Air mixture screws...where abouts?
Postby berger » Sun Sep 09, 2007 12:09 am
I was wondering where exactly the air mixture screw is...I think I know where it is, but I want to be sure. Is it the recessed screw at a nine o'clock position from the main jet?
I know that I should seat it lightly and then turn it out 1.5- 2 turns...depending on the jets I have, which I will verify before I do anything.
Berger
2007 Patrol
Modtop Exhaust/Airbox
145/45 Jets
Drilled Carb slides
2 M3 washers shims
berger
Postby Dwight » Sun Sep 09, 2007 9:46 am
Assuming that you have the stock CVK's on your bike, the air mixture screw is located in the recess on the bottom of the carb - you can get to it WITHOUT removing the fuel bowl from the underside of the carb. 1.5 - 2 turns from a SOFT seat of the screw is a good point to begin with... Some CVK's come with a plug in the recess which you'd need to drill out to gain access to the air mixture screw.
Just curious - are you having a problem of some sort with the fuel delivery system on your bike - or just a general question?
Dwight
'05 Tourist
'93 Solo
Visit my website: www.dwightrahl.com
Visit my eBay store: http://stores.ebay.com/Discount-STIKFAS ... efid=store
Dwight
Re: Air mixture screws...where abouts?
Postby Gummiente » Sun Sep 09, 2007 10:30 am
berger wrote:I was wondering where exactly the air mixture screw is...I think I know where it is, but I want to be sure. Is it the recessed screw at a nine o'clock position from the main jet?
No, that's the idle jet - do NOT unscrew that one. Leave the float bowl on, the air mixture screw is on the outside of the carb body and lies directly underneath the throat closest to the cylinder head. Like Dwight says, 1.5 to 2 turns is a start point.
Mike "Gummiente" Palmer
CURD Head Cheese
'05 Ural Tourist "Doukhbor"
'07 Harley FLTR "Bluebird"
Gummiente
Postby berger » Sun Sep 09, 2007 11:02 am
Dwight wrote:Assuming that you have the stock CVK's on your bike, the air mixture screw is located in the recess on the bottom of the carb - you can get to it WITHOUT removing the fuel bowl from the underside of the carb. 1.5 - 2 turns from a SOFT seat of the screw is a good point to begin with... Some CVK's come with a plug in the recess which you'd need to drill out to gain access to the air mixture screw.
Dwight
Thanks Dwight.
I am experiencing the occassional run-on or burps on shutdown. I want to check the plugs and make sure I am not running rich and I was told to take a look at the jets and verify the mixture screw....in comparison to the jets.
Berger
Berger
2007 Patrol
145/45 Jets
Drilled Carb slides
2 M3 washers shims
berger
Postby berger » Sun Sep 09, 2007 11:03 am
Cool, I thought I saw a pic somewhere and it appeared to be on the outside of the float bowl.
Thanks Mike.
Berger
2007 Patrol
145/45 Jets
Drilled Carb slides
2 M3 washers shims
berger
Postby BillyG » Sun Sep 09, 2007 12:29 pm
It don't matter what jets you got...1.5 to 2 turns out will work...and a half turn difference is going to cause your problem.
Bill Glaser
2002 Ural Patrol "CYKA"
110,000 km's since May 1st 2002
The "Unofficial Ural Service Manual" can be viewed at: www.myural.com
BillyG
Thread Killer
Thread Killer
Postby berger » Sun Sep 09, 2007 8:26 pm
BillyG wrote:It don't matter what jets you got...1.5 to 2 turns out will work...and a half turn difference is going to cause your problem.
I just took a look at my plugs, and while the top is tan brown, the rim of the plug is a little black. I think it might be running rich.
Berger
2007 Patrol
145/45 Jets
Drilled Carb slides
2 M3 washers shims
berger
Postby Thunderstruck » Sun Sep 09, 2007 9:21 pm
Here is a photo with every thing labeled. Pictures help a bunch.
I still say a church steeple with a lightning rod on top shows a lack of confidence.
2006 Gear Up
Thunderstruck
Postby BillyG » Sun Sep 09, 2007 9:26 pm
You are not looking at the rim of the plug to "read" them (partial lie...but not for what you are looking for). Only the insulator and if it is tan you are good to go.
Bill Glaser
BillyG
Thread Killer
Thread Killer
Postby berger » Mon Sep 10, 2007 8:09 am
Thunderstruck wrote:Here is a photo with every thing labeled. Pictures help a bunch.
That is exactly what I needed! Thanks! :cheers:
Berger
2007 Patrol
145/45 Jets
Drilled Carb slides
2 M3 washers shims
berger
BillyG wrote:You are not looking at the rim of the plug to "read" them (partial lie...but not for what you are looking for). Only the insulator and if it is tan you are good to go.
Thanks Bill. It does look pretty tan to me.
Berger
2007 Patrol
145/45 Jets
Drilled Carb slides
2 M3 washers shims
berger
Postby greenmachine » Mon Sep 10, 2007 1:33 pm
The range of fuel mixture adjustment on them screws isn't enough to make the engine run " rich " with stock jets anyways.
What will make one not fire clean is: plug not gapped wide enough.... plug wire terminations at either end not secure... leaky float valve .... air filter partially clogged with too much oil or sumthin like that there.... oil fouling from poorly seated or busted rings .
AFAIK
FWIW
ETC....
kermitski
Russian biker has-been....
Rode around the block a couple times
and got rid of the goofy thing...
greenmachine
Postby berger » Mon Sep 10, 2007 1:49 pm
greenmachine wrote:The range of fuel mixture adjustment on them screws isn't enough to make the engine run " rich " with stock jets anyways.
AFAIK
FWIW
ETC....
kermitski
Ya, I am going to check it all.
Thanks Kermi
Berger
2007 Patrol
145/45 Jets
Drilled Carb slides
2 M3 washers shims
berger
Postby greenmachine » Mon Sep 10, 2007 4:42 pm
I forgot the simplest one ......
BAD GAS !
kermitski
greenmachine
Postby berger » Tue Sep 11, 2007 8:09 am
greenmachine wrote:I forgot the simplest one ......
BAD GAS !
kermitski
I thought of that one, so I make sure to go to different stations and only use premium.
Berger
Berger
2007 Patrol
145/45 Jets
Drilled Carb slides
2 M3 washers shims
berger
