 3W)
Sidecar rear running/brake: 1157
Sidecar, other: 1156
Line, fuel: ¼"
Lubricants:
Non-specific lubrication points: Pusser’s Fix-all (a/k/a WD-40)
Magnetic Drain Plug: ES#5385 (www.ecstuning.com/stage/edpd/pagebuild_ ... uctID=5385)
Main shaft Bearings: Two 6304 Ball Bearings
Main Shaft Seal: (IMZ-8.103-04015) 36mm x 48mm x 7mm
Oil:
Engine & Gearbox: Premium grade SAE 20W/50 petroleum based detergent oil designed for air-cooled engines.
Final drive: Premium grade automotive 90 EP gear oil
Spindle/Industrial spindle: ZoomSpout
Oil Filter: EMGO #10-26960
Output Yoke Seal: 35mm x 48mm x 8mm
Pins, cotter: 2x20; 3.2x20; 3.2x32; 4x12; 4x36; 5x45; 8x16
Plugs, drain:
Plugs, spark: NGK - BP7HS; Autolite 273; Bosch WGBC; Champion L82YC; Denso W22FP-U 650
Rear crankshaft seal: NAPA # 66524 50mm X 70mm X 9mm
Relays:
Seals:
Crank Rear Main seal: Butyl Chicago Rawhide #21642 or VITON 21641
Transmission output (rear) shaft seal: NAPA # 13941 35mm X 48mm X 8mm
Shafts, drive - U-Joint:
Sidecar lights:
Rear running/brake light: 1157
Other sidecar lights: 1156
Steering head bearings: from www.cycleworks.net, or BMW #31412 from Ural or vintage BMW dealers
Sump, deep:
Transmission drain plug: M14 x 1.50
U-Joint - Drive Shafts:
Wheel bearings (all): Timken 30204, 30204M 9\KM1, (Universal number: 30204)
Wires, spark plug: Belden 701002; NGK part number 8048 from www.parts-unlimited.com
Woodruff keys
For alternator gear: 3 mm (same as VW Beetle , ALL , 1938-1979 generator or alternator equipped)
For 4th gear: 6mm x 6.5mm
Parts for M-72 and early K-750 transmissions (still used on 2006 Ural transmissions)
Output Yoke Seal: 35x48x8
Input Shaft Seal: 32x45x8
Clutch shaft Bearings: One 6205 Ball Bearing, One 12204 Roller Bearing
Fat Mack
Private, 1st Bn. Co. C, SCV Mechanized Cavalry
Riding Rosinante
Dreaming the Impossible Dream since 25 June 1953
Fat Mack
Postby Ragman » Sun Jul 22, 2007 12:31 am
Jee wizz guy.. I need to go buy a printer, to keep that in my workshop - that is one heck of a lot of data.. Thank you.
Милаж
Uralist & Bulleteer
2005 Ural Tourist - Black - converted to 2wd (sold)
1999 Royal Enfield - Green - Classic (sold)
2002 Yamaha TW200 - White, with Blue (sold)
Ragman
Postby Mud Pie » Sun Jul 22, 2007 1:23 am
Copy/Paste/Thank-you !! :D
2005 Ural Gear Up with DP-28 replica
Patriot Guard Rider
"I don't drive a Ural to make great time, I drive a Ural to have a great time."
"There is no way to rule innocent men. The only power any government has is the power to crack down on criminals. Well, when there aren't enough criminals, one makes them. One declares so many things to be a crime that it becomes impossible for men to live without breaking laws." - Ayn Rand "Atlas Shrugged"
Mud Pie
Postby JohnBG » Sun Jul 22, 2007 10:08 pm
Good Stuff!
Shallwe make this a "Sticky post"? :?:
John Grocke aka "JohnBG"
'06 Ural Raven - "Vorona"
JohnBG
General Secretary
General Secretary
Postby DaveO » Sun Jul 22, 2007 10:38 pm
Outstanding job! I take it these #s are for an '06 750? The reason I ask, some of the trans and FD seals have changed, depending on year, or something. Thanks!
DaveO
'00 Patrol 'the ural'
uniquely modified for off road use.... and more quiet than stock
DaveO
Postby Yobe » Sun Jul 22, 2007 11:27 pm
JohnBG wrote:Good Stuff!
YES!
Brandon aka Yobe
'06 Tourist
Yobe
Postby JohnBG » Sun Jul 22, 2007 11:29 pm
YES!
It's been stickified...
Great post FatMack! 8)
JohnBG
General Secretary
General Secretary
Postby Fat Mack » Mon Jul 23, 2007 8:15 am
YES!
Thanks for the compliment! :oops:
What is a sticky post?
Fat Mack
Riding Rosinante
Fat Mack
Postby Ragman » Mon Jul 23, 2007 9:40 am
one that will remain at the top of the forum all the time.
Милаж
Uralist & Bulleteer
Ragman
Postby JohnBG » Mon Jul 23, 2007 4:40 pm
Fat Mack wrote:
YES!
It stays on the top of the list of all posts and deosn't get bumped down the list. Kinda like one of them sticky post-it notes.
Means it's one of them great informative "hall of fame" type posts.
Thanks for sharing it/ Great work! 8)
JohnBG
General Secretary
General Secretary
Postby VWNate1 » Tue Jul 24, 2007 3:48 pm
Good info all but it really should be cleaned up to reduce all the duplicate entires .
Anyway , the alternator gearwoodruff key is a 3MM , same as VW Beetle , ALL , '38 ~ '79 generator or alternator equipped .
NAPA's U-joint should be # 111-X , has a Zerk fitting .
you might want to add that to the orginal sticky .
Postby Fat Mack » Wed Jul 25, 2007 5:42 pm
JohnBG wrote:It stays on the top of the list of all posts and deosn't get bumped down the list. Kinda like one of them sticky post-it notes.
Thanks for the explanation -- and thank you for the compliment.
Fat Mack
Riding Rosinante
Fat Mack
Postby Fat Mack » Wed Jul 25, 2007 5:47 pm
VWNate1 wrote:Good info all but it really should be cleaned up to reduce all the duplicate entires.
The duplications are deliberate. Remember I wrote: Because I often have issues with the indices provided by tech manual authors, I have cross-referenced each part in several different ways. Spark plug information, for example, may be had under ELECTRICAL; or IGNITION; or PLUGS, SPARK; or SPARK PLUGS.
I added the alternator Woodruff key. Now, as to the NAPA U-joint: Is that for the sidecar, or is it the other U-joint?
Fat Mack
Riding Rosinante
Fat Mack
Postby VWNate1 » Wed Jul 25, 2007 10:34 pm
The NAPA # 111X U-joint replaces the Spicer # 5-111X U-joint .
I hope this helps .
If you poke through my posts over on the R.I. Boards , you'll find the odd part #'s and brands of jobs I did on my Ural .
Many parts differ between 650 and 750 Urals too .
Postby Fat Mack » Thu Jul 26, 2007 12:36 pm
VWNate1 wrote:The NAPA # 111X U-joint replaces the Spicer # 5-111X U-joint .
I hope this helps .
It does help -- very much. Thank you. I have updated the list.
I never was able to get into the RI boards, so if you could re-post here, I daresay you would make lots of people grateful (I can call one by name! :D )
Fat Mack
Riding Rosinante
Fat Mack
Next
