According to the manual I am suppossed to "Decrease the toe in" Well and good! Er...how?
The manual is not clear. It appears the mech. vocab is not consistant and the manual wording doesn't seem clear to me. My dealership is non communicative as they have my money and are not Ural dealerships by nature, but Harley guys! Visited MY URAL. no luck there.
Do I correct the toe in/ out with the back "Slant rod" only? Or is it combination of back and front slant rods being extended and screwed in along with the lock bolts being situated correctly? It aslo appears that both slant rods are used in setting the degree of lean as well? This is not to be played with until the toe in/ out is first set, sez, the manual. Any way, do you folks have any sure fire suggestions to make Ural go Straight? Thanks in advance from a just budding foil head newbie guy!
